[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0rc1-3-g4f7552e7e
Mon Dec 13 05:36:30 PST 2021
the project "PostGIS".
The branch, main has been updated
       via  4f7552e7eff77f23985c4833695ad9931a241a6d (commit)
      from  bc96772506ecc1ff7c1945491292e4ce21672755 (commit)
revisions in full, below.
commit 4f7552e7eff77f23985c4833695ad9931a241a6d
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Dec 13 14:34:48 2021 +0100
    run_test.pl support for interative shell (use `-` as testname)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index a7372b275..f5128262f 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -39,6 +39,9 @@ BEGIN {
 #  Run the <testname>.sql script
 #  Check output against <testname>_expected
+#  Use `-` as the testname to drop into an interactive shell
@@ -389,6 +392,16 @@ foreach $TEST (@ARGV)
 	my $TEST_OBJ_COUNT_POST;
 	my $TEST_START_TIME;
+	if ( "${TEST}" eq '-' )
+		print "-- Entering interactive shell --\n";
+		# TODO: add more variables?
+		my $cmd = "psql -q -v \"regdir=$REGDIR\"";
+		my $rv = system($cmd);
+		print "-- Moving on with tests, if any --\n";
+		next;
 	# catch a common mistake (strip trailing .sql)
 	$TEST =~ s/.sql$//;
Summary of changes:
 regress/run_test.pl | 13 +++++++++++++
 1 file changed, 13 insertions(+)
hooks/post-receive
