[postgis-tickets] [PostGIS] #3239: ST_{Mod, New}EdgeHeal does not check for TopoGeometry defined by removed node
PostGIS trac at osgeo.org
Wed Jul 14 14:51:38 PDT 2021
#3239: ST_{Mod,New}EdgeHeal does not check for TopoGeometry defined by removed
node
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.2.0
 Component:  topology     |    Version:  2.1.x
Resolution:  fixed        |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"168f3f431a9349d83728e7623f9388362eb6e169/git" 168f3f4/git]:
 #!CommitTicketReference repository="git"
 revision="168f3f431a9349d83728e7623f9388362eb6e169"
 Prevent removing isolated node used in TopoGeometry definition
 Closes #3239 in main branch (3.2.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3239#comment:16>
