[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-278-g68b17cd
Wed Jul 7 02:05:44 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  68b17cd25273008060ecba05bc210eec0e6deb19 (commit)
       via  0bfe9da85da27efd3b61e567ba7817f0e50da4b4 (commit)
      from  098c52a9c998b8d0b520c5b934f0389ea2acad6b (commit)
revisions in full, below.
commit 68b17cd25273008060ecba05bc210eec0e6deb19
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 6 23:48:49 2021 +0200
    Add edge linking validation to ValidateTopology
    Closes #3042
    Includes regression tests
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index bc45e6b..43ca7e3 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -23,6 +23,45 @@ CREATE TYPE topology.ValidateTopology_ReturnType AS (
   id2 integer
+CREATE OR REPLACE FUNCTION topology._CheckEdgeLinking(curedge ANYELEMENT, prevedge ANYELEMENT)
+RETURNS topology.ValidateTopology_ReturnType
+AS
+$BODY$
+DECLARE
+  retrec topology.ValidateTopology_ReturnType;
+BEGIN
+  IF prevedge.edge_id > 0
+  THEN -- previous was outgoing, this one should be next-right
+    IF prevedge.next_right_edge != curedge.edge_id THEN
+      RAISE DEBUG 'Edge % should be next-right of edge %, is % instead',
+        curedge.edge_id,
+        abs(prevedge.edge_id),
+        prevedge.next_right_edge
+      retrec.error = 'invalid next_right_edge';
+      retrec.id1 = abs(prevedge.edge_id);
+      retrec.id2 = curedge.edge_id; -- we put the expected one here, for convenience
+      RETURN retrec;
+    END IF;
+  ELSE -- previous was incoming, this one should be next-left
+    IF prevedge.next_left_edge != curedge.edge_id THEN
+      RAISE DEBUG 'Edge % should be next-left of edge %, is % instead',
+        curedge.edge_id,
+        prevedge.next_left_edge
+      retrec.error = 'invalid next_left_edge';
+      RETURN retrec;
+    END IF;
+  END IF;
+  RETURN retrec;
+END;
+$BODY$
+LANGUAGE 'plpgsql' IMMUTABLE STRICT;
 --  ValidateTopology(toponame, [bbox])
@@ -44,6 +83,9 @@ DECLARE
   invalid_edges integer[];
   invalid_faces integer[];
   search_path_backup text;
+  last_node_id int;
+  last_node_first_edge RECORD;
+  last_node_prev_edge RECORD;
 BEGIN
   IF NOT EXISTS (
@@ -318,6 +360,103 @@ BEGIN
     RETURN NEXT retrec;
   END LOOP; --}
+  RAISE DEBUG 'Checking edge linking';
+  -- NOTE: this check relies on correct start_node and end_node
+  --       for edges, if those are not correct the results
+  --       of this check do not make much sense.
+  FOR rec IN
+      WITH
+      nodes AS (
+        SELECT node_id
+        FROM node
+        WHERE containing_face IS NULL
+        AND (
+          bbox IS NULL
+          OR geom && bbox
+      incident_edges AS (
+        SELECT
+          n.node_id,
+          e.edge_id,
+          e.start_node,
+          e.end_node,
+          e.next_left_edge,
+          e.next_right_edge,
+          ST_RemoveRepeatedPoints(e.geom) as edge_geom
+        FROM edge_data e, nodes n
+        WHERE e.start_node = n.node_id
+        or e.end_node = n.node_id
+      edge_star AS (
+        SELECT
+          node_id,
+          edge_id,
+          next_left_edge,
+          next_right_edge,
+          ST_Azimuth(ST_StartPoint(edge_geom), ST_PointN(edge_geom, 2)) as az
+        FROM incident_edges
+        WHERE start_node = node_id
+          UNION ALL
+        SELECT
+          node_id,
+          -edge_id,
+          next_left_edge,
+          next_right_edge,
+          ST_Azimuth(ST_EndPoint(edge_geom), ST_PointN(edge_geom, ST_NumPoints(edge_geom)-1))
+        WHERE end_node = node_id
+      sequenced_edge_star AS (
+        SELECT
+          row_number() over (partition by node_id order by az, edge_id) seq,
+        FROM edge_star
+      SELECT * FROM sequenced_edge_star
+      ORDER BY node_id, seq
+  LOOP --{
+    IF last_node_id IS NULL OR last_node_id != rec.node_id
+    THEN --{
+      IF last_node_id IS NOT NULL
+      THEN
+        -- Check that last edge (CW from prev one) is correctly linked
+        retrec := topology._CheckEdgeLinking(last_node_first_edge, last_node_prev_edge);
+        IF retrec IS NOT NULL
+        THEN
+          RETURN NEXT retrec;
+        END IF;
+        --RAISE DEBUG 'Finished analisys of edge star around node %', last_node_id;
+      END IF;
+      --RAISE DEBUG 'Analyzing edge star around node %', rec.node_id;
+      last_node_id = rec.node_id;
+      last_node_first_edge = rec;
+    ELSE --{
+      -- Check that this edge (CW from last one) is correctly linked
+      retrec := topology._CheckEdgeLinking(rec, last_node_prev_edge);
+      THEN
+      END IF;
+    END IF; --}
+    last_node_prev_edge = rec;
+  END LOOP; --}
+  IF last_node_id IS NOT NULL THEN
+    --RAISE DEBUG 'Out of loop: last_node_id: %', last_node_id;
+    --RAISE DEBUG 'Out of loop: last_node_first_edge edge_id:% next_left_edge:%', last_node_first_edge.edge_id, last_node_first_edge.next_left_edge;
+    --RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
+    --RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
+    THEN
+    END IF;
+    --RAISE DEBUG 'Finished analisys of edge star around node % (out of loop)', last_node_id;
+  END IF;
   -- Now create a temporary table to construct all face geometries
   -- for checking their consistency
diff --git a/topology/test/regress/legacy_invalid.sql b/topology/test/regress/legacy_invalid.sql
index 4913451..7f4a972 100644
--- a/topology/test/regress/legacy_invalid.sql
+++ b/topology/test/regress/legacy_invalid.sql
@@ -4,8 +4,9 @@ set client_min_messages to WARNING;
 -- Validate full topology, store invalidities in a table
 CREATE TABLE invalid_topology.invalidities AS
-SELECT * from topology.validatetopology('invalid_topology');
-SELECT * FROM invalid_topology.invalidities;
+SELECT * FROM topology.validatetopology('invalid_topology');
+SELECT * FROM invalid_topology.invalidities
+ORDER BY 1,2,3;
 -- Test bbox-limited checking
 -- See https://trac.osgeo.org/postgis/ticket/4936
@@ -54,7 +55,7 @@ FROM invalid_topology.missing_invalidities ;
 SELECT '#4936', 'missing', *
-ORDER BY error ASC;
+ORDER BY 1, 2, 3 ASC;
 -- clean up
 SELECT topology.DropTopology('invalid_topology');
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index 1cb4222..c1e3b5c 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -1,9 +1,5 @@
 t
 coincident nodes|1|23
-edge crosses node|1|23
-edge crosses node|27|14
-edge not simple|28|
-invalid edge|33|
 edge crosses edge|2|28
 edge crosses edge|2|29
 edge crosses edge|2|32
@@ -12,18 +8,36 @@ edge crosses edge|10|27
 edge crosses edge|19|27
 edge crosses edge|20|27
 edge crosses edge|30|32
-edge start node geometry mis-match|30|4
+edge crosses node|1|23
+edge crosses node|27|14
 edge end node geometry mis-match|30|3
-face without edges|10|
-face within face|2|11
-face overlaps face|2|12
-face has wrong mbr|3|
-face has wrong mbr|6|
-face has no rings|10|
-not-isolated node has not-null containing_face|4|
 edge not covered by both its side faces|27|
 edge not covered by both its side faces|28|
 edge not covered by both its side faces|30|
+edge not simple|28|
+edge start node geometry mis-match|30|4
+face has no rings|10|
+face has wrong mbr|3|
+face has wrong mbr|6|
+face overlaps face|2|12
+face within face|2|11
+face without edges|10|
+invalid edge|33|
+invalid next_left_edge|2|3
+invalid next_left_edge|3|-29
+invalid next_left_edge|6|29
+invalid next_left_edge|18|-27
+invalid next_left_edge|27|10
+invalid next_left_edge|29|-33
+invalid next_left_edge|30|-3
+invalid next_left_edge|31|-28
+invalid next_left_edge|33|33
+invalid next_right_edge|9|27
+invalid next_right_edge|27|-22
+invalid next_right_edge|28|-30
+invalid next_right_edge|29|7
+invalid next_right_edge|33|31
+not-isolated node has not-null containing_face|4|
 #4936|missing_count|4
 #4936|missing|face has no rings|10|
 #4936|missing|face overlaps face|2|12
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index e869a1f..33a8b27 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -72,12 +72,6 @@ SELECT null from ( select TopoGeo_addLineString('t',
 ) al;
 SELECT '#4830.0', (ValidateTopology('t')).* UNION
 SELECT '#4830.0', '---', null, null ORDER BY 1,2,3,4;
--- 0. Set edge 1 self-linking to avoid "face with no rings"
---    invalidity.
-UPDATE t.edge_data SET
-  next_left_edge = 1,
-  next_right_edge = -1
-  WHERE edge_id = 1;
 -- 1. Set wrong left_face for dangling inside edges
 BEGIN;
 UPDATE t.edge_data SET left_face = 2
@@ -123,3 +117,24 @@ SELECT '#4830.5', (ValidateTopology('t')).* UNION
 SELECT '#4830.5', '---', null, null ORDER BY 1,2,3,4;
 ROLLBACK;
 SELECT null from ( select topology.DropTopology('t') ) as dt;
+-- Test correctness of edge linking
+-- See https://trac.osgeo.org/postgis/ticket/3042
+\i ../load_topology.sql
+--set client_min_messages to NOTICE;
+SELECT '#3042.0', * FROM ValidateTopology('city_data');
+BEGIN;
+-- Break edge linking for all edges around node 14
+UPDATE city_data.edge_data SET next_left_edge = -next_left_edge where edge_id in (9,10,20);
+UPDATE city_data.edge_data SET next_right_edge = -next_right_edge where edge_id = 19;
+-- Break edge linking of dangling edges, including one around last node (3)
+SET
+  next_left_edge = -next_left_edge,
+  next_right_edge = -next_right_edge
+where edge_id in (3,25);
+set client_min_messages to WARNING;
+SELECT '#3042.1', * FROM ValidateTopology('city_data');
+ROLLBACK;
+SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index c5254ab..b164c91 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -22,3 +22,11 @@
 #4830.4|edge not covered by both its side faces|8|
 #4830.5|---||
 #4830.5|edge covered by some face has universal face on both sides|9|
+#3042.1|invalid next_right_edge|3|2
+#3042.1|invalid next_left_edge|3|-3
+#3042.1|invalid next_right_edge|19|-10
+#3042.1|invalid next_left_edge|10|-20
+#3042.1|invalid next_left_edge|20|-9
+#3042.1|invalid next_left_edge|9|19
+#3042.1|invalid next_right_edge|25|25
+#3042.1|invalid next_left_edge|25|-25
commit 0bfe9da85da27efd3b61e567ba7817f0e50da4b4
Date:   Wed Jul 7 01:04:33 2021 +0200
    Fix reference to ticket about face coverage check
    NOTE: this is currently the slowest test in ValidateTopology
index 5bc19cb..bc45e6b 100644
@@ -460,7 +460,7 @@ BEGIN
     RETURN NEXT retrec;
   END LOOP; --}
-  -- Check edges are covered by their left-right faces (#4831)
+  -- Check edges are covered by their left-right faces (#4830)
   RAISE DEBUG 'Checking for edges coverage';
   FOR rec IN
     WITH edge_coverage AS (
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in     | 141 +++++++++++++++++++++++-
 topology/test/regress/legacy_invalid.sql        |   7 +-
 topology/test/regress/legacy_invalid_expected   |  38 +++++--
 topology/test/regress/validatetopology.sql      |  27 ++++-
 topology/test/regress/validatetopology_expected |   8 ++
 5 files changed, 199 insertions(+), 22 deletions(-)
hooks/post-receive
