[postgis-tickets] [PostGIS] #4940: Test all aggregates against window clause and add to garden tests especially raster
PostGIS trac at osgeo.org
Fri Jul 2 08:34:17 PDT 2021
especially raster
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.4
Component:  raster   |    Version:  2.5.x
 Keywords:           |
 As @Robin noted alot of the the raster aggs crash and so does geobuf when
 presented with an OVER() clause.
 as noted in #4916, #4770, #4724.#4916
 I had fixed his single example for #4724 but then when I went to put in
 tests for it and also just adding OVER() to existing tests, it still
 exploded so I reverted. I think this requires a more holistic solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4940>
