[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta2-12-g1698074f5
Thu Dec 2 00:11:11 PST 2021
the project "PostGIS".
       via  1698074f5beef257a7b96d088879e91dac5c4a36 (commit)
      from  27f44ecf69ac576c95ff649b2fb23aa3e1cce5c1 (commit)
revisions in full, below.
commit 1698074f5beef257a7b96d088879e91dac5c4a36
Author: Björn Harrtell <bjorn at wololo.org>
Date:   Wed Dec 1 23:36:15 2021 +0100
    Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
diff --git a/doc/po/de/reference_input.xml.po b/doc/po/de/reference_input.xml.po
index 809c03d7d..3347152f6 100644
--- a/doc/po/de/reference_input.xml.po
+++ b/doc/po/de/reference_input.xml.po
@@ -2395,7 +2395,7 @@ msgstr ""
 #. Tag: refname
 #: reference_input.xml:1498
 #, no-c-format
-msgid "ST_TableFromFlatGeobuf"
+msgid "ST_FromFlatGeobufToTable"
 msgstr ""
 #. Tag: refpurpose
@@ -2408,7 +2408,7 @@ msgstr ""
 #: reference_input.xml:1504
 #, no-c-format
 msgid ""
-"<funcdef>void <function>ST_TableFromFlatGeobuf</function></funcdef> "
+"<funcdef>void <function>ST_FromFlatGeobufToTable</function></funcdef> "
 "<paramdef><type>text </type> <parameter>schemaname</parameter></paramdef> "
 "<paramdef><type>text </type> <parameter>tablename</parameter></paramdef> "
 "<paramdef><type>bytea </type> <parameter>FlatGeobuf input data</parameter></"
diff --git a/doc/po/es/reference_input.xml.po b/doc/po/es/reference_input.xml.po
--- a/doc/po/es/reference_input.xml.po
+++ b/doc/po/es/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/fr/reference_input.xml.po b/doc/po/fr/reference_input.xml.po
--- a/doc/po/fr/reference_input.xml.po
+++ b/doc/po/fr/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/it_IT/reference_input.xml.po b/doc/po/it_IT/reference_input.xml.po
--- a/doc/po/it_IT/reference_input.xml.po
+++ b/doc/po/it_IT/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/ja/reference_input.xml.po b/doc/po/ja/reference_input.xml.po
--- a/doc/po/ja/reference_input.xml.po
+++ b/doc/po/ja/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/ko_KR/reference_input.xml.po b/doc/po/ko_KR/reference_input.xml.po
--- a/doc/po/ko_KR/reference_input.xml.po
+++ b/doc/po/ko_KR/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/pl/reference_input.xml.po b/doc/po/pl/reference_input.xml.po
--- a/doc/po/pl/reference_input.xml.po
+++ b/doc/po/pl/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/pt_BR/reference_input.xml.po b/doc/po/pt_BR/reference_input.xml.po
--- a/doc/po/pt_BR/reference_input.xml.po
+++ b/doc/po/pt_BR/reference_input.xml.po
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
diff --git a/doc/po/templates/reference_input.xml.pot b/doc/po/templates/reference_input.xml.pot
index f79d3ec24..a7143904e 100644
--- a/doc/po/templates/reference_input.xml.pot
+++ b/doc/po/templates/reference_input.xml.pot
@@ -2394,7 +2394,7 @@ msgstr ""
 #. Tag: refname
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
@@ -2407,7 +2407,7 @@ msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index ec5640755..3a6b5c7a4 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -1821,16 +1821,16 @@ SELECT ST_AsText(ST_PointFromGeoHash('9qqj7nmxncgyy4d0dbxqz0', 10));
 	  </refsection>
 	</refentry>
-	<refentry id="ST_TableFromFlatGeobuf">
+	<refentry id="ST_FromFlatGeobufToTable">
 	  <refnamediv>
-		<refname>ST_TableFromFlatGeobuf</refname>
+		<refname>ST_FromFlatGeobufToTable</refname>
 		<refpurpose>Creates a table based on the structure of FlatGeobuf data.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
 		<funcsynopsis>
 		<funcprototype>
-				<funcdef>void <function>ST_TableFromFlatGeobuf</function></funcdef>
+				<funcdef>void <function>ST_FromFlatGeobufToTable</function></funcdef>
 				<paramdef><type>bytea </type> <parameter>FlatGeobuf input data</parameter></paramdef>
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 21216ae26..9b992549f 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5079,7 +5079,7 @@ CREATE AGGREGATE ST_AsFlatGeobuf(anyelement, bool, text)
 -- Availability: 3.2.0
-CREATE OR REPLACE FUNCTION ST_TableFromFlatGeobuf(text, text, bytea)
+CREATE OR REPLACE FUNCTION ST_FromFlatGeobufToTable(text, text, bytea)
 	RETURNS void
 	AS 'MODULE_PATHNAME','pgis_tablefromflatgeobuf'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index c2e9167e7..10a535bc2 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -1,6 +1,6 @@
 --set client_min_messages to DEBUG3;
 set timezone to UTC;
-select ST_TableFromFlatGeobuf('public', 'flatgeobuf_t1', (select ST_AsFlatGeobuf(q) fgb from (select null::geometry) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_t1', (select ST_AsFlatGeobuf(q) fgb from (select null::geometry) q));
 select '--- Null geometry ---';
@@ -115,7 +115,7 @@ select 'PL1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
 select '--- Attribute roundtrips ---';
-select ST_TableFromFlatGeobuf('public', 'flatgeobuf_a1', (select ST_AsFlatGeobuf(q) fgb from (select
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_a1', (select ST_AsFlatGeobuf(q) fgb from (select
         null::geometry,
         null::boolean as bool_1,
         null::integer as int_1,
@@ -145,7 +145,7 @@ select 'A1', id, ST_AsText(geom), bool_1, int_1, int_2, smallint_1, bigint_1, fl
 select '--- Exotic roundtrips ---';
 -- 2D Point geometry at column index 2
-select ST_TableFromFlatGeobuf('public', 'flatgeobuf_e1', (select ST_AsFlatGeobuf(q) fgb from (select
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_e1', (select ST_AsFlatGeobuf(q) fgb from (select
         true::boolean as bool_1,
         ST_MakePoint(1.1, 2.1),
         false::boolean as bool_2
diff --git a/regress/core/in_flatgeobuf.sql b/regress/core/in_flatgeobuf.sql
index cf1550fbf..5e36c9e22 100644
--- a/regress/core/in_flatgeobuf.sql
+++ b/regress/core/in_flatgeobuf.sql
@@ -1,5 +1,5 @@
 select 'T1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1,
     '\x6667620366676200240000001000000000000a000c000800000007000a000000000000010400000000000000000000003c00000010000000000000000000060008000400060000000c00000008000800000004000800000004000000020000009a9999999999f13fcdcccccccccc0040'::bytea
Summary of changes:
 doc/po/de/reference_input.xml.po         | 4 ++--
 doc/po/es/reference_input.xml.po         | 4 ++--
 doc/po/fr/reference_input.xml.po         | 4 ++--
 doc/po/it_IT/reference_input.xml.po      | 4 ++--
 doc/po/ja/reference_input.xml.po         | 4 ++--
 doc/po/ko_KR/reference_input.xml.po      | 4 ++--
 doc/po/pl/reference_input.xml.po         | 4 ++--
 doc/po/pt_BR/reference_input.xml.po      | 4 ++--
 doc/po/templates/reference_input.xml.pot | 4 ++--
 doc/reference_input.xml                  | 6 +++---
 postgis/postgis.sql.in                   | 2 +-
 regress/core/flatgeobuf.sql              | 6 +++---
 regress/core/in_flatgeobuf.sql           | 2 +-
 13 files changed, 26 insertions(+), 26 deletions(-)
hooks/post-receive
