[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.3-23-g6a831ee
Wed Jul 14 10:12:27 PDT 2021
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  6a831ee189f6b4d763631695f82b226375f72018 (commit)
      from  27ae21c50959e85d5b2695174cb4fd4f767b0f76 (commit)
revisions in full, below.
commit 6a831ee189f6b4d763631695f82b226375f72018
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 14 10:12:21 2021 -0700
    Flip N/E systems to E/N and geodetic systems to Lon/Lat, while leaving Polar systems as-is, references #4949, 3.0 branch
diff --git a/NEWS b/NEWS
index 96a0b17..72e3fb2 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,7 @@ PostGIS 3.0.4dev
   - #4844, Repair axis order handling for polar coordinate systems (Paul Ramsey)
   - #4863, Update bboxes after scale/affine coordinate changes (Paul Ramsey)
   - #4918, Fix rare crash in st_minpossiblevalue() (Paul Ramsey)
+  - #4949, Swapped coordinates for N/E planar systems (Paul Ramsey)
 PostGIS 3.0.3
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index 49b7415..78672d8 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -261,42 +261,64 @@ proj_cs_get_simplecs(const PJ *pj_crs)
 	return NULL;
+#define STR_EQUALS(A, B) strcmp((A), (B)) == 0
+#define STR_IEQUALS(A, B) (strcasecmp((A), (B)) == 0)
+#define STR_ISTARTS(A, B) (strncasecmp((A), (B), strlen((B))) == 0)
 static uint8_t
 proj_crs_is_swapped(const PJ *pj_crs)
-	PJ *pj_cs;
-	uint8_t rv = LW_FALSE;
-	pj_cs = proj_cs_get_simplecs(pj_crs);
-	if (!pj_cs) {
-		lwerror("%s: proj_cs_get_simplecs returned NULL", __func__);
-	int axis_count = proj_cs_get_axis_count(NULL, pj_cs);
-	if (axis_count > 0)
-		const char *out_name, *out_abbrev, *out_direction;
-		double out_unit_conv_factor;
-		const char *out_unit_name, *out_unit_auth_name, *out_unit_code;
-		/* Read only first axis, see if it is degrees / north */
-		proj_cs_get_axis_info(NULL,
-				      pj_cs,
-				      0,
-				      &out_name,
-				      &out_abbrev,
-				      &out_direction,
-				      &out_unit_conv_factor,
-				      &out_unit_name,
-				      &out_unit_auth_name,
-				      &out_unit_code);
-		/* Only swap Lat/Lon systems */
-		/* Use whatever ordering planar systems default to */
-		if (strcasecmp(out_abbrev, "Lat") == 0)
-			rv = LW_TRUE;
-		else
-			rv = LW_FALSE;
-	proj_destroy(pj_cs);
-	return rv;
+    int axis_count;
+    PJ *pj_cs = proj_cs_get_simplecs(pj_crs);
+    if (!pj_cs)
+        lwerror("%s: proj_cs_get_simplecs returned NULL", __func__);
+    axis_count = proj_cs_get_axis_count(NULL, pj_cs);
+    if (axis_count >= 2)
+        const char *out_name1, *out_abbrev1, *out_direction1;
+        const char *out_name2, *out_abbrev2, *out_direction2;
+        /* Read first axis */
+        proj_cs_get_axis_info(NULL,
+            pj_cs, 0,
+            &out_name1, &out_abbrev1, &out_direction1,
+            NULL, NULL, NULL, NULL);
+        /* Read second axis */
+            pj_cs, 1,
+            &out_name2, &out_abbrev2, &out_direction2,
+        proj_destroy(pj_cs);
+        /* Directions agree, this is a northing/easting CRS, so reverse it */
+        if(out_direction1 && STR_IEQUALS(out_direction1, "north") &&
+           out_direction2 && STR_IEQUALS(out_direction2, "east") )
+            return LW_TRUE;
+        /* Oddball case? Both axes north / both axes south, swap */
+        if(out_direction1 && out_direction2 &&
+           ((STR_IEQUALS(out_direction1, "north") && STR_IEQUALS(out_direction2, "north")) ||
+            (STR_IEQUALS(out_direction1, "south") && STR_IEQUALS(out_direction2, "south"))) &&
+           out_name1 && STR_ISTARTS(out_name1, "northing")  &&
+           out_name2 && STR_ISTARTS(out_name2, "easting"))
+            return LW_TRUE;
+        /* Any lat/lon system with Lat in first axis gets swapped */
+        if (STR_ISTARTS(out_abbrev1, "Lat"))
+            return LW_TRUE;
+        return LW_FALSE;
+    /* Failed the axis count test, leave quietly */
+    return LW_FALSE;
 LWPROJ *
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 267adfd..9b44624 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1334,3 +1334,25 @@ SELECT '#4863', st_contains(geometry, st_scale(st_orientedenvelope(geometry),
  6755733.56891884,-141934.403428904 6755716.1146343,-141971.698204552
  6755713.77835553,-141972.789895508 6755731.24770785))'::geometry as
  geometry) x;
+-- New Zealand forward -- SRID=2193;POINT(1766289 5927325)
+SELECT '#4949', 'NZ forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(174.863597538742 -36.785298415230315)'::geometry, 2193),0.1));
+--- New Zealand inverse (opposite EPSG order) -- SRID=4326;POINT(174.863598 -36.785298)
+SELECT '#4949', 'NZ inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=2193;POINT(1766289 5927325)'::geometry, 4326),0.000001));
+-- British Columbia forward (respect EPSG order) -- SRID=3005;POINT(1286630.44 561883.98)
+SELECT '#4949', 'BC forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4269;POINT(-122 50)'::geometry, 3005),0.01));
+-- British Columbia inverse (respect EPSG order) -- SRID=4269;POINT(-122 50)
+SELECT '#4949', 'BC inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=3005;POINT(1286630.44 561883.98)'::geometry, 4269),0.000001));
+--  North Pole LAEA Europe inverse -- SRID=4326;POINT(19.4921659 69.7902258)
+SELECT '#4949', 'North Pole LAEA inverse', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=3575;POINT(370182 -2213980)'::geometry,4326),0.0000001));
+-- Polar Stereographic forward -- SRID=3413;POINT(2218082.1 -1409150)
+SELECT '#4949', 'Arctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(12.572160  66.081084)'::geometry,3413),0.1));
+-- Antarctic Polar Stereographic -- SRID=3031;POINT(-2399498.7 3213318.5)
+SELECT '#4949', 'Antarctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
+  'SRID=4326;POINT(-36.75 -54.25)'::geometry, 3031),0.1));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f3ff300..9641025 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -441,3 +441,10 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4853|0
 #4844|SRID=4326;POINT(19.49 69.79)
 #4863|t
+#4949|NZ forward|SRID=2193;POINT(1766289 5927325)
+#4949|NZ inverse|SRID=4326;POINT(174.863598 -36.785298)
+#4949|BC forward|SRID=3005;POINT(1286630.44 561883.98)
+#4949|BC inverse|SRID=4269;POINT(-122 50)
+#4949|North Pole LAEA inverse|SRID=4326;POINT(19.4921659 69.7902258)
+#4949|Arctic Stereographic forward|SRID=3413;POINT(2218082.1 -1409150)
+#4949|Antarctic Stereographic forward|SRID=3031;POINT(-2399498.7 3213318.5)
Summary of changes:
 NEWS                          |  1 +
 liblwgeom/lwgeom_transform.c  | 88 +++++++++++++++++++++++++++----------------
 regress/core/tickets.sql      | 22 +++++++++++
 regress/core/tickets_expected |  7 ++++
 4 files changed, 85 insertions(+), 33 deletions(-)
hooks/post-receive
