[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-266-gc909a66
Mon Jul 5 13:13:09 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  c909a660377709699f7a1529d990a00c2f276593 (commit)
       via  02d6ca3eb18d65c217dc484faf3d8d4e8a7928fe (commit)
      from  d60698ed1c566f98c5c41bcd1f9ba7d746734f95 (commit)
revisions in full, below.
commit c909a660377709699f7a1529d990a00c2f276593
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jul 5 22:11:08 2021 +0200
    Add face.mbr consistency check in ValidateTopology
    Closes #3276
diff --git a/NEWS b/NEWS
index e87d347..5cc7e53 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ PostGIS 3.2.0
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
  * Enhancements *
+  - #3276, ValidateTopology check for face's mbr (Sandro Santilli)
   - #4936, Bounding box limited ValidateTopology (Sandro Santilli)
   - #4933, Speed up topology building in presence of big faces (Sandro Santilli)
   - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
diff --git a/topology/test/invalid_topology.sql b/topology/test/invalid_topology.sql
index 1bcd260..0512ca4 100644
--- a/topology/test/invalid_topology.sql
+++ b/topology/test/invalid_topology.sql
@@ -150,7 +150,7 @@ INSERT INTO invalid_topology.edge VALUES(32, 4, 4, 31, -31, 12, 12,
 INSERT INTO invalid_topology.edge VALUES(33, 3, 3, 28, 28, 13, 13,
   '01020000000100000000000000000039400000000000804140');
--- Set face mbr based on referencing edges mbr
+-- Set face mbr based on referencing non-dangling edges
 UPDATE invalid_topology.face f
 SET mbr = (
   WITH env AS (
@@ -158,6 +158,7 @@ SET mbr = (
     FROM invalid_topology.edge e
     WHERE
       ( e.left_face = f.face_id OR e.right_face = f.face_id )
+      AND NOT e.left_face = e.right_face -- skip dangling
   SELECT ST_MakeEnvelope(st_xmin(env), st_ymin(env), st_xmax(env), st_ymax(env))
   FROM env
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index ffcf2b0..9a1b831 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -15,6 +15,8 @@ edge crosses edge|30|32
 edge start node geometry mis-match|30|4
 edge end node geometry mis-match|30|3
 face without edges|10|
+face has wrong mbr|3|
+face has wrong mbr|6|
 face has no rings|10|
 face within face|11|2
 face overlaps face|2|12
@@ -22,7 +24,9 @@ not-isolated node has not-null containing_face|4|
 edge not covered by both its side faces|27|
 edge not covered by both its side faces|28|
 edge not covered by both its side faces|30|
-#4936|missing_count|2
+#4936|missing_count|4
 #4936|missing|face has no rings|10|
+#4936|missing|face overlaps face|2|12
+#4936|missing|face within face|11|2
 #4936|missing|face without edges|10|
 Topology 'invalid_topology' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index bae374c..9156136 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1762,20 +1762,35 @@ BEGIN
   CREATE INDEX "face_check_bt" ON face_check (face_id);
   -- Scan the table looking for NULL geometries
-  RAISE DEBUG 'Checking for faces with no rings';
+  -- or geometries with wrong MBR consistency
+  RAISE DEBUG 'Checking faces';
   FOR rec IN
-    SELECT face_id FROM face_check
-    WHERE geom IS NULL OR ST_IsEmpty(geom)
+    SELECT * FROM face_check
   LOOP --{
-    -- Face missing !
-    retrec.error := 'face has no rings';
-    retrec.id1 := rec.face_id;
-    retrec.id2 := NULL;
-    RETURN NEXT retrec;
+    IF rec.geom IS NULL OR ST_IsEmpty(rec.geom)
+    THEN
+      -- Face missing !
+      retrec.error := 'face has no rings';
+      retrec.id1 := rec.face_id;
+      retrec.id2 := NULL;
+      RETURN NEXT retrec;
+    END IF;
+    IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.geom))
+    THEN
+      RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(rec.mbr), ST_AsEWKT(ST_Envelope(rec.geom));
+      -- Inconsistent MBR!
+      retrec.error := 'face has wrong mbr';
+    END IF;
   END LOOP; --}
   -- Scan the table looking for overlap or containment
-  -- TODO: also check for MBR consistency
+  -- TODO: do this check as part of the earlier loop
   RAISE DEBUG 'Checking for face-in-face';
   FOR rec IN
     SELECT
commit 02d6ca3eb18d65c217dc484faf3d8d4e8a7928fe
Date:   Fri Jul 2 00:46:34 2021 +0200
    ValidateTopology: improve speed of check for node's containing_face
index fcff96b..bae374c 100644
@@ -1828,8 +1828,8 @@ BEGIN
     FROM node n
     LEFT JOIN face_check f ON ( ST_Contains(f.geom, n.geom) )
     LEFT JOIN edge e ON (
-      ST_Equals(ST_StartPoint(e.geom), n.geom) OR
-      ST_Equals(ST_EndPoint(e.geom), n.geom)
+      e.start_node = n.node_id OR
+      e.end_node = n.node_id
     WHERE
      ( bbox IS NULL OR n.geom && bbox )
Summary of changes:
 NEWS                                          |  1 +
 topology/test/invalid_topology.sql            |  3 ++-
 topology/test/regress/legacy_invalid_expected |  6 ++++-
 topology/topology.sql.in                      | 37 +++++++++++++++++++--------
 4 files changed, 34 insertions(+), 13 deletions(-)
hooks/post-receive
