[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-267-gdf3d193
Mon Jul 5 13:26:05 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  df3d193fd137a82196c3afa1af1d37bb719cc756 (commit)
      from  c909a660377709699f7a1529d990a00c2f276593 (commit)
revisions in full, below.
commit df3d193fd137a82196c3afa1af1d37bb719cc756
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jul 5 22:25:16 2021 +0200
    Use a nested loop for face checks
    Simplifies code and improves the odds of using prepared geometries
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index 9a1b831..1cb4222 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -15,11 +15,11 @@ edge crosses edge|30|32
 edge start node geometry mis-match|30|4
 edge end node geometry mis-match|30|3
 face without edges|10|
+face within face|2|11
+face overlaps face|2|12
 face has wrong mbr|3|
 face has wrong mbr|6|
 face has no rings|10|
-face within face|11|2
-face overlaps face|2|12
 not-isolated node has not-null containing_face|4|
 edge not covered by both its side faces|27|
 edge not covered by both its side faces|28|
@@ -27,6 +27,6 @@ edge not covered by both its side faces|30|
 #4936|missing_count|4
 #4936|missing|face has no rings|10|
 #4936|missing|face overlaps face|2|12
-#4936|missing|face within face|11|2
+#4936|missing|face within face|2|11
 #4936|missing|face without edges|10|
 Topology 'invalid_topology' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 9156136..bb9e884 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1787,47 +1787,42 @@ BEGIN
       RETURN NEXT retrec;
     END IF;
-  END LOOP; --}
-  -- Scan the table looking for overlap or containment
-  -- TODO: do this check as part of the earlier loop
-  RAISE DEBUG 'Checking for face-in-face';
-  FOR rec IN
-    SELECT
-      f1.geom,
-      f1.face_id as id1,
-      f2.face_id as id2,
-      ST_Relate(f1.geom, f2.geom) as im
-    FROM
-      face_check f1,
-      face_check f2
-      WHERE f1.face_id < f2.face_id
-      AND f1.geom && f2.geom
-  LOOP --{
+    FOR rec2 IN
+      SELECT
+        geom,
+        face_id,
+        ST_Relate(rec.geom, geom) as im
+      FROM
+        face_check
+        WHERE face_id > rec.face_id
+        AND geom && rec.geom
+    LOOP --{
+      -- Face overlap
+      IF ST_RelateMatch(rec2.im, 'T*T***T**') THEN
+        retrec.error = 'face overlaps face';
+        retrec.id1 = rec.face_id;
+        retrec.id2 = rec2.face_id;
+        RETURN NEXT retrec;
+      END IF;
-    -- Face overlap
-    IF ST_RelateMatch(rec.im, 'T*T***T**') THEN
-    retrec.error = 'face overlaps face';
-    retrec.id1 = rec.id1;
-    retrec.id2 = rec.id2;
-    RETURN NEXT retrec;
-    END IF;
+      -- Face 1 is within face 2
+      IF ST_RelateMatch(rec2.im, 'T*F**F***') THEN
+        retrec.error = 'face within face';
+      END IF;
-    -- Face 1 is within face 2
-    IF ST_RelateMatch(rec.im, 'T*F**F***') THEN
-    retrec.error = 'face within face';
-    END IF;
+      -- Face 1 contains face 2
+      IF ST_RelateMatch(rec2.im, 'T*****FF*') THEN
+      END IF;
-    -- Face 1 contains face 2
-    IF ST_RelateMatch(rec.im, 'T*****FF*') THEN
-    retrec.id1 = rec.id2;
-    retrec.id2 = rec.id1;
-    END IF;
+    END LOOP; --}
   END LOOP; --}
Summary of changes:
 topology/test/regress/legacy_invalid_expected |  6 +--
 topology/topology.sql.in                      | 71 +++++++++++++--------------
 2 files changed, 36 insertions(+), 41 deletions(-)
hooks/post-receive
