[postgis-tickets] [PostGIS] #4983: Regress failure on berrie on PostGIS 3.2 - protobuf?
PostGIS trac at osgeo.org
Tue Aug 24 23:32:29 PDT 2021
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.2.0
Component:  postgis  |    Version:  master
 Keywords:           |
 18:30:33 PostgreSQL 12.6 on aarch64-unknown-linux-gnu, compiled by gcc
 (Raspbian 8.3.0-6+rpi1) 8.3.0, 32-bit
 18:30:33   Postgis 3.2.0dev - (1045eed) - 2021-08-24 22:21:43
 18:30:33   scripts 3.2.0dev 1045eed
 18:30:33   raster scripts 3.2.0dev 1045eed
 18:30:33   GEOS: 3.7.1-CAPI-1.11.1 27a5e771
 18:30:33   PROJ: Rel. 5.2.0, September 15th, 2018
 18:30:33   GDAL: GDAL 2.4.0, released 2018/12/14
 18:30:33
 01:20:58  ./regress/core/tickets .. failed (diff expected obtained:
 /tmp/pgis_reg/test_78_diff)
 01:21:02
 01:21:02 --- ./regress/core/tickets_expected    2021-08-24
 22:11:03.231269018 -0700
 01:21:02 +++ /tmp/pgis_reg/test_78_out  2021-08-24 22:21:02.488949002
 -0700
 01:21:02 @@ -458,7 +458,5 @@
 01:21:02  #4770.b|POINT(1 1)|302
 01:21:02  #4770.c|POINT(0 0)|300
 01:21:02  #4770.c|MULTIPOINT(0 0,1 1)|602
 01:21:02 -#4916.a|
 01:21:02 -#4916.a|
 01:21:02 -#4916.b|
 01:21:02 -#4916.b|
 01:21:02 +ERROR:  ST_AsGeobuf: Compiled without protobuf-c support
 01:21:02
 This started happening after
 [1045eede8bf6c781707e5aa25bff3b16b789a086/git]
 Well of course one issue is the ST_AsGeobuf test, can't have that in
 tickets, so maybe this is all this failure is about.
 berrie doesn't have protobuf-c installed, the other bots do.  I left her
 that way to catch tese kind of errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4983>
