[postgis-tickets] [PostGIS] #4955: Configure flag --without-protobuf broken in back branches
PostGIS trac at osgeo.org
Tue Jul 27 04:11:24 PDT 2021
 Reporter:  mbanck   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.1.3
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 Except for 3.1 (where the protobuf handling got changed to basically
 mandating it unless explicitly switched off), all active branches seem to
 be broken when --without-protobuf (as mentioned in the configure help) is
 passed.
 In that case, configure.ac sets HAVE_PROTOBUF=yes, then checks the
 withval, and jumps over the whole detection code, leaving
 HAVE_PROTOBUF=yes on (and subsquently $PROTOCC is empty leading to build
 errors:
 E.g.:
 postgis-2.4.9> ./configure --with-protobuf --prefix=[...] 2>&1 | grep -i
 protobuf
 checking for PROTOBUFC... no
 libprotobuf-c not found in pkg-config
 checking protobuf-c/protobuf-c.h usability... no
 checking protobuf-c/protobuf-c.h presence... no
 checking for protobuf-c/protobuf-c.h... no
 unable to find protobuf-c/protobuf-c.h using
 checking for protobuf_c_message_init in -lprotobuf-c... no
 unable to link protobuf-c using
 checking for protobuf_c_version in -lprotobuf-c... no
 checking protobuf-c version... 0
 Cannot find protoc-c protobuf compiler on the PATH: [...]
   protobuf-c support:   no
 postgis-2.4.9> ./configure --without-protobuf --prefix=[...]  2>&1 | grep
 -i protobuf
   protobuf-c support:   yes
   protobuf-c version:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4955>
