[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-29-ge7cad4d
Mon Jan 4 09:05:43 PST 2021
the project "PostGIS".
       via  e7cad4d9bc798edfbf7f07650620c50ebca13d19 (commit)
      from  b12bd53ced640d9e62c93aaf356d26619b6f5409 (commit)
revisions in full, below.
commit e7cad4d9bc798edfbf7f07650620c50ebca13d19
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 4 09:05:40 2021 -0800
    Bump up GEOS test version
diff --git a/.travis.yml b/.travis.yml
index 71a34f5..f093fd6 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -5,16 +5,17 @@ language: c
 env:
   # Use the last stable release to run more tests
-  - tag=pg13-geos38-gdal31-proj71 mode=garden
-  - tag=pg13-geos38-gdal31-proj71 mode=tests
-  - tag=pg13-geos38-gdal31-proj71 mode=debug
-  - tag=pg13-geos38-gdal31-proj71 mode=coverage
-  - tag=pg13-geos38-gdal31-proj71 mode=usan_gcc
-  - tag=pg13-clang-geos38-gdal31-proj71 mode=usan_clang
-  - tag=pg13-geos38-gdal31-proj71 mode=nowagyu
+  - tag=pg13-geos39-gdal31-proj71 mode=garden
+  - tag=pg13-geos39-gdal31-proj71 mode=tests
+  - tag=pg13-geos39-gdal31-proj71 mode=debug
+  - tag=pg13-geos39-gdal31-proj71 mode=coverage
+  - tag=pg13-geos39-gdal31-proj71 mode=usan_gcc
+  - tag=pg13-clang-geos39-gdal31-proj71 mode=usan_clang
+  - tag=pg13-geos39-gdal31-proj71 mode=nowagyu
   # Run tests with different dependency combinations
   - tag=latest mode=tests
+  - tag=pg13-geos38-gdal31-proj71 mode=tests
   - tag=pg12-geos37-gdal30-proj611 mode=tests
   - tag=pg11-geos37-gdal24-proj52 mode=tests
   - tag=pg10-geos36-gdal23-proj49 mode=tests
Summary of changes:
 .travis.yml | 15 ++++++++-------
 1 file changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
