[postgis-tickets] [PostGIS] #4885: macOS build fails: proj not found
PostGIS trac at osgeo.org
Fri Jul 30 11:20:50 PDT 2021
  Reporter:  rjhb     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.1.4
 Component:  postgis  |    Version:  3.1.x
Resolution:  fixed    |   Keywords:  macOS proj
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Pretty sure this has been fixed, at least there's a version switched check
 for this in configure.ac, and I can build on MacOS just fine with both old
 and new proj versions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4885#comment:4>
