[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-350-gea18ecd
Thu Jul 15 06:07:58 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  ea18ecdda1e907490048167cb013ea82c2160f8d (commit)
      from  40b8e63bdb055547d695727bc5c5df57f41c7d4d (commit)
revisions in full, below.
commit ea18ecdda1e907490048167cb013ea82c2160f8d
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 15 14:53:14 2021 +0200
    Prevent moving an isolated node to different face
    Closes #3232 in main branch (3.2.0dev)
    Includes regression test, moving existing
    tests from sqlmm to ad-hoc file
diff --git a/NEWS b/NEWS
index 3d22927..53c8234 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostGIS 3.2.0
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
  * Enhancements *
+  - #3232, Prevent moving an isolated node to different face
+           (Sandro Santilli)
   - Consider collection TopoGeometries while editing topology primitives.
            (Sandro Santilli)
   - #3248, Prevent removing isolated edges if used in a TopoGeometry
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 51c4639..8b7e2cd 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -3611,6 +3611,7 @@ lwt_MoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid, LWPOINT *pt)
   LWT_ISO_NODE *node;
   int ret;
+  int newPointFace;
   node = _lwt_GetIsoNode( topo, nid );
   if ( ! node ) return -1;
@@ -3629,9 +3630,19 @@ lwt_MoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid, LWPOINT *pt)
     return -1;
-  /* TODO: check that the new point is in the same containing face !
-   * See https://trac.osgeo.org/postgis/ticket/3232
+  /* Check that the new point is in the same containing face !
+   * See https://trac.osgeo.org/postgis/ticket/3232 */
+  newPointFace = lwt_be_getFaceContainingPoint(topo, pt);
+  if ( newPointFace == -1 ) {
+    lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
+    return -1;
+  if ( node->containing_face != newPointFace )
+    lwfree(node);
+    lwerror("Cannot move isolated node across faces");
+    return -1;
   node->node_id = nid;
   node->geom = pt;
diff --git a/topology/test/regress/sqlmm.sql b/topology/test/regress/sqlmm.sql
index ec2881a..c42fa37 100644
--- a/topology/test/regress/sqlmm.sql
+++ b/topology/test/regress/sqlmm.sql
@@ -96,28 +96,6 @@ SELECT '-- ST_AddIsoNode(2) ------------------------';
 -- ST_AddIsoNode edge-crossing node
 SELECT topology.ST_AddIsoNode('sqlmm_topology', NULL, 'POINT(5 9.5)');
--- ST_MoveIsoNode
-SELECT '-- ST_MoveIsoNode  ------------------------';
--- Isolated node to invalid location (coincident)
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 8, 'POINT(5 10)');
--- Isolated node to invalid location (edge-crossing)
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 8, 'POINT(5 9)');
--- Non isolated node (is used by an edge);
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 4, 'POINT(5 4)');
--- Invalid point
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 2, 'MULTIPOINT(5 4)');
--- Valid move
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 8, 'POINT(7 11)');
-SELECT topology.ST_MoveIsoNode('sqlmm_topology', 8, 'POINT(7 10)');
 -- ST_RemoveIsoEdge
diff --git a/topology/test/regress/sqlmm_expected b/topology/test/regress/sqlmm_expected
index 0b22ddc..e62599a 100644
--- a/topology/test/regress/sqlmm_expected
+++ b/topology/test/regress/sqlmm_expected
@@ -36,13 +36,6 @@ ERROR:  SQL/MM Spatial exception - not isolated node
 ERROR:  SQL/MM Spatial exception - edge crosses node.
--- ST_MoveIsoNode  ------------------------
-ERROR:  SQL/MM Spatial exception - coincident node
-ERROR:  SQL/MM Spatial exception - edge crosses node.
-ERROR:  SQL/MM Spatial exception - not isolated node
-ERROR:  SQL/MM Spatial exception - invalid point
-Isolated Node 8 moved to location 7,11
-Isolated Node 8 moved to location 7,10
 -- ST_RemoveIsoEdge ---------------------
 #3351.1|4|
 #3351.1|5|
diff --git a/topology/test/regress/st_moveisonode.sql b/topology/test/regress/st_moveisonode.sql
new file mode 100644
index 0000000..feb544f
--- /dev/null
+++ b/topology/test/regress/st_moveisonode.sql
@@ -0,0 +1,31 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+-- Import city_data
+\i ../load_topology.sql
+-- Isolated node to invalid location (coincident)
+SELECT 'coincident_node', topology.ST_MoveIsoNode('city_data', 4, 'POINT(25 35)');
+-- Isolated node to invalid location (edge-crossing)
+SELECT 'edge-crossing', topology.ST_MoveIsoNode('city_data', 4, 'POINT(20 40)');
+-- Non isolated node (is used by an edge);
+SELECT 'not-isolated', topology.ST_MoveIsoNode('city_data', 3, 'POINT(25 36)');
+-- Invalid point
+SELECT 'invalid-new-point', topology.ST_MoveIsoNode('city_data', 4, 'MULTIPOINT(5 4)');
+-- Move outside of original containing face (universal)
+SELECT 'change-face-to-universal', topology.ST_MoveIsoNode('city_data', 4, 'POINT(20 41)');
+SELECT 'change-face-to-other', topology.ST_MoveIsoNode('city_data', 4, 'POINT(15 37)');
+-- Valid move
+SELECT topology.ST_MoveIsoNode('city_data', 4, 'POINT(21 37)');
+SELECT topology.ST_MoveIsoNode('city_data', 4, 'POINT(19 37)');
+-- TODO: test moving the node in a different face (#3232)
+-- Cleanup
+SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/st_moveisonode_expected b/topology/test/regress/st_moveisonode_expected
index 0000000..f5091cd
--- /dev/null
+++ b/topology/test/regress/st_moveisonode_expected
@@ -0,0 +1,8 @@
+ERROR:  SQL/MM Spatial exception - coincident node
+ERROR:  SQL/MM Spatial exception - edge crosses node.
+ERROR:  SQL/MM Spatial exception - not isolated node
+ERROR:  SQL/MM Spatial exception - invalid point
+ERROR:  Cannot move isolated node across faces
+Isolated Node 4 moved to location 21,37
+Isolated Node 4 moved to location 19,37
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index f98afe4..63cfaf2 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -55,6 +55,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/st_getfacegeometry.sql \
 	$(topsrcdir)/topology/test/regress/st_modedgeheal.sql \
 	$(topsrcdir)/topology/test/regress/st_modedgesplit.sql \
+	$(topsrcdir)/topology/test/regress/st_moveisonode.sql \
 	$(topsrcdir)/topology/test/regress/st_newedgeheal.sql \
 	$(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
 	$(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
Summary of changes:
 NEWS                                          |  2 ++
 liblwgeom/lwgeom_topo.c                       | 17 ++++++++++++---
 topology/test/regress/sqlmm.sql               | 22 -------------------
 topology/test/regress/sqlmm_expected          |  7 ------
 topology/test/regress/st_moveisonode.sql      | 31 +++++++++++++++++++++++++++
 topology/test/regress/st_moveisonode_expected |  8 +++++++
 topology/test/tests.mk                        |  1 +
 7 files changed, 56 insertions(+), 32 deletions(-)
 create mode 100644 topology/test/regress/st_moveisonode.sql
 create mode 100644 topology/test/regress/st_moveisonode_expected
hooks/post-receive
