[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-55-ge797330
Wed Feb 3 22:08:02 PST 2021
the project "PostGIS".
       via  e7973308de3df4515c6456880e162040e285ee2b (commit)
      from  253e3930e379f2a2cc6edfa2d1dc1b3177543e71 (commit)
revisions in full, below.
commit e7973308de3df4515c6456880e162040e285ee2b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 3 22:07:53 2021 -0800
    Add doc ST_PointOnSurface see also ref
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 58f3747..482d85c 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1757,8 +1757,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
     <refentry id="ST_PointOnSurface">
       <refnamediv>
         <refname>ST_PointOnSurface</refname>
-        <refpurpose>Returns a point guaranteed to lie in a polygon, or on a geometry.</refpurpose>
+        <refpurpose>Computes a point guaranteed to lie in a polygon, or on a geometry.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -1777,14 +1776,14 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
         <para>Returns a <varname>POINT</varname> which is guaranteed to lie in the interior of a surface
         (POLYGON, MULTIPOLYGON, and CURVED POLYGON).
-        In PostGIS this function also works on non-surface geometries.
+        In PostGIS this function also works on line and point geometries.
         </para>
         <para>&sfs_compliant; s3.2.14.2 // s3.2.18.2</para>
         <para>&sqlmm_compliant; SQL-MM 3: 8.1.5, 9.5.6.
          The specifications define ST_PointOnSurface for surface geometries only.
          PostGIS extends the function to support all common geometry types.
-         Other databases (Oracle,DB II, ESRI SDE) seem to support this function only for surfaces.
+         Other databases (Oracle, DB2, ArcSDE) seem to support this function only for surfaces.
          SQL Server 2008 supports all common geometry types.</para>
         <para>&Z_support;</para>
       </refsection>
@@ -1796,32 +1795,27 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
  st_astext
  POINT(0 5)
-(1 row)
 SELECT ST_AsText(ST_PointOnSurface('LINESTRING(0 5, 0 10)'::geometry));
  st_astext
  POINT(0 5)
-(1 row)
 SELECT ST_AsText(ST_PointOnSurface('POLYGON((0 0, 0 5, 5 5, 5 0, 0 0))'::geometry));
    st_astext
  POINT(2.5 2.5)
-(1 row)
 SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING(0 5 1, 0 0 1, 0 10 2)')));
    st_asewkt
  POINT(0 0 1)
-(1 row)
 </programlisting>
       </refsection>
       <refsection>
         <title>See Also</title>
-        <para><xref linkend="ST_Centroid" /></para>
+        <para><xref linkend="ST_Centroid" />, <xref linkend="ST_MaximumInscribedCircle" /></para>
       </refsection>
     </refentry>
Summary of changes:
 doc/reference_processing.xml | 14 ++++----------
 1 file changed, 4 insertions(+), 10 deletions(-)
hooks/post-receive
