[postgis-tickets] [PostGIS] #4736: ST_NumGeometries is zero for GeometryCollection with empty parts
PostGIS trac at osgeo.org
Thu Jul 29 13:55:13 PDT 2021
  Reporter:  Mike Taves  |      Owner:  strk
      Type:  defect      |     Status:  assigned
  Priority:  medium      |  Milestone:  PostGIS 3.0.4
 Component:  postgis     |    Version:  2.4.x
Resolution:              |   Keywords:
Comment (by pramsey):
 Meanwhile, there's some extra behavior lying around in more obscure types.
 Returns NULL on geometryn for empty input. There's a simplicity to that
 and it does match with other out-of-range behaviour of geometryn, so if we
 *do* think that numgeometries(empty) == 0, then geometryn(empty) should be
 NULL and not empty.
 postgis32=# SELECT 'patchN_01', ST_AsEWKT(ST_patchN('POLYHEDRALSURFACE
 EMPTY'::geometry, 1));
  ?column?  | st_asewkt
  patchN_01 |
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4736#comment:6>
