[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-334-g34382d4
Wed Jul 14 05:28:04 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  34382d44f9909c9775dab30499f2f57d856ab12a (commit)
      from  ba702a707c0fdbabf04ec309e2c294250ab82026 (commit)
revisions in full, below.
commit 34382d44f9909c9775dab30499f2f57d856ab12a
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 14 14:24:01 2021 +0200
    Fix toTopoGeom(TopoGeometry,TopoGeometry) return type
    References #4854 in main (3.2.0dev) branch
diff --git a/topology/sql/topogeometry/totopogeom.sql.in b/topology/sql/topogeometry/totopogeom.sql.in
index 2a26349..e5adede 100644
--- a/topology/sql/topogeometry/totopogeom.sql.in
+++ b/topology/sql/topogeometry/totopogeom.sql.in
@@ -204,7 +204,7 @@ BEGIN
         'Layer "%" of topology "%" is %, cannot hold a puntal feature.',
         layer_info.layer_id, topology_info.name, layer_info.typename;
     END IF;
-    tg.type := 1;
+    tg.type := CASE WHEN tg.type = 1 THEN 1 ELSE 4 END;
   ELSIF typ = 'LINESTRING' or typ = 'MULTILINESTRING' THEN -- lineal
     --  A line can go in lineal or collection layer
     IF layer_info.feature_type != 4 and layer_info.feature_type != 2 THEN
@@ -212,7 +212,7 @@ BEGIN
         'Layer "%" of topology "%" is %, cannot hold a lineal feature.',
     END IF;
-    tg.type := 2;
+    tg.type := CASE WHEN tg.type = 2 THEN 2 ELSE 4 END;
   ELSIF typ = 'POLYGON' OR typ = 'MULTIPOLYGON' THEN -- areal
     --  An area can go in areal or collection layer
     IF layer_info.feature_type != 4 and layer_info.feature_type != 3 THEN
@@ -220,7 +220,7 @@ BEGIN
         'Layer "%" of topology "%" is %, cannot hold an areal feature.',
     END IF;
-    tg.type := 3;
+    tg.type := CASE WHEN tg.type = 3 THEN 3 ELSE 4 END;
   ELSE
       -- Should never happen
       RAISE EXCEPTION
diff --git a/topology/test/regress/totopogeom.sql b/topology/test/regress/totopogeom.sql
index f72d58d..32b4a01 100644
--- a/topology/test/regress/totopogeom.sql
+++ b/topology/test/regress/totopogeom.sql
@@ -199,6 +199,132 @@ SELECT 'tgup1.3', id(t.g), st_area(t.g), count(r.*)
   WHERE t.id = -1 AND r.layer_id = 4 AND r.topogeo_id = id(t.g)
   GROUP BY id(t.g), st_area(t.g);
+-- Check GeometryType of TopoGeometries getting
+-- other TopoGeometry types added
+-- See https://trac.osgeo.org/postgis/ticket/4854
+BEGIN;
+SELECT '#4854.0.0', GeometryType(
+    toTopoGeom(
+      'POINT(0 0)', -- insert a point
+      toTopoGeom(
+        'POINT(10 0)', -- to a point TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.0.1', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'LINESTRING(0 0, 10 0)', -- to a linear TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.0.2', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'POLYGON((0 0,10 0,10 10,0 10,0 0))', -- to a polygonal TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.0.3', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'GEOMETRYCOLLECTION(POLYGON((0 0,10 0,10 10,0 10,0 0)),POINT(5 5))', -- to a collection TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.1.0', GeometryType(
+    toTopoGeom(
+      'LINESTRING(10 0, 20 0)', -- insert a line
+      toTopoGeom(
+        'POINT(0 0)', -- to a point TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.1.1', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'LINESTRING(0 0, 0 10)', -- to a line TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.1.2', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'POLYGON((0 0, 10 0,10 10,0 10,0 0))', -- to a polygonal TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.1.3', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(0 0, 10 0))', -- to a collection TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.2.0', GeometryType(
+    toTopoGeom(
+      'POLYGON((100 0,100 10,110 10,110 0, 100 0))', -- insert a polygon
+      toTopoGeom(
+        'POINT(100 1)', -- to a puntal TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.2.1', GeometryType(
+    toTopoGeom(
+      'POLYGON((-1 0,0 -2,1 0,-1 0))', -- insert a polygon
+      toTopoGeom(
+        'LINESTRING(200 1, 200 2)', -- to a lineal TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.2.2', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'POLYGON((200 1, 200 5,210 2,200 1))', -- to a polygon TopoGeom
+        'tt',
+        5
+      5)
+SELECT '#4854.2.3', GeometryType(
+    toTopoGeom(
+      toTopoGeom(
+        'GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(0 0,10 0))', -- to a collection TopoGeom
+        'tt',
+        5
+      5)
+ROLLBACK;
 -- http://trac.osgeo.org/postgis/ticket/3359
diff --git a/topology/test/regress/totopogeom_expected b/topology/test/regress/totopogeom_expected
index 6ba1e0a..b11747d 100644
--- a/topology/test/regress/totopogeom_expected
+++ b/topology/test/regress/totopogeom_expected
@@ -44,6 +44,18 @@ custom_search_path|0
 tgup1.1|5|100|1
 tgup1.2|5|200|2
 tgup1.3|5|200|4
+#4854.0.0|MULTIPOINT
+#4854.0.1|GEOMETRYCOLLECTION
+#4854.0.2|GEOMETRYCOLLECTION
+#4854.0.3|GEOMETRYCOLLECTION
+#4854.1.0|GEOMETRYCOLLECTION
+#4854.1.1|MULTILINESTRING
+#4854.1.2|GEOMETRYCOLLECTION
+#4854.1.3|GEOMETRYCOLLECTION
+#4854.2.0|GEOMETRYCOLLECTION
+#4854.2.1|GEOMETRYCOLLECTION
+#4854.2.2|MULTIPOLYGON
+#4854.2.3|GEOMETRYCOLLECTION
 #3359.setval|1|2|1
 #3359.line.1|1
 #3359.line.2|2
Summary of changes:
 topology/sql/topogeometry/totopogeom.sql.in |   6 +-
 topology/test/regress/totopogeom.sql        | 126 ++++++++++++++++++++++++++++
 topology/test/regress/totopogeom_expected   |  12 +++
 3 files changed, 141 insertions(+), 3 deletions(-)
hooks/post-receive
