[postgis-tickets] [PostGIS] #4834: protobuf checking on berrie causing compile to fail
PostGIS trac at osgeo.org
Fri Jan 29 00:53:34 PST 2021
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.1.2
 Component:  buildbots  |    Version:  3.1.x
Resolution:             |   Keywords:
Comment (by Algunenano):
 This was changed in 3.1 to stop people from unknowingly building without
 MVT and Geobuf support because if failed "silently" (I mean, nobody would
 see it among hundreds of lines of similar text).
 You need to either have protobuf development files installed or explicitly
 disable it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4834#comment:1>
