[postgis-tickets] [PostGIS] #4833: Compiling Postgis with Proj 8
PostGIS trac at osgeo.org
Sat Jan 23 13:54:59 PST 2021
  Reporter:  jgrocha                |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  low                    |  Milestone:  PostGIS 3.1.1
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:  autotools
Comment (by jgrocha):
 The patch is to fix configure.ac, not the generated configure script.
 $ cat configure.patch
 diff --git a/configure.ac b/configure.ac
 index 9ac7051bb..0e22e08c1 100644
 --- a/configure.ac
 +++ b/configure.ac
 @@ -902,7 +902,7 @@ AC_SUBST([PROJ_LDFLAGS])
  dnl Ensure we can link against libproj
  LIBS_SAVE="$LIBS"
  LIBS="$PROJ_LDFLAGS"
 -AC_CHECK_LIB([proj], [pj_get_release],
 +AC_CHECK_LIB([proj], [proj_create_from_wkt],
         [AC_MSG_ERROR([could not find libproj - you may need to specify
 the directory of a PROJ installation using --with-projdir])],
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4833#comment:2>
