[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-98-ga39944c
Thu Feb 18 17:24:12 PST 2021
the project "PostGIS".
       via  a39944c37f1b1b6efa3e90c6f51f1d9f016d4f53 (commit)
       via  c2193edf12ecdb0c79a7bb84ab691f0e1d62a516 (commit)
      from  d17abd3bc43e3ba9521d66d6ea3676c92062734a (commit)
revisions in full, below.
commit a39944c37f1b1b6efa3e90c6f51f1d9f016d4f53
Merge: c2193ed d17abd3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Feb 18 17:24:04 2021 -0800
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit c2193edf12ecdb0c79a7bb84ab691f0e1d62a516
Date:   Thu Feb 18 17:23:56 2021 -0800
    Add in test that exercises lw_dist2d_distribute_fast, references #4720
diff --git a/liblwgeom/cunit/cu_measures.c b/liblwgeom/cunit/cu_measures.c
index 8867992..c590fa7 100644
--- a/liblwgeom/cunit/cu_measures.c
+++ b/liblwgeom/cunit/cu_measures.c
@@ -71,7 +71,6 @@ do_test_mindistance_tolerance(char *in1,
 	distance = distancef(lw1, lw2, 0.0);
 	lwgeom_free(lw1);
 	lwgeom_free(lw2);
 	if ( fabs(distance - expected_res) > accepted_error )
 		printf(msg1, distance, expected_res, line);
@@ -88,6 +87,8 @@ static void test_mindistance2d_tolerance(void)
 	double default_accepted_error = 0.00001;
 	double zero_accepted_error = 0.0;
 	** Simple case.
@@ -208,6 +209,12 @@ static void test_mindistance2d_tolerance(void)
 	DIST2DTEST("LINESTRING(0.5 1,0.5 3)", "MULTICURVE(CIRCULARSTRING(2 3,3 2,2 1,1 2,2 3),(0 0, 0 5))", 0.5, default_accepted_error);
+	** "Fast path" case
+	DIST2DTEST("LINESTRING(10 0,11 1,12 2,13 3,14 4,15 5,16 6)",
+		"LINESTRING(1 1.5,2 3,3 4.5,4 6,5 7.5,6 9)",
+		8.3205, default_accepted_error);
 static void
Summary of changes:
 liblwgeom/cunit/cu_measures.c | 9 ++++++++-
 1 file changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
