[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-337-g6f37390
Wed Jul 14 09:46:41 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  6f373901c677b60f7f83236fcdd8345e653bb2e4 (commit)
      from  f2cd119bba43fdffd3ace23406d145ce914096a7 (commit)
revisions in full, below.
commit 6f373901c677b60f7f83236fcdd8345e653bb2e4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 14 09:46:35 2021 -0700
    Flip N/E systems to E/N and geodetic systems to Lon/Lat, while leaving Polar systems as-is, references #4949
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index b871898..4fa50dd 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -68,6 +68,10 @@
 #define FP_CONTAINS_EXCL(A, X, B) (FP_LT(A, X) && FP_LT(X, B))
 #define FP_CONTAINS(A, X, B) FP_CONTAINS_EXCL(A, X, B)
+#define STR_EQUALS(A, B) strcmp((A), (B)) == 0
+#define STR_IEQUALS(A, B) (strcasecmp((A), (B)) == 0)
+#define STR_ISTARTS(A, B) (strncasecmp((A), (B), strlen((B))) == 0)
 * this will change to NaN when I figure out how to
@@ -209,13 +213,13 @@ void ptarray_simplify_in_place(POINTARRAY *pa, double tolerance, uint32_t minpts
 * The possible ways a pair of segments can interact. Returned by lw_segment_intersects
 enum CG_SEGMENT_INTERSECTION_TYPE {
-    SEG_ERROR = -1,
-    SEG_NO_INTERSECTION = 0,
-    SEG_COLINEAR = 1,
-    SEG_CROSS_LEFT = 2,
-    SEG_CROSS_RIGHT = 3,
-    SEG_TOUCH_LEFT = 4,
-    SEG_TOUCH_RIGHT = 5
+		SEG_ERROR = -1,
+		SEG_NO_INTERSECTION = 0,
+		SEG_COLINEAR = 1,
+		SEG_CROSS_LEFT = 2,
+		SEG_CROSS_RIGHT = 3,
+		SEG_TOUCH_LEFT = 4,
+		SEG_TOUCH_RIGHT = 5
@@ -462,14 +466,14 @@ extern uint8_t MULTITYPE[NUMTYPES];
 extern lwinterrupt_callback *_lwgeom_interrupt_callback;
 extern int _lwgeom_interrupt_requested;
 #define LW_ON_INTERRUPT(x) { \
-  if ( _lwgeom_interrupt_callback ) { \
-    (*_lwgeom_interrupt_callback)(); \
-  if ( _lwgeom_interrupt_requested ) { \
-    _lwgeom_interrupt_requested = 0; \
-    lwnotice("liblwgeom code interrupted"); \
-    x; \
+	if ( _lwgeom_interrupt_callback ) { \
+		(*_lwgeom_interrupt_callback)(); \
+	if ( _lwgeom_interrupt_requested ) { \
+		_lwgeom_interrupt_requested = 0; \
+		lwnotice("liblwgeom code interrupted"); \
+		x; \
 int ptarray_npoints_in_rect(const POINTARRAY *pa, const GBOX *gbox);
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index d77d3ba..3bc3799 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -264,40 +264,56 @@ proj_cs_get_simplecs(const PJ *pj_crs)
 static uint8_t
 proj_crs_is_swapped(const PJ *pj_crs)
-	PJ *pj_cs;
-	uint8_t rv = LW_FALSE;
-	pj_cs = proj_cs_get_simplecs(pj_crs);
-	if (!pj_cs) {
+	int axis_count;
+	PJ *pj_cs = proj_cs_get_simplecs(pj_crs);
+	if (!pj_cs)
 		lwerror("%s: proj_cs_get_simplecs returned NULL", __func__);
-	int axis_count = proj_cs_get_axis_count(NULL, pj_cs);
-	if (axis_count > 0)
+	axis_count = proj_cs_get_axis_count(NULL, pj_cs);
+	if (axis_count >= 2)
-		const char *out_name, *out_abbrev, *out_direction;
-		double out_unit_conv_factor;
-		const char *out_unit_name, *out_unit_auth_name, *out_unit_code;
-		/* Read only first axis */
+		const char *out_name1, *out_abbrev1, *out_direction1;
+		const char *out_name2, *out_abbrev2, *out_direction2;
+		/* Read first axis */
 		proj_cs_get_axis_info(NULL,
-				      pj_cs,
-				      0,
-				      &out_name,
-				      &out_abbrev,
-				      &out_direction,
-				      &out_unit_conv_factor,
-				      &out_unit_name,
-				      &out_unit_auth_name,
-				      &out_unit_code);
-		/* Only swap Lat/Lon systems */
-		/* Use whatever ordering planar systems default to */
-		if (strcasecmp(out_abbrev, "Lat") == 0)
-			rv = LW_TRUE;
-		else
-			rv = LW_FALSE;
+			pj_cs, 0,
+			&out_name1, &out_abbrev1, &out_direction1,
+			NULL, NULL, NULL, NULL);
+		/* Read second axis */
+		proj_cs_get_axis_info(NULL,
+			pj_cs, 1,
+			&out_name2, &out_abbrev2, &out_direction2,
+		proj_destroy(pj_cs);
+		/* Directions agree, this is a northing/easting CRS, so reverse it */
+		if(out_direction1 && STR_IEQUALS(out_direction1, "north") &&
+		   out_direction2 && STR_IEQUALS(out_direction2, "east") )
+			return LW_TRUE;
+		/* Oddball case? Both axes north / both axes south, swap */
+		if(out_direction1 && out_direction2 &&
+		   ((STR_IEQUALS(out_direction1, "north") && STR_IEQUALS(out_direction2, "north")) ||
+		    (STR_IEQUALS(out_direction1, "south") && STR_IEQUALS(out_direction2, "south"))) &&
+		   out_name1 && STR_ISTARTS(out_name1, "northing")  &&
+		   out_name2 && STR_ISTARTS(out_name2, "easting"))
+			return LW_TRUE;
+		/* Any lat/lon system with Lat in first axis gets swapped */
+		if (STR_ISTARTS(out_abbrev1, "Lat"))
+			return LW_TRUE;
+		return LW_FALSE;
+	/* Failed the axis count test, leave quietly */
-	return rv;
+	return LW_FALSE;
 LWPROJ *
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 4269354..ff61797 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1368,3 +1368,25 @@ SELECT '#4863', st_contains(geometry, st_scale(st_orientedenvelope(geometry),
  6755713.77835553,-141972.789895508 6755731.24770785))'::geometry as
  geometry) x;
+-- New Zealand forward -- SRID=2193;POINT(1766289 5927325)
+SELECT '#4949', 'NZ forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(174.863597538742 -36.785298415230315)'::geometry, 2193),0.1));
+--- New Zealand inverse (opposite EPSG order) -- SRID=4326;POINT(174.863598 -36.785298)
+SELECT '#4949', 'NZ inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=2193;POINT(1766289 5927325)'::geometry, 4326),0.000001));
+-- British Columbia forward (respect EPSG order) -- SRID=3005;POINT(1286630.44 561883.98)
+SELECT '#4949', 'BC forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4269;POINT(-122 50)'::geometry, 3005),0.01));
+-- British Columbia inverse (respect EPSG order) -- SRID=4269;POINT(-122 50)
+SELECT '#4949', 'BC inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=3005;POINT(1286630.44 561883.98)'::geometry, 4269),0.000001));
+--  North Pole LAEA Europe inverse -- SRID=4326;POINT(19.4921659 69.7902258)
+SELECT '#4949', 'North Pole LAEA inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=3575;POINT(370182 -2213980)'::geometry,4326),0.0000001));
+-- Polar Stereographic forward -- SRID=3413;POINT(2218082.1 -1409150)
+SELECT '#4949', 'Arctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(12.572160  66.081084)'::geometry,3413),0.1));
+-- Antarctic Polar Stereographic -- SRID=3031;POINT(-2399498.7 3213318.5)
+SELECT '#4949', 'Antarctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(-36.75 -54.25)'::geometry, 3031),0.1));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 8f6ac27..b48ecff 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -445,3 +445,10 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4853|0
 #4844|SRID=4326;POINT(19.492 69.79)
 #4863|t
+#4949|NZ forward|SRID=2193;POINT(1766289 5927325)
+#4949|NZ inverse|SRID=4326;POINT(174.863598 -36.785298)
+#4949|BC forward|SRID=3005;POINT(1286630.44 561883.98)
+#4949|BC inverse|SRID=4269;POINT(-122 50)
+#4949|North Pole LAEA inverse|SRID=4326;POINT(19.4921659 69.7902258)
+#4949|Arctic Stereographic forward|SRID=3413;POINT(2218082.1 -1409150)
+#4949|Antarctic Stereographic forward|SRID=3031;POINT(-2399498.7 3213318.5)
Summary of changes:
 liblwgeom/liblwgeom_internal.h | 34 ++++++++++---------
 liblwgeom/lwgeom_transform.c   | 74 +++++++++++++++++++++++++-----------------
 regress/core/tickets.sql       | 22 +++++++++++++
 regress/core/tickets_expected  |  7 ++++
 4 files changed, 93 insertions(+), 44 deletions(-)
hooks/post-receive
