[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta3-6-g46e9f65c7
Fri Dec 10 21:00:59 PST 2021
the project "PostGIS".
       via  46e9f65c7a157e8944b1d7aad9a226302c834a28 (commit)
      from  b89060db83cb8b17051b00cbf772a75e60b54a1a (commit)
revisions in full, below.
commit 46e9f65c7a157e8944b1d7aad9a226302c834a28
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Dec 11 00:00:52 2021 -0500
    Prepping for 3.2.0rc1
diff --git a/NEWS b/NEWS
index 9ee0e3422..d8813fb01 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,7 @@
-PostGIS 3.2.0beta3
-2021/12/04
-This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+PostGIS 3.2.0rc1
+2021/12/XX
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
+, and Proj 4.9+.
 Additional features are enabled if you are running GEOS 3.9+
 (and ST_MakeValid enhancements with 3.10+),
 Proj 6.1+, and PostgreSQL 14+.
@@ -14,51 +15,14 @@ If you are running PG14+, you can reenable it by doing
 ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
      ADD FUNCTION 11 (geometry)
      geometry_gist_sortsupport_2d (internal);
+and then reindex your gist indexes.
-To revert the change:
+To revert back to the old index behavior:
    ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
      DROP FUNCTION 11 (geometry);
-Changes since PostGIS 3.2.0beta2 release:
-  * Breaking changes / fixes *
-  - #5028, ST_AsFlatGeobuf crashes on mixed geometry input
-    (Björn Harrtell)
-  - #5029, ST_AsFlatGeobuf indexed output corruption
-    (Björn Harrtell)
-  - #5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)
-  - Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
-    (Björn Harrtell)
-  - PG14 fast index building disabled by default. (Paul Ramsey)
-PostGIS 3.2.0beta2
-2021/11/26
-Additional features are enabled if you are running GEOS 3.9+
-(and ST_MakeValid enhancements with 3.10+),
-Proj 6.1+, and PostgreSQL 14+.
-Changes since PostGIS 3.2.0beta1 release:
-  - #5016, loader (shp2pgsq): Respect LDFLAGS (Greg Troxel)
-  - #5005, ST_AsFlatGeoBuf crashes on tables when geometry
-           column is not the first column (Björn Harrtell)
-  - #5017, topology.ValidateTopology error relation "shell_check"
-           already exists (Sandro Santilli)
-  * Enhancements *
-  - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
-  - #5019, address_standardizer: Add support for pcre2 (Paul Ramsey)
-  - GH647, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
-  - GH648, ST_PixelAsCentroids, ST_PixelAsCentroid
-           reimplemented in C (Sergei Shoulbakov)
-PostGIS 3.2.0
-2021/xx/xx
  * Breaking changes *
   - #5008, Empty geometries are not reported as being within Infinite
            distance by ST_DWithin (Sandro Santilli)
@@ -69,6 +33,9 @@ PostGIS 3.2.0
            If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
            (Darafei Praliaskouski)
   - Proj 4.9 or higher is required
+  - #5000, Turn off Window support in ST_AsMVT aggregate
+        as no real use-case for it and it crashes with random input
+        (Paul Ramsey)
  * Enhancements *
   - #4997, FlatGeobuf format input/output (Björn Harrtell)
@@ -118,6 +85,8 @@ PostGIS 3.2.0
   - #4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)
   - GH647, ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented on top of a C function (Sergei Shoulbakov)
   - GH648, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
+  - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
+  - #5019, address_standardizer: Add support for pcre2 (Paul Ramsey)
  * New features*
   - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
@@ -144,6 +113,65 @@ PostGIS 3.2.0
   - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
     the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
+PostGIS 3.2.0beta3
+2021/12/04
+This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+(and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 14+.
+Due to some query performance degradation
+with the new fast index build that requires PG14,
+we have decided to disable the feature by default
+until we get more user testing
+as to the true impact of real-world queries.
+If you are running PG14+, you can reenable it by doing
+ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
+     ADD FUNCTION 11 (geometry)
+     geometry_gist_sortsupport_2d (internal);
+To revert the change:
+   ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
+     DROP FUNCTION 11 (geometry);
+Changes since PostGIS 3.2.0beta2 release:
+  * Breaking changes / fixes *
+  - #5028, ST_AsFlatGeobuf crashes on mixed geometry input
+    (Björn Harrtell)
+  - #5029, ST_AsFlatGeobuf indexed output corruption
+    (Björn Harrtell)
+  - #5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)
+  - Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
+    (Björn Harrtell)
+  - PG14 fast index building disabled by default. (Paul Ramsey)
+PostGIS 3.2.0beta2
+2021/11/26
+Changes since PostGIS 3.2.0beta1 release:
+  - #5016, loader (shp2pgsql): Respect LDFLAGS (Greg Troxel)
+  - #5005, ST_AsFlatGeoBuf crashes on tables when geometry
+           column is not the first column (Björn Harrtell)
+  - #5017, topology.ValidateTopology error relation "shell_check"
+           already exists (Sandro Santilli)
+  * Enhancements *
+  - GH647, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
+  - GH648, ST_PixelAsCentroids, ST_PixelAsCentroid
+           reimplemented in C (Sergei Shoulbakov)
 PostGIS 3.2.0beta1
 2021/10/23
diff --git a/README.postgis b/README.postgis
index c31624ee7..64a9edd63 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.0beta3
-:Date: 2021-12-04
+:Version: 3.2.0rc1
+:Date: 2021-12-11
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 843963a1e..924c89076 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 9a4710cac..bbf5cd099 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1553,6 +1553,7 @@ UPDATE sometable
         <para>If the tolerance parameter is provided, vertices within the tolerance
         of one another will be considered the "same" for the purposes of removal.</para>
+        <para>Enhanced: 3.2.0</para>
         <para>Availability: 2.2.0</para>
         <para>&P_support;</para>
         <para>&Z_support;</para>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index ee66b7aa0..5e5673af5 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,7 +2,123 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+    <sect1>
+        <title>PostGIS 3.2.0rc1</title>
+        <para>2021/12/10</para>
+        <para>This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
+            Additional features are enabled if you are running GEOS 3.9+
+            (and ST_MakeValid enhancements with 3.10+),
+            Proj 6.1+, and PostgreSQL 14+.</para>
+        <para>Due to some query performance degradation
+        with the new PG14 fast index build ,
+        we have decided to disable the feature by default
+        until we get more user testing
+        as to the true impact of real-world queries.
+        If you are running PG14+, you can reenable it by doing:</para>
+        <programlisting>ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
+        </programlisting>
+        <para>To revert the change:</para>
+        <programlisting>ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
+        DROP FUNCTION 11 (geometry);</programlisting>
+        <para>and then reindex your gist indexes</para>
+        <simplesect>
+            <title>Breaking changes</title>
+            <para>5008, Empty geometries are not reported as being within Infinite
+                    distance by ST_DWithin (Sandro Santilli)</para>
+            <para>4824, Removed <code>--without-wagyu</code> build option. Using Wagyu is now mandatory to build with MVT support.</para>
+            <para>4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.</para>
+            <para>4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.</para>
+            <para>4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
+                    If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
+                    (Darafei Praliaskouski)</para>
+            <para>- Proj 4.9 or higher is required</para>
+            <para>5000, Turn off Window support in ST_AsMVT aggregate
+                    (Paul Ramsey)</para>
+    </simplesect>
+    <simplesect>
+    <title>Enhancements</title>
+        <para>4997, FlatGeobuf format input/output (Björn Harrtell)</para>
+        <para>4575, GRANT SELECT on topology metadata tables to PUBLIC (Sandro Santilli)</para>
+        <para>2592, Do not allow CreateTopology to define topologies with SRID < 0
+                (Sandro Santilli)</para>
+        <para>3232, Prevent moving an isolated node to different face
+        <para>- Consider collection TopoGeometries while editing topology primitives.
+        <para>3248, Prevent removing isolated edges if used in a TopoGeometry
+        <para>3231, Prevent removing isolated nodes if used in a TopoGeometry
+        <para>3239, Prevent headling topology edges if the connecting node is
+                used in the definition of a TopoGeometry (Sandro Santilli)</para>
+        <para>4950, Speed up checking containing_face for nodes in ValidateTopology
+        <para>4945, Multi-shell face check in ValidateTopology (Sandro Santilli)</para>
+        <para>4944, Side-location conflict check in ValidateTopology (Sandro Santilli)</para>
+        <para>3042, ValidateTopology check for edge linking (Sandro Santilli)</para>
+        <para>3276, ValidateTopology check for face's mbr (Sandro Santilli)</para>
+        <para>4936, Bounding box limited ValidateTopology (Sandro Santilli)</para>
+        <para>4933, Speed up topology building in presence of big faces (Sandro Santilli)</para>
+        <para>3233, ValidateTopology check for node's containing_face (Sandro Santilli)</para>
+        <para>4830, ValidateTopology check for edges side face containment
+        <para>4827, Allow NaN coordinates in WKT input (Paul Ramsey)</para>
+        <para>- ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)</para>
+        <para>3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)</para>
+        <para>4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
+                to retain direction (Sandro Santilli)</para>
+        <para>4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)</para>
+        <para>4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
+                (Aliaksandr Kalenik, Darafei Praliaskouski)</para>
+        <para>4925, fix ST_DumpPoints to not overlook points (Aliaksandr Kalenik)</para>
+        <para>- ST_SRID(topogeometry) override, to speedup lookups (Sandro Santilli)</para>
+        <para>2175, Avoid creating additional nodes when adding same closed
+                line to topology (Sandro Santilli)</para>
+        <para>4974, Upgrade path for address_standardizer_data_us
+                (Jan Katins of Aiven, Regina Obe)</para>
+        <para>4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)</para>
+        <para>4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)</para>
+        <para>4799, Include srs in GeoJSON where it exists in spatial_ref_sys.</para>
+        <para>4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
+                (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)</para>
+        <para>4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)</para>
+        <para>- GH647, ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented on top of a C function (Sergei Shoulbakov)</para>
+        <para>- GH648, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)</para>
+        <para>5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)</para>
+        <para>5019, address_standardizer: Add support for pcre2 (Paul Ramsey)</para>
+    </simplesect>
+    <simplesect>
+        <title>New features</title>
+            <para>4923, topology.ValidateTopologyRelation (Sandro Santilli)</para>
+            <para>4933, topology.GetFaceContainingPoint (Sandro Santilli)</para>
+            <para>2175, ST_Scroll (Sandro Santilli)</para>
+            <para>4841, FindTopology to quickly get a topology record (Sandro Santilli)</para>
+            <para>4869, FindLayer to quickly get a layer record (Sandro Santilli)</para>
+            <para>4851, TopoGeom_addTopoGeom function (Sandro Santilli)</para>
+            <para>ST_MakeValid(geometry, options) allows alternative validity building
+                algorithms with GEOS 3.10 (Paul Ramsey)</para>
+            <para>ST_InterpolateRaster() fills in raster cells between sample points
+                using one of a number of algorithms (inverse weighted distance, average, etc)
+                using algorithms from GDAL
+            <para>ST_Contour() generates contour lines from raster values
+                using algorithms from GDAL (Paul Ramsey)</para>
+            <para>ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
+                from a raster (Paul Ramsey)</para>
+            <para>New postgis.gdal_vsi_options GUC allows out-db rasters on VSI network
+                services to be accessed with authentication keys, etc. (Paul Ramsey)</para>
+            <para>ST_DumpSegments returns a set of segments of input geometry (Aliaksandr Kalenik)</para>
+            <para>4859, ST_Point, ST_PointZ, ST_PointM, ST_PointZM, constructors
+                with SRID parameter (Paul Ramsey)</para>
+            <para>4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
+                the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)</para>
+            </simplesect>
+    </sect1>
     <sect1>
         <title>PostGIS 3.2.0beta3</title>
         <para>2021/12/04</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 3fc87904e..54e99c188 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -70,4 +70,5 @@ UPGRADEABLE_VERSIONS = \
 	3.2.0alpha1 \
 	3.2.0beta1 \
 	3.2.0beta2 \
-	3.2.0beta3
+	3.2.0beta3 \
+	3.2.0dev
Summary of changes:
 NEWS                               | 112 +++++++++++++++++++++--------------
 README.postgis                     |   4 +-
 Version.config                     |   2 +-
 doc/reference_editor.xml           |   1 +
 doc/release_notes.xml              | 116 +++++++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |   3 +-
 6 files changed, 192 insertions(+), 46 deletions(-)
hooks/post-receive
