[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-412-g86a8a59
Fri Aug 20 21:24:50 PDT 2021
the project "PostGIS".
       via  86a8a59791431b279e4d6511c96af0d3e45332d5 (commit)
      from  ca57f5ffa443aef7f41c59c12a719a10ecb49e7e (commit)
revisions in full, below.
commit 86a8a59791431b279e4d6511c96af0d3e45332d5
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Aug 21 00:24:44 2021 -0400
    Partially revert #4964 which broke mingw64 building.  Closes #4977
diff --git a/configure.ac b/configure.ac
index 2356ab7..422fd87 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1013,7 +1013,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 			if test "x$withval" = "xyes"; then
 				AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/usr/local])
 			else
-				PROTOBUF_LDFLAGS="-L$withval/lib -lprotobuf-c";
+				PROTOBUF_LDFLAGS="-L$withval/lib";
 				PROTOBUF_CPPFLAGS="-I$withval/include"
 			fi
@@ -1044,7 +1044,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	dnl confirm that discovered/configured library path works
 	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],
-		[PROTOBUF_LDFLAGS="-lprotobuf-c"],
 		AC_MSG_ERROR([unable to link protobuf-c using $LDFLAGS. You can disable MVT and Geobuf support using --without-protobuf])
 		HAVE_PROTOBUF=no
Summary of changes:
 configure.ac | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
