[postgis-tickets] [PostGIS] #5033: Breaking change in PostGIS 3.1 with introduction of gridSize
PostGIS trac at osgeo.org
Thu Dec 16 10:18:47 PST 2021
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.5
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by strk):
 There's still a pending issue: renamed functions (not drop) are left
 pointing to possibly unexisting library:
 # regress/run_test.pl --before-upgrade-script regress/hooks/hook-before-
 upgrade.sql  --extension --upgrade-path ${F}--3.2.0dev!
 regress/core/regress -v --nodrop
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION
 '2.5.6dev' SCHEMA public
 Upgrading from postgis 2.5.6dev
 Running before-upgrade-script regress/hooks/hook-before-upgrade.sql
 WARNING: postgis_extensions_upgrade() not available or functional in
 version 2.5.6dev. We'll use manual upgrade.
 Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
 TO '3.2.0dev'
 Packaging PostGIS Raster in 'postgis_reg' for later drop using: ALTER
 EXTENSION postgis UPDATE TO '3.2.0dev'
 Dropping PostGIS Raster in 'postgis_reg' using: CREATE EXTENSION
 postgis_raster VERSION '3.2.0dev' FROM unpackaged;
 PostgreSQL 12.7 (Ubuntu 12.7-0ubuntu0.20.10.1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 10.2.0-13ubuntu1) 10.2.0, 64-bit
   Postgis 3.2.0dev - (3.2.0rc1-11-g211893b3a) - 2021-10-18 22:13:19
   scripts 3.2.0dev 3.2.0rc1-11-g211893b3a
   GEOS: 3.11.0dev-CAPI-1.16.0
   PROJ: 7.1.0
 Running tests
  regress/core/regress .. failed (diff expected obtained:
 /tmp/pgis_reg/test_1_diff)
 --- regress/core/regress_expected       2021-07-01 12:48:31.374498018
 +0200
 +++ /tmp/pgis_reg/test_1_out    2021-12-16 19:16:10.970197463 +0100
 @@ -231,3 +231,8 @@
  314|676
  315|0
  316|t|LINESTRING(40 8.660254037844387,35 8.660254037844387)
 +unexpected
 probin|st_difference_deprecated_by_postgis_301:$libdir/postgis-2.5
 +unexpected
 probin|st_intersection_deprecated_by_postgis_301:$libdir/postgis-2.5
 +unexpected
 probin|st_subdivide_deprecated_by_postgis_301:$libdir/postgis-2.5
 +unexpected
 probin|st_symdifference_deprecated_by_postgis_301:$libdir/postgis-2.5
 +unexpected
 probin|st_unaryunion_deprecated_by_postgis_301:$libdir/postgis-2.5
 This may be a problem in production as the users's views might be just
 disfunctioning unless the old ones point to the same major version as the
 new ones (and we didn't change function name in the library).
 For the testcase it could be only fixed by adapting those views (either
 automatically or by the test itself, maybe upgrading against after having
 dropped the views)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5033#comment:9>
