[postgis-tickets] [PostGIS] #4736: ST_NumGeometries is zero for GeometryCollection with empty parts
PostGIS trac at osgeo.org
Thu Jul 29 14:05:30 PDT 2021
  Reporter:  Mike Taves  |      Owner:  strk
      Type:  defect      |     Status:  assigned
  Priority:  medium      |  Milestone:  PostGIS 3.0.4
 Component:  postgis     |    Version:  2.4.x
Resolution:              |   Keywords:
Comment (by pramsey):
 The overloading of ST_NumGeometries to return non-null on simple geometry
 means that we end up with an odd situation where behaviours are slightly
 different with respect to element counts on empty things. I feel like the
 below is the least disruptive thing that involves the least change.
 ST_NumGeometries('POINT EMPTY') => 1
 ST_NumGeometries('GEOMETRYCOLLECTION EMPTY') => 0
 ST_NumGeometries('GEOMETRYCOLLECTION(POINT EMPTY)') => 1
 ST_GeometryN('POINT EMPTY', 1) => POINT EMPTY
 ST_GeometryN('GEOMETRYCOLLECTION EMPTY', 1) => NULL
 ST_GeometryN('GEOMETRYCOLLECTION(POINT EMPTY)', 1) => POINT EMPTY
 So just adjusting the return of ST_NumGeometries to be non-zero for
 collections of empty sub-elements.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4736#comment:8>
