[postgis-tickets] [PostGIS] #4958: TIGER2020 zcta and Tabblock and faces (was: TIGER2020 zcta and Tabblock)
PostGIS trac at osgeo.org
Thu Jul 29 07:18:12 PDT 2021
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.1.3
 Component:  tiger geocoder  |    Version:  main
Resolution:                  |   Keywords:
Description changed by robe:
Old description:
> for tiger2020 they have both Tabblock20 and Tabblock which has
> tabblcok10.  Script doesn't work with either cause it was relying on
> geoid field which is now called geoid10 or geoid20
> I haven't checked zcta data.
> Revising script to handle these.
New description:
 for tiger2020 they have both Tabblock20 and Tabblock which has tabblcok10.
 Script doesn't work with either cause it was relying on geoid field which
 Faces seemed broken as well but they might have changed the zcta column on
 it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4958#comment:5>
