[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-198-g429bf56
Thu Jun 3 03:42:23 PDT 2021
the project "PostGIS".
       via  429bf56aa47e55a13555a15d20ef08a1c14d2aba (commit)
      from  3efe42ec18bf1f2a9e3645049b8caf3828ef4f33 (commit)
revisions in full, below.
commit 429bf56aa47e55a13555a15d20ef08a1c14d2aba
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 4 18:19:03 2021 +0100
    topology.FindLayer function
    Closes #4869
diff --git a/NEWS b/NEWS
index 2f7d515..d45d57f 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,7 @@ PostGIS 3.2.0
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
+  - #4869, FindLayer to quickly get a layer record (Sandro Santilli)
   - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
   - ST_MakeValid(geometry, options) allows alternative validity building
     algorithms with GEOS 3.10 (Paul Ramsey)
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 0c48cd2..c31d10a 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -121,6 +121,7 @@ topology.sql: \
 	sql/query/GetNodeEdges.sql.in \
 	sql/manage/TopologySummary.sql.in \
 	sql/manage/CopyTopology.sql.in \
+	sql/manage/FindLayer.sql.in \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
 	sql/topoelement/topoelement_agg.sql.in \
diff --git a/topology/sql/manage/FindLayer.sql.in b/topology/sql/manage/FindLayer.sql.in
new file mode 100644
index 0000000..bcc88c5
--- /dev/null
+++ b/topology/sql/manage/FindLayer.sql.in
@@ -0,0 +1,68 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2021 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+--  FindLayer(TopoGeometry)
+-- Return a topology.layer record from a TopoGeometry
+CREATE OR REPLACE FUNCTION topology.FindLayer(tg TopoGeometry)
+RETURNS topology.layer
+AS $$
+    SELECT * FROM topology.layer
+    WHERE topology_id = topology_id($1)
+    AND layer_id = layer_id($1)
+$$ LANGUAGE 'sql';
+--  FindLayer(layerRegclass, layerColumn)
+-- Return a topology.layer record from a layer table/column
+CREATE OR REPLACE FUNCTION topology.FindLayer(layer_table regclass, feature_column name)
+AS $$
+    WHERE format('%I.%I', schema_name, table_name)::regclass = $1
+    AND feature_column = $2;
+$$ LANGUAGE 'sql';
+--  FindLayer(layerSchema, layerTable, layerColumn)
+-- Return a topology.layer record from a layer schema/table/column
+CREATE OR REPLACE FUNCTION topology.FindLayer(schema_name name, table_name name, feature_column name)
+AS $$
+    WHERE schema_name = $1
+    AND table_name = $2
+    AND feature_column = $3;
+$$ LANGUAGE 'sql';
+--  FindLayer(topoName)
+-- Return a topology.layer record from a topology id and layer id
+CREATE OR REPLACE FUNCTION topology.FindLayer(topology_id integer, layer_id integer)
+AS $$
+    WHERE topology_id = $1
+      AND layer_id = $2
+$$ LANGUAGE 'sql';
diff --git a/topology/test/regress/findlayer.sql b/topology/test/regress/findlayer.sql
index 0000000..7feec3a
--- /dev/null
+++ b/topology/test/regress/findlayer.sql
@@ -0,0 +1,25 @@
+BEGIN;
+CREATE SCHEMA s;
+SELECT NULL FROM CreateTopology('a');
+CREATE TABLE a.l(i int);
+SELECT AddTopoGeometryColumn('a','a','l','g1','POINT');
+SELECT AddTopoGeometryColumn('a','a','l','g2','POINT');
+SELECT 'by_regclass_1', layer_id(findLayer('a.l', 'g1'));
+SELECT 'by_regclass_2', layer_id(findLayer('a.l', 'g2'));
+SELECT 'by_schema_table_1', layer_id(findLayer('a', 'l', 'g1'));
+SELECT 'by_schema_table_2', layer_id(findLayer('a', 'l', 'g2'));
+SELECT 'by_ids_1', layer_id(findLayer(id(FindTopology('a')), layer_id(findLayer('a.l', 'g1'))));
+SELECT 'by_ids_2', layer_id(findLayer(id(FindTopology('a')), layer_id(findLayer('a.l', 'g2'))));
+SELECT 'by_topogeom_1', layer_id(findLayer(
+  toTopoGeom('POINT(0 0)', 'a', layer_id(findLayer('a.l','g1')), 0)
+SELECT 'by_topogeom_2', layer_id(findLayer(
+  toTopoGeom('POINT(0 0)', 'a', layer_id(findLayer('a.l','g2')), 0)
+ROLLBACK;
diff --git a/topology/test/regress/findlayer_expected b/topology/test/regress/findlayer_expected
index 0000000..c15641a
--- /dev/null
+++ b/topology/test/regress/findlayer_expected
@@ -0,0 +1,10 @@
+1
+2
+by_regclass_1|1
+by_regclass_2|2
+by_schema_table_1|1
+by_schema_table_2|2
+by_ids_1|1
+by_ids_2|2
+by_topogeom_1|1
+by_topogeom_2|2
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 4f01bc0..fcf610d 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -2191,6 +2191,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/TopologySummary.sql.in"
 #include "sql/manage/CopyTopology.sql.in"
 #include "sql/manage/FindTopology.sql.in"
+#include "sql/manage/FindLayer.sql.in"
 CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed() RETURNS text
Summary of changes:
 NEWS                                     |  1 +
 topology/Makefile.in                     |  1 +
 topology/sql/manage/FindLayer.sql.in     | 68 ++++++++++++++++++++++++++++++++
 topology/test/regress/findlayer.sql      | 25 ++++++++++++
 topology/test/regress/findlayer_expected | 10 +++++
 topology/topology.sql.in                 |  1 +
 6 files changed, 106 insertions(+)
 create mode 100644 topology/sql/manage/FindLayer.sql.in
 create mode 100644 topology/test/regress/findlayer.sql
 create mode 100644 topology/test/regress/findlayer_expected
hooks/post-receive
