[postgis-tickets] [PostGIS] #4823: Memory Leak in GEOS conversion with EMPTY
PostGIS trac at osgeo.org
Sun Jan 3 03:59:58 PST 2021
  Reporter:  pramsey  |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 3.1.1
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by strk):
 I see the crashing thing references #3579 - Paul you even found a GEOS
 reproducer there but then there's no link to a GEOS ticket about it. The
 CI is running
 GEOS: 3.6.4dev-CAPI-1.10.4 6775f76 - can you file a ticket there ? Maybe
 even add a link to it from #3579 :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4823#comment:4>
