[postgis-tickets] [PostGIS] #4857: Large ST_Union makes PostgreSQL temporarily unrestartable
PostGIS trac at osgeo.org
Mon Feb 22 22:06:32 PST 2021
  Reporter:  grassick  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.2
 Component:  postgis   |    Version:  3.1.x
Resolution:            |   Keywords:
Comment (by komzpa):
 Hello grassick,
 Can you make sure your restart procedure actually calls fast shutdown and
 not smart shutdown? Most distros use smart shutdown and I believe it's
 default.
 If it is a fast shutdown it has to be indistinguishable for PostGIS from
 Ctrl-C unless there is an issue in Postgres itself not dispatching it
 properly.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4857#comment:13>
