[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-52-gdbd1425
Thu Jan 28 12:49:58 PST 2021
the project "PostGIS".
       via  dbd1425e11283d7c7b840e293073d336c6362b59 (commit)
       via  1815cbe641f7b97b6a3368932ec47c7c697dd4e0 (commit)
       via  7ff1d90703ddba72a05cca771ab344857aa43a26 (commit)
       via  671a878982550e3c590d642620a6621b52c230c7 (commit)
      from  5148c43e378628090098099f63b67297d573a4fe (commit)
revisions in full, below.
commit dbd1425e11283d7c7b840e293073d336c6362b59
Merge: 5148c43 1815cbe
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 28 12:49:47 2021 -0800
    Merge branch 'fidomax-patch-2'
commit 1815cbe641f7b97b6a3368932ec47c7c697dd4e0
Merge: 7ff1d90 5148c43
Date:   Thu Jan 28 12:48:03 2021 -0800
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 7ff1d90703ddba72a05cca771ab344857aa43a26
Merge: ebe9ec5 671a878
Date:   Thu Jan 28 12:47:11 2021 -0800
commit 671a878982550e3c590d642620a6621b52c230c7
Author: Maxim Kochetkov <adobegitler at gmail.com>
Date:   Thu Jan 28 08:12:57 2021 +0300
    Use pkg-config to get PROJ version if available
    In case of cross-compile AC_PROJ_VERSION([POSTGIS_PROJ_VERSION]) fails.
    So try to get version by pkg-config first
diff --git a/configure.ac b/configure.ac
index 9ac7051..077a615 100644
--- a/configure.ac
+++ b/configure.ac
@@ -864,6 +864,7 @@ elif test ! -z "$PKG_CONFIG"; then
 			PROJ_CPPFLAGS="$PROJ_CFLAGS"
 			PROJ_LDFLAGS="$PROJ_LIBS"
+			POSTGIS_PROJ_VERSION=`$PKG_CONFIG proj --modversion | sed 's/\([[0-9]]\).*\([[0-9]]\).*\([[0-9]]\)/\1\2/'`
 			PROJ_LDFLAGS="-lproj"
@@ -885,8 +886,10 @@ AC_CHECK_HEADER([proj_api.h],
-dnl Return the PROJ.4 version number
-AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
+dnl Return the PROJ.4 version number if not detected by pkg-config
+if test "x$POSTGIS_PROJ_VERSION" = "x"; then
+	AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
+fi
 AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ library version])
 AC_SUBST([POSTGIS_PROJ_VERSION])
 CPPFLAGS="$CPPFLAGS_SAVE"
Summary of changes:
 configure.ac | 7 +++++--
 1 file changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
