[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-2-g80abad406
Fri Dec 17 19:34:42 PST 2021
the project "PostGIS".
       via  80abad4062b6bd38c47642b9419ceb449b8d27c1 (commit)
      from  dd0bbb8ccdab7ae9fa6a71688ca5fcf4e9f64f77 (commit)
revisions in full, below.
commit 80abad4062b6bd38c47642b9419ceb449b8d27c1
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Dec 17 22:34:34 2021 -0500
    Fix translation building and have make new dir for docs if it does not exist
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 761cd2bf5..28eb71868 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -19,6 +19,7 @@ POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
 POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
 POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 echo $PATH
@@ -70,7 +71,7 @@ cp html/images/* images
 make epub
 make -e chunked-html-web 2>&1 | tee -a doc-errors.log
-if [[ "$reference" == *"main"* ]]; then  #only do this for main branch because only main follows transifex
+if [[ "$reference" == *"master"* ]]; then  #only do this for master branch because only master follows transifex
   make update-pot
   make pull-tx
   make -C po/it_IT/ local-html
Summary of changes:
 ci/debbie/postgis_release_docs.sh | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
