[postgis-tickets] [PostGIS] #5033: Breaking change in PostGIS 3.1 with introduction of gridSize
PostGIS trac at osgeo.org
Sat Dec 18 15:20:04 PST 2021
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.5
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"a99a00ab73bca7aee7a7f2cd224cabce4aef8e93/git" a99a00a/git]:
 #!CommitTicketReference repository="git"
 revision="a99a00ab73bca7aee7a7f2cd224cabce4aef8e93"
 Allow upgrades in presence of views using deprecated functions
 Support adding a 'Replaces' comment above functions to improve upgrade
 When a function has a line like the following in in the comments
 above its signature:
   Replaces ST_Intersection(geometry, geometry) deprecated in 3.1.0
 The upgrade script will try to drop the deprecated functions and in case
 of failure leave them behind renamed with a
 _deprecated_by_postgis_<version>
 suffix, warns the user about such occurrence and gives her hints on
 how to fix.
 The postgis_full_version() will report presence of such deprecated
 functions as an "incomplete upgrade".
 References #5033 in master/main branch (3.3.0dev)
 Includes regression tests
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5033#comment:12>
