[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-330-g54a0c74
Tue Jul 13 14:56:08 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  54a0c748dbb165847c1d0fe3abbe22dd48b8237a (commit)
      from  b564e095f367dc76d05c933da7a5d4a29f92822c (commit)
revisions in full, below.
commit 54a0c748dbb165847c1d0fe3abbe22dd48b8237a
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 13 23:54:53 2021 +0200
    Build shell rings using ad-hoc function
    Speeds up building outer ring for faces with many holes
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 4c14df4..c9cd13f 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -23,6 +23,100 @@ CREATE TYPE topology.ValidateTopology_ReturnType AS (
   id2 integer
+-- Return the exterior ring of a topology face
+CREATE OR REPLACE FUNCTION topology._ValidateTopologyGetFaceShell(atopology varchar, aface int)
+RETURNS GEOMETRY AS
+$BODY$
+DECLARE
+  sql TEXT;
+  outsidePoint GEOMETRY;
+  shell GEOMETRY;
+BEGIN
+  sql := format(
+      SELECT
+        ST_Translate(
+          ST_StartPoint( ST_BoundingDiagonal(mbr) ),
+          -1,
+          -1
+      FROM %1$I.face
+      WHERE face_id = $1
+    atopology
+  EXECUTE sql USING aface INTO outsidePoint;
+  sql := format(
+      WITH
+      outside_point AS (
+        SELECT ST_Translate(
+          -1,
+          -1
+        FROM %1$I.face
+      leftmost_edge AS (
+        SELECT
+          CASE WHEN left_face = $1
+          THEN
+            edge_id
+          ELSE
+            -edge_id
+          END ring_id
+        FROM %1$I.edge
+        WHERE left_face = $1 or right_face = $1
+        ORDER BY
+#if POSTGIS_PGSQL_VERSION < 95
+          ST_Distance(geom, $2)
+#else
+          geom <-> $2
+#endif
+        LIMIT 1
+      edgering AS (
+        SELECT *
+        FROM
+          GetRingEdges(
+            %1$L,
+            (SELECT ring_id FROM leftmost_edge)
+      SELECT
+        ST_MakeLine(
+          CASE WHEN r.edge > 0 THEN
+            e.geom
+          ELSE
+            ST_Reverse(e.geom)
+          END
+          ORDER BY r.sequence
+        ) outerRing
+      FROM edgering r, %1$I.edge e
+      WHERE e.edge_id = abs(r.edge)
+    atopology
+  --RAISE DEBUG 'SQL: %', sql;
+  EXECUTE sql USING aface, outsidePoint
+  INTO shell;
+  -- TODO: check if the ring is not closed
+  shell := ST_MakePolygon(shell);
+  RETURN shell;
+END;
+$BODY$ LANGUAGE 'plpgsql' STABLE; --}
 -- Assumes search_path has topology schema first
 CREATE OR REPLACE FUNCTION topology._ValidateTopologyGetRingEdges(starting_edge int)
@@ -837,14 +931,7 @@ BEGIN
   THEN --{
     INSERT INTO pg_temp.face_check
     SELECT face_id,
-      ST_MakePolygon(
-        ST_ExteriorRing(
-          topology.ST_GetFaceGeometry(
-            toponame,
-            face_id
+      topology._ValidateTopologyGetFaceShell(toponame, face_id),
       mbr
     FROM face
     WHERE mbr && bbox
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 103 +++++++++++++++++++++++++---
 1 file changed, 95 insertions(+), 8 deletions(-)
hooks/post-receive
