[postgis-tickets] [PostGIS] #4826: Geocoder gives goofy resutls for 1 Main St, Hanover, MA
PostGIS trac at osgeo.org
Tue Jan 5 05:38:14 PST 2021
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.1.1
 Component:  tiger geocoder  |    Version:  3.1.x
Resolution:                  |   Keywords:
Description changed by robe:
Old description:
> tiger geocoder as mentioned on IRC
> http://irclogs.geoapt.com/postgis/%23postgis.2021-01-05.log
> sorry for the repeat from last night, but if anyone's here and knows
> where I can look for an answer - my TIGER PostGIS setup is returning
> weird results? when I run geocode('1 Main St, Hanover, MA 02239') it
> returns a good result, but when I skip the zip code, it returns a result
> in Andover, which is obviously wrong even though the correct result does
> exist
> One observation is that Hanover is not in the place table, but is in the
> cousub table.
New description:
 12:42:06        turova:
 sorry for the repeat from last night, but if anyone's here and knows where
 I can look for an answer - my TIGER PostGIS setup is returning weird
 results? when I run geocode('1 Main St, Hanover, MA 02239') it returns a
 good result, but when I skip the zip code, it returns a result in Andover,
 which is obviously wrong even though the correct result does exist
 cousub table.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4826#comment:1>
