[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-273-g02ae48a
Tue Jul 6 08:24:23 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  02ae48afb536bd302734fe8b342e312527f2d2f3 (commit)
      from  4c84d496cd2d545582cdb9c005c734c720c8b58e (commit)
revisions in full, below.
commit 02ae48afb536bd302734fe8b342e312527f2d2f3
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 6 17:22:20 2021 +0200
    Put ValidateTopology code in its own file
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 2d134ff..d6d5fea 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -125,6 +125,7 @@ topology.sql: \
 	sql/manage/FindLayer.sql.in \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
+	sql/manage/ValidateTopology.sql.in \
 	sql/topoelement/topoelement_agg.sql.in \
 	sql/topogeometry/type.sql.in \
 	sql/topogeometry/totopogeom.sql.in \
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
new file mode 100644
index 0000000..5bc19cb
--- /dev/null
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -0,0 +1,528 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2010, 2021 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2005 Refractions Research Inc.
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Author: Sandro Santilli <strk at kbt.io>
+-- Type returned by ValidateTopology
+CREATE TYPE topology.ValidateTopology_ReturnType AS (
+  error varchar,
+  id1 integer,
+  id2 integer
+--  ValidateTopology(toponame, [bbox])
+--  Return a Set of ValidateTopology_ReturnType containing
+--  informations on all topology inconsistencies
+-- Availability: 1.0.0
+-- Changed: 3.2.0 - add bbox optional parameter
+CREATE OR REPLACE FUNCTION topology.ValidateTopology(toponame varchar, bbox geometry DEFAULT NULL)
+  RETURNS setof topology.ValidateTopology_ReturnType
+AS
+DECLARE
+  retrec topology.ValidateTopology_ReturnType;
+  rec RECORD;
+  rec2 RECORD;
+  affected_rows integer;
+  invalid_edges integer[];
+  invalid_faces integer[];
+  search_path_backup text;
+BEGIN
+  IF NOT EXISTS (
+    SELECT oid
+    FROM pg_catalog.pg_namespace
+    WHERE nspname = toponame
+  THEN
+    RAISE EXCEPTION 'Topology schema % does not exist', toponame;
+  END IF;
+  IF NOT EXISTS (
+    SELECT id
+    FROM topology.topology
+    WHERE name = toponame
+  THEN
+    RAISE WARNING 'Topology % is not registered in topology.topology', toponame;
+  END IF;
+  EXECUTE 'SHOW search_path' INTO search_path_backup;
+  EXECUTE 'SET search_PATH TO ' || quote_ident(toponame) || ','
+                                || search_path_backup;
+  IF bbox IS NOT NULL THEN
+    RAISE DEBUG 'Limiting topology checking to bbox %', ST_AsEWKT(ST_Envelope(bbox));
+  END IF;
+  -- Check for coincident nodes
+  RAISE DEBUG 'Checking for coincident nodes';
+  FOR rec IN
+    SELECT a.node_id as id1, b.node_id as id2
+    FROM
+      node a,
+      node b
+    WHERE a.node_id < b.node_id
+    AND ST_DWithin(a.geom, b.geom, 0) -- NOTE: see #1625 and #1789
+    AND (
+      bbox IS NULL
+      OR (
+        a.geom && bbox
+        AND
+        b.geom && bbox
+  LOOP
+    retrec.error = 'coincident nodes';
+    retrec.id1 = rec.id1;
+    retrec.id2 = rec.id2;
+    RETURN NEXT retrec;
+  END LOOP;
+  -- Check for edge crossed nodes
+  -- TODO: do this in the single edge loop
+  RAISE DEBUG 'Checking for edges crossing nodes';
+  FOR rec IN
+    SELECT n.node_id as nid, e.edge_id as eid
+    FROM
+      node n,
+      edge e
+    WHERE e.start_node != n.node_id
+    AND e.end_node != n.node_id
+    AND ST_Within(n.geom, e.geom)
+    AND (
+      bbox IS NULL
+      OR (
+        n.geom && bbox
+        AND
+        e.geom && bbox
+  LOOP
+    retrec.error = 'edge crosses node';
+    retrec.id1 = rec.eid; -- edge_id
+    retrec.id2 = rec.nid; -- node_id
+  END LOOP;
+  -- Scan all edges
+  RAISE DEBUG 'Checking for invalid or not-simple edges';
+  FOR rec IN
+    SELECT e.geom, e.edge_id as id1, e.left_face, e.right_face
+    FROM edge e
+    WHERE (
+      bbox IS NULL
+      OR e.geom && bbox
+    ORDER BY edge_id
+  LOOP --{
+    -- Any invalid edge becomes a cancer for higher level complexes
+    IF NOT ST_IsValid(rec.geom) THEN
+      retrec.error = 'invalid edge';
+      retrec.id2 = NULL;
+      invalid_edges := array_append(invalid_edges, rec.id1);
+      IF invalid_faces IS NULL OR NOT rec.left_face = ANY ( invalid_faces )
+      THEN
+        invalid_faces := array_append(invalid_faces, rec.left_face);
+      END IF;
+      IF rec.right_face != rec.left_face AND ( invalid_faces IS NULL OR
+            NOT rec.right_face = ANY ( invalid_faces ) )
+      THEN
+        invalid_faces := array_append(invalid_faces, rec.right_face);
+      END IF;
+      CONTINUE;
+    END IF;
+    -- Check edge being simple (ie: not self-intersecting)
+    IF NOT ST_IsSimple(rec.geom) THEN
+      retrec.error = 'edge not simple';
+    END IF;
+  END LOOP; --}
+  -- Check for edge crossing
+  RAISE DEBUG 'Checking for crossing edges';
+  FOR rec IN
+    SELECT
+      e1.edge_id as id1,
+      e2.edge_id as id2,
+      e1.geom as g1,
+      e2.geom as g2,
+      ST_Relate(e1.geom, e2.geom) as im
+    FROM
+      edge e1,
+      edge e2
+    WHERE
+      e1.edge_id < e2.edge_id
+      AND e1.geom && e2.geom
+      AND (
+        invalid_edges IS NULL OR (
+          NOT e1.edge_id = ANY (invalid_edges)
+          AND
+          NOT e2.edge_id = ANY (invalid_edges)
+      AND (
+        bbox IS NULL
+        OR (
+          e1.geom && bbox
+          AND
+          e2.geom && bbox
+  LOOP --{
+    IF ST_RelateMatch(rec.im, 'FF1F**1*2') THEN
+      CONTINUE; -- no interior intersection
+    -- Closed lines have no boundary, so endpoint
+    -- intersection would be considered interior
+    -- See http://trac.osgeo.org/postgis/ticket/770
+    -- See also full explanation in topology.AddEdge
+    ELSIF ST_RelateMatch(rec.im, 'FF10F01F2') THEN
+      -- first line (g1) is open, second (g2) is closed
+      -- first boundary has puntual intersection with second interior
+      -- compute intersection, check it equals second endpoint
+      IF ST_Equals(ST_Intersection(rec.g2, rec.g1),
+                   ST_StartPoint(rec.g2))
+      THEN
+        CONTINUE;
+      END IF;
+    ELSIF ST_RelateMatch(rec.im, 'F01FFF102') THEN
+      -- second line (g2) is open, first (g1) is closed
+      -- second boundary has puntual intersection with first interior
+      -- compute intersection, check it equals first endpoint
+                   ST_StartPoint(rec.g1))
+      THEN
+        CONTINUE;
+      END IF;
+    ELSIF ST_RelateMatch(rec.im, '0F1FFF1F2') THEN
+      -- both lines are closed (boundary intersects nothing)
+      -- they have puntual intersection between interiors
+      -- compute intersection, check it's a single point
+      -- and equals first StartPoint _and_ second StartPoint
+      IF ST_Equals(ST_Intersection(rec.g1, rec.g2),
+                   ST_StartPoint(rec.g1)) AND
+         ST_Equals(ST_StartPoint(rec.g1), ST_StartPoint(rec.g2))
+      THEN
+        CONTINUE;
+      END IF;
+    END IF;
+    retrec.error = 'edge crosses edge';
+  END LOOP; --}
+  -- Check for edge start_node geometry mis-match
+  -- TODO: move this in the first edge table scan
+  RAISE DEBUG 'Checking for edges start_node mismatch';
+  FOR rec IN
+    SELECT e.edge_id as id1, n.node_id as id2
+    FROM
+      edge e,
+      node n
+    WHERE e.start_node = n.node_id
+    AND NOT ST_Equals(ST_StartPoint(e.geom), n.geom)
+    AND (
+      bbox IS NULL
+      OR e.geom && bbox
+  LOOP --{
+    retrec.error = 'edge start node geometry mis-match';
+  END LOOP; --}
+  -- Check for edge end_node geometry mis-match
+  RAISE DEBUG 'Checking for edges end_node mismatch';
+  FOR rec IN
+    FROM
+      edge e,
+      node n
+    WHERE e.end_node = n.node_id
+    AND NOT ST_Equals(ST_EndPoint(e.geom), n.geom)
+    AND (
+      bbox IS NULL
+      OR e.geom && bbox
+  LOOP --{
+    retrec.error = 'edge end node geometry mis-match';
+  END LOOP; --}
+  -- Check for faces w/out edges
+  RAISE DEBUG 'Checking for faces without edges';
+  FOR rec IN
+    SELECT face_id as id1
+    FROM face
+    WHERE face_id > 0
+    AND (
+      bbox IS NULL
+      OR mbr && bbox
+    EXCEPT (
+      SELECT left_face FROM edge
+      UNION
+      SELECT right_face FROM edge
+  LOOP --{
+    retrec.error = 'face without edges';
+  END LOOP; --}
+  -- Now create a temporary table to construct all face geometries
+  -- for checking their consistency
+  RAISE DEBUG 'Constructing geometry of all faces';
+  CREATE TEMP TABLE face_check ON COMMIT DROP AS
+  SELECT
+    face_id,
+    topology.ST_GetFaceGeometry(toponame, face_id) AS geom,
+    mbr
+  FROM
+    face
+  WHERE
+    face_id > 0
+    AND (
+      CASE WHEN invalid_faces IS NOT NULL THEN
+        NOT face_id = ANY(invalid_faces)
+      ELSE
+        TRUE
+      END
+    AND (
+      bbox IS NULL
+      OR mbr && bbox
+  -- Build a gist index on geom
+  CREATE INDEX "face_check_gist" ON face_check USING gist (geom);
+  -- Build a btree index on id
+  CREATE INDEX "face_check_bt" ON face_check (face_id);
+  -- Scan the table looking for NULL geometries
+  -- or geometries with wrong MBR consistency
+  RAISE DEBUG 'Checking faces';
+  affected_rows := 0;
+  FOR rec IN
+    SELECT * FROM face_check
+  LOOP --{
+    affected_rows := affected_rows + 1;
+    IF rec.geom IS NULL OR ST_IsEmpty(rec.geom)
+    THEN
+      -- Face missing !
+      retrec.error := 'face has no rings';
+      retrec.id1 := rec.face_id;
+      retrec.id2 := NULL;
+    END IF;
+    IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.geom))
+    THEN
+      RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(ST_Envelope(rec.geom)), ST_AsEWKT(ST_Envelope(rec.mbr));
+      -- Inconsistent MBR!
+      retrec.error := 'face has wrong mbr';
+    END IF;
+    FOR rec2 IN
+      SELECT
+        geom,
+        face_id,
+        ST_Relate(rec.geom, geom) as im
+      FROM
+        face_check
+        WHERE face_id > rec.face_id
+        AND geom && rec.geom
+    LOOP --{
+      -- Face overlap
+      IF ST_RelateMatch(rec2.im, 'T*T***T**') THEN
+        retrec.error = 'face overlaps face';
+        retrec.id1 = rec.face_id;
+        retrec.id2 = rec2.face_id;
+      END IF;
+      -- Face 1 is within face 2
+      IF ST_RelateMatch(rec2.im, 'T*F**F***') THEN
+        retrec.error = 'face within face';
+      END IF;
+      -- Face 1 contains face 2
+      IF ST_RelateMatch(rec2.im, 'T*****FF*') THEN
+      END IF;
+    END LOOP; --}
+  END LOOP; --}
+  RAISE DEBUG 'Checked % faces', affected_rows;
+  -- Check nodes have correct containing_face (#3233)
+  RAISE DEBUG 'Checking for node containing_face correctness';
+  FOR rec IN
+    SELECT
+      n.node_id,
+      -- in a corrupted topology multiple faces may contain the node
+      min(f.face_id) face_id,
+      -- multiple edges may contain the node
+      min(e.edge_id) edge_id
+    FROM node n
+    LEFT JOIN face_check f ON ( ST_Contains(f.geom, n.geom) )
+    LEFT JOIN edge e ON (
+      e.start_node = n.node_id OR
+      e.end_node = n.node_id
+    WHERE
+     ( bbox IS NULL OR n.geom && bbox )
+     AND (
+        e.edge_id IS NULL AND (
+          n.containing_face != f.face_id
+          OR ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
+      OR ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL)
+    GROUP BY n.node_id, n.containing_face
+  LOOP --{
+    IF rec.edge_id IS NOT NULL THEN
+      -- node is not really isolated
+      retrec.error := 'not-isolated node has not-null containing_face';
+    ELSE
+      retrec.error := 'isolated node has wrong containing_face';
+    END IF;
+    retrec.id1 := rec.node_id;
+    retrec.id2 := NULL; -- TODO: write expected containing_face here ?
+  END LOOP; --}
+  -- Check edges are covered by their left-right faces (#4831)
+  RAISE DEBUG 'Checking for edges coverage';
+  FOR rec IN
+    WITH edge_coverage AS (
+      SELECT
+        e.edge_id,
+        e.left_face,
+        e.right_face,
+        array_agg(COALESCE(f.face_id, 0)) covered_by
+      FROM
+        edge_data e
+        LEFT JOIN face_check f ON ( ST_Covers(f.geom, e.geom) )
+        -- skip invalid edges (toxic, and will be already reported previously)
+        WHERE
+            invalid_edges IS NULL OR NOT e.edge_id = ANY(invalid_edges)
+          AND
+            bbox IS NULL OR e.geom && bbox
+      GROUP BY
+        e.edge_id, e.left_face, e.right_face
+    SELECT
+       left_face = ANY(covered_by) left_face_covered,
+       right_face = ANY(covered_by) right_face_covered
+       from edge_coverage
+    WHERE
+      ( left_face != 0 AND NOT left_face = ANY(covered_by) )
+      OR
+      ( right_face != 0 AND NOT right_face = ANY(covered_by) )
+      OR
+      ( right_face = 0 AND left_face = 0 AND covered_by[1] != 0 )
+    ORDER BY edge_id
+  LOOP --{
+      retrec.id1 := rec.edge_id;
+      IF rec.left_face = 0 AND rec.right_face = 0 THEN
+        retrec.error := 'edge covered by some face has universal face on both sides';
+      ELSE
+        retrec.error := 'edge not covered by both its side faces';
+--        IF rec.left_face != 0 AND NOT rec.left_face_covered THEN
+--          retrec.error := 'edge not covered by its left face';
+--          RETURN NEXT retrec;
+--        END IF;
+--        IF rec.right_face != 0 AND NOT rec.right_face_covered THEN
+--          retrec.error := 'edge not covered by its right face';
+--        END IF;
+      END IF;
+  END LOOP; --}
+  DROP TABLE face_check;
+  EXECUTE 'SET search_PATH TO ' || search_path_backup;
+  RETURN;
+END
+LANGUAGE 'plpgsql' VOLATILE; -- NOTE: we need VOLATILE to use SHOW
+--} ValidateTopology(toponame, bbox)
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index e427691..d23f1dc 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -320,15 +320,6 @@ ON topology.layer FOR EACH ROW EXECUTE PROCEDURE topology.LayerTrigger();
 --} Layer table.
--- Type returned by ValidateTopology
-CREATE TYPE topology.ValidateTopology_ReturnType AS (
-  error varchar,
-  id1 integer,
-  id2 integer
 -- TopoGeometry type
 CREATE TYPE topology.TopoGeometry AS (
@@ -1438,509 +1429,6 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 CREATE CAST (topology.TopoGeometry AS Geometry) WITH FUNCTION topology.Geometry(topology.TopoGeometry) AS IMPLICIT;
---  ValidateTopology(toponame, [bbox])
---  Return a Set of ValidateTopology_ReturnType containing
---  informations on all topology inconsistencies
--- Availability: 1.0.0
--- Changed: 3.2.0 - add bbox optional parameter
-CREATE OR REPLACE FUNCTION topology.ValidateTopology(toponame varchar, bbox geometry DEFAULT NULL)
-  RETURNS setof topology.ValidateTopology_ReturnType
-AS
-DECLARE
-  retrec topology.ValidateTopology_ReturnType;
-  rec RECORD;
-  rec2 RECORD;
-  affected_rows integer;
-  invalid_edges integer[];
-  invalid_faces integer[];
-  search_path_backup text;
-BEGIN
-  IF NOT EXISTS (
-    SELECT oid
-    FROM pg_catalog.pg_namespace
-    WHERE nspname = toponame
-  THEN
-    RAISE EXCEPTION 'Topology schema % does not exist', toponame;
-  END IF;
-  IF NOT EXISTS (
-    SELECT id
-    FROM topology.topology
-    WHERE name = toponame
-  THEN
-    RAISE WARNING 'Topology % is not registered in topology.topology', toponame;
-  END IF;
-  EXECUTE 'SHOW search_path' INTO search_path_backup;
-  EXECUTE 'SET search_PATH TO ' || quote_ident(toponame) || ','
-                                || search_path_backup;
-  IF bbox IS NOT NULL THEN
-    RAISE DEBUG 'Limiting topology checking to bbox %', ST_AsEWKT(ST_Envelope(bbox));
-  END IF;
-  -- Check for coincident nodes
-  RAISE DEBUG 'Checking for coincident nodes';
-  FOR rec IN
-    SELECT a.node_id as id1, b.node_id as id2
-    FROM
-      node a,
-      node b
-    WHERE a.node_id < b.node_id
-    AND ST_DWithin(a.geom, b.geom, 0) -- NOTE: see #1625 and #1789
-    AND (
-      bbox IS NULL
-      OR (
-        a.geom && bbox
-        AND
-        b.geom && bbox
-  LOOP
-    retrec.error = 'coincident nodes';
-    retrec.id1 = rec.id1;
-    retrec.id2 = rec.id2;
-  END LOOP;
-  -- Check for edge crossed nodes
-  -- TODO: do this in the single edge loop
-  RAISE DEBUG 'Checking for edges crossing nodes';
-  FOR rec IN
-    SELECT n.node_id as nid, e.edge_id as eid
-    FROM
-      node n,
-      edge e
-    WHERE e.start_node != n.node_id
-    AND e.end_node != n.node_id
-    AND ST_Within(n.geom, e.geom)
-    AND (
-      bbox IS NULL
-      OR (
-        n.geom && bbox
-        AND
-        e.geom && bbox
-  LOOP
-    retrec.error = 'edge crosses node';
-    retrec.id1 = rec.eid; -- edge_id
-    retrec.id2 = rec.nid; -- node_id
-  END LOOP;
-  -- Scan all edges
-  RAISE DEBUG 'Checking for invalid or not-simple edges';
-  FOR rec IN
-    SELECT e.geom, e.edge_id as id1, e.left_face, e.right_face
-    FROM edge e
-    WHERE (
-      bbox IS NULL
-      OR e.geom && bbox
-    ORDER BY edge_id
-  LOOP --{
-    -- Any invalid edge becomes a cancer for higher level complexes
-    IF NOT ST_IsValid(rec.geom) THEN
-      retrec.error = 'invalid edge';
-      retrec.id2 = NULL;
-      invalid_edges := array_append(invalid_edges, rec.id1);
-      IF invalid_faces IS NULL OR NOT rec.left_face = ANY ( invalid_faces )
-      THEN
-        invalid_faces := array_append(invalid_faces, rec.left_face);
-      END IF;
-      IF rec.right_face != rec.left_face AND ( invalid_faces IS NULL OR
-            NOT rec.right_face = ANY ( invalid_faces ) )
-      THEN
-        invalid_faces := array_append(invalid_faces, rec.right_face);
-      END IF;
-      CONTINUE;
-    END IF;
-    -- Check edge being simple (ie: not self-intersecting)
-    IF NOT ST_IsSimple(rec.geom) THEN
-      retrec.error = 'edge not simple';
-    END IF;
-  END LOOP; --}
-  -- Check for edge crossing
-  RAISE DEBUG 'Checking for crossing edges';
-  FOR rec IN
-    SELECT
-      e1.edge_id as id1,
-      e2.edge_id as id2,
-      e1.geom as g1,
-      e2.geom as g2,
-      ST_Relate(e1.geom, e2.geom) as im
-    FROM
-      edge e1,
-      edge e2
-    WHERE
-      e1.edge_id < e2.edge_id
-      AND e1.geom && e2.geom
-      AND (
-        invalid_edges IS NULL OR (
-          NOT e1.edge_id = ANY (invalid_edges)
-          AND
-          NOT e2.edge_id = ANY (invalid_edges)
-      AND (
-        bbox IS NULL
-        OR (
-          e1.geom && bbox
-          AND
-          e2.geom && bbox
-  LOOP --{
-    IF ST_RelateMatch(rec.im, 'FF1F**1*2') THEN
-      CONTINUE; -- no interior intersection
-    -- Closed lines have no boundary, so endpoint
-    -- intersection would be considered interior
-    -- See http://trac.osgeo.org/postgis/ticket/770
-    -- See also full explanation in topology.AddEdge
-    ELSIF ST_RelateMatch(rec.im, 'FF10F01F2') THEN
-      -- first line (g1) is open, second (g2) is closed
-      -- first boundary has puntual intersection with second interior
-      -- compute intersection, check it equals second endpoint
-      IF ST_Equals(ST_Intersection(rec.g2, rec.g1),
-                   ST_StartPoint(rec.g2))
-      THEN
-        CONTINUE;
-      END IF;
-    ELSIF ST_RelateMatch(rec.im, 'F01FFF102') THEN
-      -- second line (g2) is open, first (g1) is closed
-      -- second boundary has puntual intersection with first interior
-      -- compute intersection, check it equals first endpoint
-                   ST_StartPoint(rec.g1))
-      THEN
-        CONTINUE;
-      END IF;
-    ELSIF ST_RelateMatch(rec.im, '0F1FFF1F2') THEN
-      -- both lines are closed (boundary intersects nothing)
-      -- they have puntual intersection between interiors
-      -- compute intersection, check it's a single point
-      -- and equals first StartPoint _and_ second StartPoint
-      IF ST_Equals(ST_Intersection(rec.g1, rec.g2),
-                   ST_StartPoint(rec.g1)) AND
-         ST_Equals(ST_StartPoint(rec.g1), ST_StartPoint(rec.g2))
-      THEN
-        CONTINUE;
-      END IF;
-    END IF;
-    retrec.error = 'edge crosses edge';
-  END LOOP; --}
-  -- Check for edge start_node geometry mis-match
-  -- TODO: move this in the first edge table scan
-  RAISE DEBUG 'Checking for edges start_node mismatch';
-  FOR rec IN
-    SELECT e.edge_id as id1, n.node_id as id2
-    FROM
-      edge e,
-      node n
-    WHERE e.start_node = n.node_id
-    AND NOT ST_Equals(ST_StartPoint(e.geom), n.geom)
-    AND (
-      bbox IS NULL
-      OR e.geom && bbox
-  LOOP --{
-    retrec.error = 'edge start node geometry mis-match';
-  END LOOP; --}
-  -- Check for edge end_node geometry mis-match
-  RAISE DEBUG 'Checking for edges end_node mismatch';
-  FOR rec IN
-    FROM
-      edge e,
-      node n
-    WHERE e.end_node = n.node_id
-    AND NOT ST_Equals(ST_EndPoint(e.geom), n.geom)
-    AND (
-      bbox IS NULL
-      OR e.geom && bbox
-  LOOP --{
-    retrec.error = 'edge end node geometry mis-match';
-  END LOOP; --}
-  -- Check for faces w/out edges
-  RAISE DEBUG 'Checking for faces without edges';
-  FOR rec IN
-    SELECT face_id as id1
-    FROM face
-    WHERE face_id > 0
-    AND (
-      bbox IS NULL
-      OR mbr && bbox
-    EXCEPT (
-      SELECT left_face FROM edge
-      UNION
-      SELECT right_face FROM edge
-  LOOP --{
-    retrec.error = 'face without edges';
-  END LOOP; --}
-  -- Now create a temporary table to construct all face geometries
-  -- for checking their consistency
-  RAISE DEBUG 'Constructing geometry of all faces';
-  CREATE TEMP TABLE face_check ON COMMIT DROP AS
-  SELECT
-    face_id,
-    topology.ST_GetFaceGeometry(toponame, face_id) AS geom,
-    mbr
-  FROM
-    face
-  WHERE
-    face_id > 0
-    AND (
-      CASE WHEN invalid_faces IS NOT NULL THEN
-        NOT face_id = ANY(invalid_faces)
-      ELSE
-        TRUE
-      END
-    AND (
-      bbox IS NULL
-      OR mbr && bbox
-  -- Build a gist index on geom
-  CREATE INDEX "face_check_gist" ON face_check USING gist (geom);
-  -- Build a btree index on id
-  CREATE INDEX "face_check_bt" ON face_check (face_id);
-  -- Scan the table looking for NULL geometries
-  -- or geometries with wrong MBR consistency
-  RAISE DEBUG 'Checking faces';
-  affected_rows := 0;
-  FOR rec IN
-    SELECT * FROM face_check
-  LOOP --{
-    affected_rows := affected_rows + 1;
-    IF rec.geom IS NULL OR ST_IsEmpty(rec.geom)
-    THEN
-      -- Face missing !
-      retrec.error := 'face has no rings';
-      retrec.id1 := rec.face_id;
-      retrec.id2 := NULL;
-    END IF;
-    IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.geom))
-    THEN
-      RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(ST_Envelope(rec.geom)), ST_AsEWKT(ST_Envelope(rec.mbr));
-      -- Inconsistent MBR!
-      retrec.error := 'face has wrong mbr';
-    END IF;
-    FOR rec2 IN
-      SELECT
-        geom,
-        face_id,
-        ST_Relate(rec.geom, geom) as im
-      FROM
-        face_check
-        WHERE face_id > rec.face_id
-        AND geom && rec.geom
-    LOOP --{
-      -- Face overlap
-      IF ST_RelateMatch(rec2.im, 'T*T***T**') THEN
-        retrec.error = 'face overlaps face';
-        retrec.id1 = rec.face_id;
-        retrec.id2 = rec2.face_id;
-      END IF;
-      -- Face 1 is within face 2
-      IF ST_RelateMatch(rec2.im, 'T*F**F***') THEN
-        retrec.error = 'face within face';
-      END IF;
-      -- Face 1 contains face 2
-      IF ST_RelateMatch(rec2.im, 'T*****FF*') THEN
-      END IF;
-    END LOOP; --}
-  END LOOP; --}
-  RAISE DEBUG 'Checked % faces', affected_rows;
-  -- Check nodes have correct containing_face (#3233)
-  RAISE DEBUG 'Checking for node containing_face correctness';
-  FOR rec IN
-    SELECT
-      n.node_id,
-      -- in a corrupted topology multiple faces may contain the node
-      min(f.face_id) face_id,
-      -- multiple edges may contain the node
-      min(e.edge_id) edge_id
-    FROM node n
-    LEFT JOIN face_check f ON ( ST_Contains(f.geom, n.geom) )
-    LEFT JOIN edge e ON (
-      e.start_node = n.node_id OR
-      e.end_node = n.node_id
-    WHERE
-     ( bbox IS NULL OR n.geom && bbox )
-     AND (
-        e.edge_id IS NULL AND (
-          n.containing_face != f.face_id
-          OR ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
-      OR ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL)
-    GROUP BY n.node_id, n.containing_face
-  LOOP --{
-    IF rec.edge_id IS NOT NULL THEN
-      -- node is not really isolated
-      retrec.error := 'not-isolated node has not-null containing_face';
-    ELSE
-      retrec.error := 'isolated node has wrong containing_face';
-    END IF;
-    retrec.id1 := rec.node_id;
-    retrec.id2 := NULL; -- TODO: write expected containing_face here ?
-  END LOOP; --}
-  -- Check edges are covered by their left-right faces (#4831)
-  RAISE DEBUG 'Checking for edges coverage';
-  FOR rec IN
-    WITH edge_coverage AS (
-      SELECT
-        e.edge_id,
-        e.left_face,
-        e.right_face,
-        array_agg(COALESCE(f.face_id, 0)) covered_by
-      FROM
-        edge_data e
-        LEFT JOIN face_check f ON ( ST_Covers(f.geom, e.geom) )
-        -- skip invalid edges (toxic, and will be already reported previously)
-        WHERE
-            invalid_edges IS NULL OR NOT e.edge_id = ANY(invalid_edges)
-          AND
-            bbox IS NULL OR e.geom && bbox
-      GROUP BY
-        e.edge_id, e.left_face, e.right_face
-    SELECT
-       left_face = ANY(covered_by) left_face_covered,
-       right_face = ANY(covered_by) right_face_covered
-       from edge_coverage
-    WHERE
-      ( left_face != 0 AND NOT left_face = ANY(covered_by) )
-      OR
-      ( right_face != 0 AND NOT right_face = ANY(covered_by) )
-      OR
-      ( right_face = 0 AND left_face = 0 AND covered_by[1] != 0 )
-    ORDER BY edge_id
-  LOOP --{
-      retrec.id1 := rec.edge_id;
-      IF rec.left_face = 0 AND rec.right_face = 0 THEN
-        retrec.error := 'edge covered by some face has universal face on both sides';
-      ELSE
-        retrec.error := 'edge not covered by both its side faces';
---        IF rec.left_face != 0 AND NOT rec.left_face_covered THEN
---          retrec.error := 'edge not covered by its left face';
---          RETURN NEXT retrec;
---        END IF;
---        IF rec.right_face != 0 AND NOT rec.right_face_covered THEN
---          retrec.error := 'edge not covered by its right face';
---        END IF;
-      END IF;
-  END LOOP; --}
-  DROP TABLE face_check;
-  EXECUTE 'SET search_PATH TO ' || search_path_backup;
-  RETURN;
-END
-LANGUAGE 'plpgsql' VOLATILE; -- NOTE: we need VOLATILE to use SHOW
---} ValidateTopology(toponame, bbox)
 --  CreateTopology(name, SRID, precision, hasZ)
 -- Create a topology schema, add a topology info record
@@ -2323,6 +1811,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/CopyTopology.sql.in"
 #include "sql/manage/FindTopology.sql.in"
 #include "sql/manage/FindLayer.sql.in"
+#include "sql/manage/ValidateTopology.sql.in"
 CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed() RETURNS text
Summary of changes:
 topology/Makefile.in                        |   1 +
 topology/sql/manage/ValidateTopology.sql.in | 528 ++++++++++++++++++++++++++++
 topology/topology.sql.in                    | 513 +--------------------------
 3 files changed, 530 insertions(+), 512 deletions(-)
 create mode 100644 topology/sql/manage/ValidateTopology.sql.in
hooks/post-receive
