[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-10-g876c965
Tue Feb 9 15:37:29 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  876c965db4becd6355c77b6e82e05bd3fecb4045 (commit)
      from  0c0f2e4a51184d8f09efac2ef8656f22fad53eb5 (commit)
revisions in full, below.
commit 876c965db4becd6355c77b6e82e05bd3fecb4045
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 9 15:37:07 2021 -0800
    Add GitHub Actions config
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
new file mode 100644
index 0000000..b7e06b1
--- /dev/null
+++ b/.github/workflows/ci.yml
@@ -0,0 +1,59 @@
+# GitHub Actions for PostGIS
+# Paul Ramsey <pramsey at cleverelephant dot ca>
+name: "CI"
+on: [push, pull_request]
+jobs:
+  linux:
+    name: "CI"
+    strategy:
+      matrix:
+        ci:
+        # Use the last stable releases to run more tests
+        # - { tag: pg13-geos39-gdal31-proj71, mode: garden }
+        - { tag: pg13-geos38-gdal31-proj71, mode: tests }
+        - { tag: pg13-geos38-gdal31-proj71, mode: debug }
+        - { tag: pg13-geos38-gdal31-proj71, mode: coverage }
+        - { tag: pg13-geos38-gdal31-proj71, mode: usan_gcc }
+        # Run tests with different dependency combinations
+        # - { tag: latest, mode: tests }
+        - { tag: pg12-geos37-gdal30-proj611, mode: tests }
+        - { tag: pg11-geos37-gdal24-proj52, mode: tests }
+        - { tag: pg10-geos36-gdal23-proj49, mode: tests }
+        - { tag: pg96-geos36-gdal22-proj49, mode: tests }
+    runs-on: ubuntu-latest
+    steps:
+    # - name: 'Install Docker'
+    #   run: |
+    #     curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
+    #     sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
+    #     sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
+    - name: 'Check Out'
+      uses: actions/checkout at v2
+    - name: 'Prepare Image'
+      run: |
+        set -e
+        uname -a
+        echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
+        echo "FROM postgis/postgis-build-env:${{ matrix.ci.tag }}" > Dockerfile
+        echo "ADD --chown=postgres:postgres . /src/postgis" >> Dockerfile
+        echo "CMD bash ci/travis/run_${{ matrix.ci.mode }}.sh" >> Dockerfile
+        docker build -t pgtest .
+        ci_env=`bash .github/codecov_env.bash`
+    - name: 'Build & Test'
+      run: |
+        docker run $ci_env --name pgtest-${GITHUB_RUN_NUMBER} pgtest
+    - name: 'Clean Up Image'
+      if: ${{ success() }}
+      run: |
+        docker rm pgtest-${GITHUB_RUN_NUMBER}
Summary of changes:
 .github/workflows/ci.yml | 59 ++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 59 insertions(+)
 create mode 100644 .github/workflows/ci.yml
hooks/post-receive
