[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-91-gb0e380d
Thu Feb 18 03:47:16 PST 2021
the project "PostGIS".
       via  b0e380d3c1c9945ca570ff0b930d3cf0c0ced973 (commit)
       via  d412e4215f9445947fbde566bdd4ba7a07874ca1 (commit)
       via  67a2477245979c56001d2df1767c59d30ae25229 (commit)
       via  0d0f997dfff576837d0a043a955ed30d51affa95 (commit)
       via  80a031b4aeff275dc7f85cd289f3cd69851b987d (commit)
       via  c2c8f8f9a4e5ebb4884e356520d3c6e7c4c088bb (commit)
      from  86df398fcfced629460c0f03f8fb6691da405b26 (commit)
revisions in full, below.
commit b0e380d3c1c9945ca570ff0b930d3cf0c0ced973
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 18 10:07:21 2021 +0100
    Add check for all available tests to be enabled
    Adds a new check_tests_enabled.sh utility script.
    Adds a "check-tests-enabled" Makefile target using the script.
    Tags "check-tests-enabled" target as a dependency of "check" target.
diff --git a/GNUmakefile.in b/GNUmakefile.in
index a59fbab..3f98403 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -41,7 +41,7 @@ clean-local:
 # TODO: drop 'test' target..
 test: check
-check: check-no-trailing-blanks check-unit check-regress docs-check check-news
+check: check-no-trailing-blanks check-unit check-regress docs-check check-news check-tests-enabled
 staged-install: all
 	$(MAKE) -C regress staged-install
@@ -209,6 +209,9 @@ include regress/runtest.mk
 check-regress: staged-install check-regress-deps
+check-tests-enabled:
+	utils/check_tests_enabled.sh
 check-regress-deps:
 ifeq (@TOPOLOGY@,topology)
 	$(MAKE) -C topology/test $@
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
new file mode 100755
index 0000000..d29e46f
--- /dev/null
+++ b/utils/check_tests_enabled.sh
@@ -0,0 +1,55 @@
+#!/bin/sh
+usage() {
+  echo "Usage: $0"
+TMPDIR=/tmp/postgis_check_tests_enabled_$$
+mkdir -p ${TMPDIR}
+cleanup() {
+  #echo "Things are in ${TMPDIR}"
+  rm -rf ${TMPDIR}
+trap 'cleanup' EXIT
+# Usage: check_enabled <path-to-test.mk> [<subdir-containing-tests>]
+check_enabled() {
+  mk=$1
+  suffix=$2
+  bd=`dirname ${mk}`/${suffix}
+  #echo "MK file: ${mk}"
+  #echo "Suffix: ${suffix}"
+  #echo "Basedir: ${bd}"
+  grep 'topsrcdir)' ${mk} |
+      sed 's|.*topsrcdir)/||;s/ .*$//' |
+      sed 's|\\||' |
+      sed 's|\.sql\>||' > ${TMPDIR}/enabled_tests
+  find ${bd} -name '*.sql' |
+    sed 's|\.sql$||' > ${TMPDIR}/available_tests
+  MISSING=`grep -vf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
+  if test -n "${MISSING}"; then
+    echo "The following tests are available but not enabled in:"
+    echo "- ${mk}:"
+    echo "${MISSING}" | sed 's/^/  /'
+    ) >&2
+    return 1
+  else
+    echo "All tests enabled in ${mk}"
+    return 0
+  fi
+check_enabled topology/test/tests.mk regress &&
+check_enabled regress/loader/tests.mk &&
+check_enabled regress/dumper/tests.mk &&
+check_enabled sfcgal/regress/tests.mk &&
+check_enabled regress/core/tests.mk.in &&
+check_enabled raster/test/regress/tests.mk
commit d412e4215f9445947fbde566bdd4ba7a07874ca1
Date:   Thu Feb 18 11:55:12 2021 +0100
    Rewrite raster tests list in a simpler and machine readable way
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 39fb529..2f33bb7 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -11,121 +11,121 @@
 RASTER_TEST_FIRST = \
-	check_gdal \
-	load_outdb
+	$(topsrcdir)/raster/test/regress/check_gdal \
+	$(topsrcdir)/raster/test/regress/load_outdb
 RASTER_TEST_LAST = \
-	clean
+	$(topsrcdir)/raster/test/regress/clean
 RASTER_TEST_METADATA = \
-	check_raster_columns \
-	check_raster_overviews
+	$(topsrcdir)/raster/test/regress/check_raster_columns \
+	$(topsrcdir)/raster/test/regress/check_raster_overviews
 RASTER_TEST_IO = \
-	rt_io
+	$(topsrcdir)/raster/test/regress/rt_io
 RASTER_TEST_BASIC_FUNC = \
-	rt_bytea \
-	rt_wkb \
-	box3d \
-	rt_addband \
-	rt_band \
-	rt_tile
+	$(topsrcdir)/raster/test/regress/rt_bytea \
+	$(topsrcdir)/raster/test/regress/rt_wkb \
+	$(topsrcdir)/raster/test/regress/box3d \
+	$(topsrcdir)/raster/test/regress/rt_addband \
+	$(topsrcdir)/raster/test/regress/rt_band \
+	$(topsrcdir)/raster/test/regress/rt_tile
 RASTER_TEST_PROPS = \
-	rt_dimensions \
-	rt_scale \
-	rt_pixelsize \
-	rt_upperleft \
-	rt_rotation \
-	rt_georeference \
-	rt_set_properties \
-	rt_isempty \
-	rt_hasnoband \
-	rt_metadata \
-	rt_rastertoworldcoord \
-	rt_worldtorastercoord \
-	rt_convexhull \
-	rt_envelope
+	$(topsrcdir)/raster/test/regress/rt_dimensions \
+	$(topsrcdir)/raster/test/regress/rt_scale \
+	$(topsrcdir)/raster/test/regress/rt_pixelsize \
+	$(topsrcdir)/raster/test/regress/rt_upperleft \
+	$(topsrcdir)/raster/test/regress/rt_rotation \
+	$(topsrcdir)/raster/test/regress/rt_georeference \
+	$(topsrcdir)/raster/test/regress/rt_set_properties \
+	$(topsrcdir)/raster/test/regress/rt_isempty \
+	$(topsrcdir)/raster/test/regress/rt_hasnoband \
+	$(topsrcdir)/raster/test/regress/rt_metadata \
+	$(topsrcdir)/raster/test/regress/rt_rastertoworldcoord \
+	$(topsrcdir)/raster/test/regress/rt_worldtorastercoord \
+	$(topsrcdir)/raster/test/regress/rt_convexhull \
+	$(topsrcdir)/raster/test/regress/rt_envelope
 RASTER_TEST_BANDPROPS = \
-	rt_band_properties \
-	rt_set_band_properties \
-	rt_pixelaspolygons \
-	rt_pixelaspoints \
-	rt_pixelascentroids \
-	rt_setvalues_array \
-	rt_summarystats \
-	rt_count \
-	rt_histogram \
-	rt_quantile \
-	rt_valuecount \
-	rt_valuepercent \
-	rt_bandmetadata \
-	rt_pixelvalue \
-	rt_neighborhood \
-	rt_nearestvalue \
-	rt_pixelofvalue \
-	rt_polygon \
-	rt_setbandpath
+	$(topsrcdir)/raster/test/regress/rt_band_properties \
+	$(topsrcdir)/raster/test/regress/rt_set_band_properties \
+	$(topsrcdir)/raster/test/regress/rt_pixelaspolygons \
+	$(topsrcdir)/raster/test/regress/rt_pixelaspoints \
+	$(topsrcdir)/raster/test/regress/rt_pixelascentroids \
+	$(topsrcdir)/raster/test/regress/rt_setvalues_array \
+	$(topsrcdir)/raster/test/regress/rt_summarystats \
+	$(topsrcdir)/raster/test/regress/rt_count \
+	$(topsrcdir)/raster/test/regress/rt_histogram \
+	$(topsrcdir)/raster/test/regress/rt_quantile \
+	$(topsrcdir)/raster/test/regress/rt_valuecount \
+	$(topsrcdir)/raster/test/regress/rt_valuepercent \
+	$(topsrcdir)/raster/test/regress/rt_bandmetadata \
+	$(topsrcdir)/raster/test/regress/rt_pixelvalue \
+	$(topsrcdir)/raster/test/regress/rt_neighborhood \
+	$(topsrcdir)/raster/test/regress/rt_nearestvalue \
+	$(topsrcdir)/raster/test/regress/rt_pixelofvalue \
+	$(topsrcdir)/raster/test/regress/rt_polygon \
+	$(topsrcdir)/raster/test/regress/rt_setbandpath
 RASTER_TEST_UTILITY = \
-	rt_utility \
-	rt_fromgdalraster \
-	rt_asgdalraster \
-	rt_astiff \
-	rt_asjpeg \
-	rt_aspng \
-	rt_reclass \
-	rt_gdalwarp \
-	rt_asraster \
-	rt_dumpvalues \
-	rt_makeemptycoverage \
-	rt_createoverview
+	$(topsrcdir)/raster/test/regress/rt_utility \
+	$(topsrcdir)/raster/test/regress/rt_fromgdalraster \
+	$(topsrcdir)/raster/test/regress/rt_asgdalraster \
+	$(topsrcdir)/raster/test/regress/rt_astiff \
+	$(topsrcdir)/raster/test/regress/rt_asjpeg \
+	$(topsrcdir)/raster/test/regress/rt_aspng \
+	$(topsrcdir)/raster/test/regress/rt_reclass \
+	$(topsrcdir)/raster/test/regress/rt_gdalwarp \
+	$(topsrcdir)/raster/test/regress/rt_asraster \
+	$(topsrcdir)/raster/test/regress/rt_dumpvalues \
+	$(topsrcdir)/raster/test/regress/rt_makeemptycoverage \
+	$(topsrcdir)/raster/test/regress/rt_createoverview
 RASTER_TEST_MAPALGEBRA = \
-	rt_mapalgebraexpr \
-	rt_mapalgebrafct \
-	rt_mapalgebraexpr_2raster \
-	rt_mapalgebrafct_2raster \
-	rt_mapalgebrafctngb \
-	rt_mapalgebrafctngb_userfunc \
-	rt_intersection \
-	rt_clip \
-	rt_mapalgebra \
-	rt_mapalgebra_expr \
-	rt_mapalgebra_mask \
-	rt_union \
-	rt_invdistweight4ma \
-	rt_4ma \
-	rt_setvalues_geomval \
-	rt_elevation_functions \
-	rt_colormap \
-	rt_grayscale
+	$(topsrcdir)/raster/test/regress/rt_mapalgebraexpr \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebrafct \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebraexpr_2raster \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebrafct_2raster \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebrafctngb \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebrafctngb_userfunc \
+	$(topsrcdir)/raster/test/regress/rt_intersection \
+	$(topsrcdir)/raster/test/regress/rt_clip \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebra \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebra_expr \
+	$(topsrcdir)/raster/test/regress/rt_mapalgebra_mask \
+	$(topsrcdir)/raster/test/regress/rt_union \
+	$(topsrcdir)/raster/test/regress/rt_invdistweight4ma \
+	$(topsrcdir)/raster/test/regress/rt_4ma \
+	$(topsrcdir)/raster/test/regress/rt_setvalues_geomval \
+	$(topsrcdir)/raster/test/regress/rt_elevation_functions \
+	$(topsrcdir)/raster/test/regress/rt_colormap \
+	$(topsrcdir)/raster/test/regress/rt_grayscale
 RASTER_TEST_SREL = \
-	rt_gist_relationships \
-	rt_intersects \
-	rt_samealignment \
-	rt_geos_relationships \
-	rt_iscoveragetile
+	$(topsrcdir)/raster/test/regress/rt_gist_relationships \
+	$(topsrcdir)/raster/test/regress/rt_intersects \
+	$(topsrcdir)/raster/test/regress/rt_samealignment \
+	$(topsrcdir)/raster/test/regress/rt_geos_relationships \
+	$(topsrcdir)/raster/test/regress/rt_iscoveragetile
 RASTER_TEST_BUGS = \
-	bug_test_car5 \
-	permitted_gdal_drivers \
-	tickets
+	$(topsrcdir)/raster/test/regress/bug_test_car5 \
+	$(topsrcdir)/raster/test/regress/permitted_gdal_drivers \
+	$(topsrcdir)/raster/test/regress/tickets
 RASTER_TEST_LOADER = \
-	loader/Basic \
-	loader/Projected \
-	loader/BasicCopy \
-	loader/BasicFilename \
-	loader/BasicOutDB \
-	loader/Tiled10x10 \
-	loader/Tiled10x10Copy \
-	loader/Tiled8x8 \
-	loader/TiledAuto \
-	loader/TiledAutoSkipNoData
+	$(topsrcdir)/raster/test/regress/loader/Basic \
+	$(topsrcdir)/raster/test/regress/loader/Projected \
+	$(topsrcdir)/raster/test/regress/loader/BasicCopy \
+	$(topsrcdir)/raster/test/regress/loader/BasicFilename \
+	$(topsrcdir)/raster/test/regress/loader/BasicOutDB \
+	$(topsrcdir)/raster/test/regress/loader/Tiled10x10 \
+	$(topsrcdir)/raster/test/regress/loader/Tiled10x10Copy \
+	$(topsrcdir)/raster/test/regress/loader/Tiled8x8 \
+	$(topsrcdir)/raster/test/regress/loader/TiledAuto \
+	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData
 RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
@@ -135,4 +135,4 @@ RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_LOADER) \
 	$(RASTER_TEST_LAST)
-TESTS += $(patsubst %, $(topsrcdir)/raster/test/regress/%, $(RASTER_TESTS))
+TESTS += $(RASTER_TESTS)
commit 67a2477245979c56001d2df1767c59d30ae25229
Date:   Thu Feb 18 11:54:47 2021 +0100
    Enable geos_noop and wrapx core tests
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index db0e5c2..a0f50df 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -38,6 +38,7 @@ TESTS += \
 	$(topsrcdir)/regress/core/forcecurve \
 	$(topsrcdir)/regress/core/geography \
 	$(topsrcdir)/regress/core/geometric_median \
+  $(topsrcdir)/regress/core/geos_noop \
 	$(topsrcdir)/regress/core/hausdorff \
 	$(topsrcdir)/regress/core/in_geohash \
 	$(topsrcdir)/regress/core/in_gml \
@@ -117,7 +118,8 @@ TESTS += \
 	$(topsrcdir)/regress/core/minimum_clearance \
 	$(topsrcdir)/regress/core/oriented_envelope \
 	$(topsrcdir)/regress/core/point_coordinates \
-	$(topsrcdir)/regress/core/out_geojson
+	$(topsrcdir)/regress/core/out_geojson \
+  $(topsrcdir)/regress/core/wrapx
 # Slow slow tests
 TESTS_SLOW = \
commit 0d0f997dfff576837d0a043a955ed30d51affa95
Date:   Thu Feb 18 10:24:00 2021 +0100
    Enable getnodeedges topology test
    And fix expectations from it
diff --git a/topology/test/regress/getnodeedges_expected b/topology/test/regress/getnodeedges_expected
index 3bd2a10..ade79a0 100644
--- a/topology/test/regress/getnodeedges_expected
+++ b/topology/test/regress/getnodeedges_expected
@@ -1,9 +1,7 @@
-BEGIN
 t
 9
 22
 26
-COMMIT
 N1|1|1
 N1|2|-1
 N2|1|3
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 9ee5e63..fa4025f 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -26,6 +26,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/getedgebypoint.sql \
 	$(topsrcdir)/topology/test/regress/getfacebypoint.sql \
 	$(topsrcdir)/topology/test/regress/getnodebypoint.sql \
+	$(topsrcdir)/topology/test/regress/getnodeedges.sql \
 	$(topsrcdir)/topology/test/regress/getringedges.sql \
 	$(topsrcdir)/topology/test/regress/gettopogeomelements.sql \
 	$(topsrcdir)/topology/test/regress/gml.sql \
commit 80a031b4aeff275dc7f85cd289f3cd69851b987d
Date:   Thu Feb 18 10:23:13 2021 +0100
    Enable cleartopogeom topology test
    And fix it to play nicely with other tests
diff --git a/topology/test/regress/cleartopogeom.sql b/topology/test/regress/cleartopogeom.sql
index 6f27f76..e8d8c57 100644
--- a/topology/test/regress/cleartopogeom.sql
+++ b/topology/test/regress/cleartopogeom.sql
@@ -33,4 +33,5 @@ SELECT 'relation after', count(distinct topogeo_id)
  FROM city_data.relation
  WHERE layer_id = 1;
-select droptopology('city_data');
+select NULL FROM droptopology('city_data');
+DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/cleartopogeom_expected b/topology/test/regress/cleartopogeom_expected
index decc772..741f3ec 100644
--- a/topology/test/regress/cleartopogeom_expected
+++ b/topology/test/regress/cleartopogeom_expected
@@ -1,17 +1,12 @@
-BEGIN
 t
 9
 22
 26
-COMMIT
-BEGIN
 1
 2
 3
-COMMIT
 relation before|5
 feature before|P1|f
 feature during|P1|t
 feature after|P1|t
 relation after|4
-Topology 'city_data' dropped
index bdecb99..9ee5e63 100644
@@ -17,6 +17,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/addnode.sql \
 	$(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
 	$(topsrcdir)/topology/test/regress/copytopology.sql \
+	$(topsrcdir)/topology/test/regress/cleartopogeom.sql \
 	$(topsrcdir)/topology/test/regress/createtopogeom.sql \
 	$(topsrcdir)/topology/test/regress/createtopology.sql \
 	$(topsrcdir)/topology/test/regress/droptopogeometrycolumn.sql \
commit c2c8f8f9a4e5ebb4884e356520d3c6e7c4c088bb
Date:   Thu Feb 18 09:52:31 2021 +0100
    Enable the findtopology topology test
index f46097a..bdecb99 100644
@@ -21,6 +21,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/droptopology.sql \
+	$(topsrcdir)/topology/test/regress/findtopology.sql \
Summary of changes:
 GNUmakefile.in                               |   5 +-
 raster/test/regress/tests.mk                 | 188 +++++++++++++--------------
 regress/core/tests.mk.in                     |   4 +-
 topology/test/regress/cleartopogeom.sql      |   3 +-
 topology/test/regress/cleartopogeom_expected |   5 -
 topology/test/regress/getnodeedges_expected  |   2 -
 topology/test/tests.mk                       |   3 +
 utils/check_tests_enabled.sh                 |  55 ++++++++
 8 files changed, 161 insertions(+), 104 deletions(-)
 create mode 100755 utils/check_tests_enabled.sh
hooks/post-receive
