[postgis-tickets] [PostGIS] #4975: PostGIS upgrade should not use temp tables as that is banned by some security policies
PostGIS trac at osgeo.org
Fri Aug 20 23:00:29 PDT 2021
security policies
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.2.0
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"87a815cfb038e24e760cbdba1d9fb64d5debd943/git" 87a815c/git]:
 #!CommitTicketReference repository="git"
 revision="87a815cfb038e24e760cbdba1d9fb64d5debd943"
 Upgrade path patchfor address_standardizer_data_us
 and minor fix to patch Closes #4974
 PostGIS upgrade change to not use temp tables Closes #4975
 Closes https://github.com/postgis/postgis/pull/623
 Credits: Jan Katins (Aiven)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4975#comment:2>
