[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta2-15-gf55de7f52
Fri Dec 3 20:21:36 PST 2021
the project "PostGIS".
       via  f55de7f52d009bc9467a38ee04e5a16e17e2ba72 (commit)
      from  d8976c0d2f6b8906b583f24e98fba2ef92fb1277 (commit)
revisions in full, below.
commit f55de7f52d009bc9467a38ee04e5a16e17e2ba72
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Dec 3 23:21:31 2021 -0500
    Prepping for PostGIS 3.2.0beta3
diff --git a/NEWS b/NEWS
index aec161b86..9ee0e3422 100644
--- a/NEWS
+++ b/NEWS
@@ -1,15 +1,36 @@
 PostGIS 3.2.0beta3
-2021/xx/xx
+2021/12/04
 This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
 Additional features are enabled if you are running GEOS 3.9+
 (and ST_MakeValid enhancements with 3.10+),
 Proj 6.1+, and PostgreSQL 14+.
+Due to some query performance degradation
+with the new fast index build that requires PG14,
+we have decided to disable the feature by default
+until we get more user testing
+as to the true impact of real-world queries.
+If you are running PG14+, you can reenable it by doing
+ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
+     ADD FUNCTION 11 (geometry)
+     geometry_gist_sortsupport_2d (internal);
+To revert the change:
+   ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
+     DROP FUNCTION 11 (geometry);
+and then reindex your gist indexes.
 Changes since PostGIS 3.2.0beta2 release:
-  * Fixes *
+  * Breaking changes / fixes *
   - #5028, ST_AsFlatGeobuf crashes on mixed geometry input
+    (Björn Harrtell)
   - #5029, ST_AsFlatGeobuf indexed output corruption
-  - #5014, Crash on ST_TableFromFlatGeobuf
-  * Enhancements *
+    (Björn Harrtell)
+  - #5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)
+  - Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
+    (Björn Harrtell)
+  - PG14 fast index building disabled by default. (Paul Ramsey)
 PostGIS 3.2.0beta2
 2021/11/26
diff --git a/README.postgis b/README.postgis
index 6e51289dc..c31624ee7 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.0beta2
-:Date: 2021-11-26
+:Version: 3.2.0beta3
+:Date: 2021-12-04
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 843963a1e..78ef196d7 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0beta3
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 923ee1cae..ee66b7aa0 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,45 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+    <sect1>
+        <title>PostGIS 3.2.0beta3</title>
+        <para>2021/12/04</para>
+        <para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+(and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 14+.</para>
+    <para>Due to some query performance degradation
+    with the new PG14 fast index build ,
+    we have decided to disable the feature by default
+    until we get more user testing
+    as to the true impact of real-world queries.
+    If you are running PG14+, you can reenable it by doing:</para>
+    <programlisting>ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
+    </programlisting>
+    <para>To revert the change:</para>
+    <programlisting>ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
+     DROP FUNCTION 11 (geometry);</programlisting>
+    <para>and then reindex your gist indexes</para>
+    <para>Changes since PostGIS 3.2.0beta2 release:</para>
+    <simplesect>
+        <title>Breaking changes / fixes</title>
+        <para>5028, ST_AsFlatGeobuf crashes on mixed geometry input
+            (Björn Harrtell)</para>
+        <para>5029, ST_AsFlatGeobuf indexed output corruption
+        <para>5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)</para>
+        <para>Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
+         <para>PG14 fast index building disabled by default. (Paul Ramsey)</para>
+    </simplesect>
+    </sect1>
     <sect1>
         <title>Release 3.2.0beta2</title>
         <para>Release date: 2021/11/26</para>
@@ -12,7 +51,7 @@ Proj 6.1+, and PostgreSQL 14+.
 Changes since PostGIS 3.2.0beta1 release:</para>
         <simplesect>
-            <title> Breaking changes / fixes</title>
             <para>5016, loader (shp2pgsq): Respect LDFLAGS (Greg Troxel)</para>
             <para>5005, ST_AsFlatGeoBuf crashes on tables when geometry
                     column is not the first column (Björn Harrtell)</para>
Summary of changes:
 NEWS                  | 29 +++++++++++++++++++++++++----
 README.postgis        |  4 ++--
 Version.config        |  2 +-
 doc/release_notes.xml | 41 ++++++++++++++++++++++++++++++++++++++++-
 4 files changed, 68 insertions(+), 8 deletions(-)
hooks/post-receive
