[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-202-g423b519
Sun Jun 6 03:32:47 PDT 2021
the project "PostGIS".
       via  423b519e1851eb630c57ffa242bf370edfb365ad (commit)
       via  35558344063371f4ccc7dbc591e18ff78407b209 (commit)
       via  7f41d76cb44397fe4b0a7bde4016ee14fff809ed (commit)
       via  76f9c693b37139f3dd04f6ab5ecbee6ec9e16c70 (commit)
      from  429bf56aa47e55a13555a15d20ef08a1c14d2aba (commit)
revisions in full, below.
commit 423b519e1851eb630c57ffa242bf370edfb365ad
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jun 6 13:29:47 2021 +0300
    Polish over lwgeom_remove_repeated_points_in_place and NEWS entry
diff --git a/NEWS b/NEWS
index d45d57f..1de0ef3 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,8 @@ PostGIS 3.2.0
   - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
            to retain direction (Sandro Santilli)
   - #4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)
+  - #4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
+           (Aliaksandr Kalenik, Darafei Praliaskouski)
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 6ce5fbc..9fa7549 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1170,7 +1170,7 @@ static void test_lwgeom_remove_repeated_points(void)
 	modified = lwgeom_remove_repeated_points_in_place(g, 1);
 	ASSERT_INT_EQUAL(modified, LW_TRUE);
 	ewkt = lwgeom_to_ewkt(g);
-	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,10 0,5 5,0 10,10 10)");
+	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,0 10,5 5,10 0,10 10)");
 	lwgeom_free(g);
 	lwfree(ewkt);
@@ -1187,7 +1187,7 @@ static void test_lwgeom_remove_repeated_points(void)
-		ewkt, "MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60)");
+	    ewkt, "MULTIPOINT(0 0,0 10,5 5,5 8,8 5,8 8,10 0,10 10,50 50,50 60,55 55,55 58,58 55,58 58,60 50,60 60)");
 	lwgeom_free(g);
 	lwfree(ewkt);
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index f0975dd..ad85fa8 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1579,145 +1579,137 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
 	int geometry_modified = LW_FALSE;
 	switch (geom->type)
-		/* No-op! Cannot remote points */
-		case POINTTYPE:
-		case TRIANGLETYPE:
-			return geometry_modified;
-		case LINETYPE:
+	/* No-op! Cannot remove points */
+	case POINTTYPE:
+	case TRIANGLETYPE:
+		return geometry_modified;
+	case LINETYPE: {
+		LWLINE *g = (LWLINE *)(geom);
+		POINTARRAY *pa = g->points;
+		uint32_t npoints = pa->npoints;
+		ptarray_remove_repeated_points_in_place(pa, tolerance, 2);
+		geometry_modified = npoints != pa->npoints;
+		/* Invalid input, discard the collapsed line */
+		if (pa->npoints < 2)
-			LWLINE *g = (LWLINE*)(geom);
-			POINTARRAY *pa = g->points;
+			pa->npoints = 0;
+			geometry_modified = LW_TRUE;
+		break;
+	case POLYGONTYPE: {
+		uint32_t j = 0;
+		LWPOLY *g = (LWPOLY *)(geom);
+		for (uint32_t i = 0; i < g->nrings; i++)
+			POINTARRAY *pa = g->rings[i];
-			ptarray_remove_repeated_points_in_place(pa, tolerance, 2);
-			geometry_modified = npoints != pa->npoints;
-			/* Invalid output */
-			if (pa->npoints == 1 && pa->maxpoints > 1)
+			ptarray_remove_repeated_points_in_place(pa, tolerance, 4);
+			geometry_modified |= npoints != pa->npoints;
+			/* Drop collapsed rings */
+			if (pa->npoints < 4)
-				/* Use first point as last point */
-				pa->npoints = 2;
-				ptarray_copy_point(pa, 0, 1);
+				ptarray_free(pa);
+				continue;
-			break;
+			g->rings[j++] = pa;
-		case POLYGONTYPE:
+		/* Update ring count */
+		g->nrings = j;
+		break;
+	case MULTIPOINTTYPE: {
+		double tolsq = tolerance * tolerance;
+		LWMPOINT *mpt = (LWMPOINT *)geom;
+		for (uint8_t dim = 0; dim < 2; dim++)
-			uint32_t i, j = 0;
-			LWPOLY *g = (LWPOLY*)(geom);
-			for (i = 0; i < g->nrings; i++)
+			/* sort by y, then by x - this way the result is sorted by x */
+			qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), dim ? cmp_point_x : cmp_point_y);
+			for (uint32_t i = 0; i < mpt->ngeoms; i++)
-				POINTARRAY *pa = g->rings[i];
-				int minpoints = 4;
-				uint32_t npoints = 0;
-				/* Skip zero'ed out rings */
-				if(!pa)
+				if (!mpt->geoms[i])
 					continue;
-				npoints = pa->npoints;
-				ptarray_remove_repeated_points_in_place(pa, tolerance, minpoints);
-				geometry_modified |= npoints != pa->npoints;
-				/* Drop collapsed rings */
-				if(pa->npoints < 4)
-					geometry_modified = LW_TRUE;
-					ptarray_free(pa);
-					continue;
-				g->rings[j++] = pa;
-			/* Update ring count */
-			g->nrings = j;
-			break;
-		case MULTIPOINTTYPE:
-			double tolsq = tolerance * tolerance;
-			LWMPOINT *mpt = (LWMPOINT *)geom;
-			for (uint8_t dim = 0; dim < 2; dim++)
-				qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), dim ? cmp_point_y : cmp_point_x);
-				for (uint32_t i = 0; i < mpt->ngeoms; i++)
+				const POINT2D *pti = getPoint2d_cp(mpt->geoms[i]->point, 0);
+				/* check upcoming points if they're within tolerance of current one */
+				for (uint32_t j = i + 1; j < mpt->ngeoms; j++)
-					if (!mpt->geoms[i])
+					if (!mpt->geoms[j])
 						continue;
-					const POINT2D *pti = getPoint2d_cp(mpt->geoms[i]->point, 0);
-					for (uint32_t j = i + 1; j < mpt->ngeoms; j++)
-						if (!mpt->geoms[j])
-							continue;
+					const POINT2D *ptj = getPoint2d_cp(mpt->geoms[j]->point, 0);
-						const POINT2D *ptj = getPoint2d_cp(mpt->geoms[j]->point, 0);
-						if ((dim ? ptj->y - pti->y : ptj->x - pti->x) > tolerance)
-							break;
+					/* check that the point is in the strip of tolerance around the point */
+					if ((dim ? ptj->x - pti->x : ptj->y - pti->y) > tolerance)
+						break;
-						if (distance2d_sqr_pt_pt(pti, ptj) <= tolsq)
-							lwpoint_free(mpt->geoms[j]);
-							mpt->geoms[j] = NULL;
+					/* remove any upcoming point that is within tolerance circle */
+					if (distance2d_sqr_pt_pt(pti, ptj) <= tolsq)
+						lwpoint_free(mpt->geoms[j]);
+						mpt->geoms[j] = NULL;
-				uint32_t i = 0;
-				for (uint32_t j = 0; j < mpt->ngeoms; j++)
-					if (mpt->geoms[j])
-						mpt->geoms[i++] = mpt->geoms[j];
-				geometry_modified |= mpt->ngeoms != i;
-				mpt->ngeoms = i;
-			break;
+			/* compactify array of points */
+			uint32_t i = 0;
+			for (uint32_t j = 0; j < mpt->ngeoms; j++)
+				if (mpt->geoms[j])
+					mpt->geoms[i++] = mpt->geoms[j];
+			mpt->ngeoms = i;
-		case CIRCSTRINGTYPE:
-			/* Dunno how to handle these, will return untouched */
+		break;
-		/* Can process most multi* types as generic collection */
-		case MULTILINETYPE:
-		case MULTIPOLYGONTYPE:
-		case TINTYPE:
-		case COLLECTIONTYPE:
-		/* Curve types we mostly ignore, but allow the linear */
-		/* portions to be processed by recursing into them */
-		case MULTICURVETYPE:
-		case CURVEPOLYTYPE:
-		case MULTISURFACETYPE:
-		case COMPOUNDTYPE:
+	case CIRCSTRINGTYPE:
+		/* Dunno how to handle these, will return untouched */
+	/* Can process most multi* types as generic collection */
+	case MULTILINETYPE:
+	case MULTIPOLYGONTYPE:
+	case TINTYPE:
+	case COLLECTIONTYPE:
+	/* Curve types we mostly ignore, but allow the linear */
+	/* portions to be processed by recursing into them */
+	case MULTICURVETYPE:
+	case CURVEPOLYTYPE:
+	case MULTISURFACETYPE:
+	case COMPOUNDTYPE: {
+		uint32_t i, j = 0;
+		LWCOLLECTION *col = (LWCOLLECTION *)(geom);
+		for (i = 0; i < col->ngeoms; i++)
-			LWCOLLECTION *col = (LWCOLLECTION*)(geom);
-			for (i = 0; i < col->ngeoms; i++)
+			LWGEOM *g = col->geoms[i];
+			if (!g)
+				continue;
+			geometry_modified |= lwgeom_remove_repeated_points_in_place(g, tolerance);
+			/* Drop zero'ed out geometries */
+			if (lwgeom_is_empty(g))
-				LWGEOM *g = col->geoms[i];
-				if (!g) continue;
-				geometry_modified |= lwgeom_remove_repeated_points_in_place(g, tolerance);
-				/* Drop zero'ed out geometries */
-				if(lwgeom_is_empty(g))
-					lwgeom_free(g);
-					continue;
-				col->geoms[j++] = g;
+				lwgeom_free(g);
+				continue;
-			/* Update geometry count */
-			col->ngeoms = j;
-			break;
-		default:
-			lwerror("%s: unsupported geometry type: %s", __func__, lwtype_name(geom->type));
-			break;
+			col->geoms[j++] = g;
+		/* Update geometry count */
+		col->ngeoms = j;
+		break;
+	default: {
+		lwerror("%s: unsupported geometry type: %s", __func__, lwtype_name(geom->type));
+		break;
 	if (geometry_modified)
 		lwgeom_drop_bbox(geom);
diff --git a/regress/core/remove_repeated_points_expected b/regress/core/remove_repeated_points_expected
index 2e747d0..607dca0 100644
--- a/regress/core/remove_repeated_points_expected
+++ b/regress/core/remove_repeated_points_expected
@@ -4,8 +4,8 @@
 3|MULTILINESTRING((0 0,1 1,2 2,3 3),(5 5,4 4,2 2))
 4|POLYGON((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5))
 5|MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55)))
-6|MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60)
-7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
+6|MULTIPOINT(0 0,0 10,5 5,5 8,8 5,8 8,10 0,10 10,50 50,50 60,55 55,55 58,58 55,58 58,60 50,60 60)
+7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,0 10,5 5,5 8,8 5,8 8,10 0,10 10,50 50,50 60,55 55,55 58,58 55,58 58,60 50,60 60),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
 8|POINT(0 0)
 9|CURVEPOLYGON ZM (CIRCULARSTRING ZM (-2 0 0 0,-1 -1 1 2,0 0 2 4,1 -1 3 6,2 0 4 8,0 2 2 4,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2))
 10|LINESTRING(0 0,0 0)
commit 35558344063371f4ccc7dbc591e18ff78407b209
Author: kalenikaliaksandr <kalenik.aliaksandr at gmail.com>
Date:   Thu Apr 22 20:39:03 2021 +0300
    fix code style
index b041ab7..f0975dd 100644
@@ -1632,22 +1632,22 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
-			for (uint32_t dim = 0; dim < 2; dim++)
-				qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), dim == 0 ? cmp_point_x : cmp_point_y);
+				qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), dim ? cmp_point_y : cmp_point_x);
-					if (mpt->geoms[i] == NULL)
 						continue;
-						if (mpt->geoms[j] == NULL)
 							continue;
-						if ((dim == 0 ? ptj->x - pti->x : ptj->y - pti->y) > tolerance)
+						if ((dim ? ptj->y - pti->y : ptj->x - pti->x) > tolerance)
 							break;
@@ -1661,7 +1661,7 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
 				uint32_t i = 0;
-					if (mpt->geoms[j] != NULL)
commit 7f41d76cb44397fe4b0a7bde4016ee14fff809ed
Date:   Mon Apr 19 23:30:42 2021 +0300
    improve performance of removerepeatedpoints(multipoint) -- double sort
index 4400ca2..6ce5fbc 100644
-	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,0 10,5 5,10 10,10 0)");
+	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,10 0,5 5,0 10,10 10)");
 	lwgeom_free(g);
 	lwfree(ewkt);
-	    ewkt, "MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0)");
+		ewkt, "MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60)");
 	lwgeom_free(g);
 	lwfree(ewkt);
index 66dc1be..b041ab7 100644
@@ -1550,19 +1550,27 @@ void lwgeom_set_srid(LWGEOM *geom, int32_t srid)
 static int
-point_cmp(const void *pn1, const void *pn2)
+cmp_point_x(const void *pa, const void *pb)
-	LWPOINT *p1 = *((LWPOINT **)pn1);
-	LWPOINT *p2 = *((LWPOINT **)pn2);
+	LWPOINT *p1 = *((LWPOINT **)pa);
+	LWPOINT *p2 = *((LWPOINT **)pb);
-	GBOX b1, b2;
-	lwgeom_calculate_gbox((LWGEOM *)p1, &b1);
-	lwgeom_calculate_gbox((LWGEOM *)p2, &b2);
+	const POINT2D *pt1 = getPoint2d_cp(p1->point, 0);
+	const POINT2D *pt2 = getPoint2d_cp(p2->point, 0);
-	uint64_t h1, h2;
-	h1 = gbox_get_sortable_hash(&b1, 0);
-	h2 = gbox_get_sortable_hash(&b2, 0);
-	return h1 < h2 ? -1 : (h1 > h2 ? 1 : 0);
+	return (pt1->x > pt2->x) ? 1 : ((pt1->x < pt2->x) ? -1 : 0);
+static int
+cmp_point_y(const void *pa, const void *pb)
+	return (pt1->y > pt2->y) ? 1 : ((pt1->y < pt2->y) ? -1 : 0);
 int
@@ -1623,26 +1631,43 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
-			qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), point_cmp);
-			uint32_t i = 0;
-			for (uint32_t j = 1; j < mpt->ngeoms; j++)
+			for (uint32_t dim = 0; dim < 2; dim++)
-				POINT2D ptj, pti;
-				getPoint2d_p(mpt->geoms[i]->point, 0, &pti);
-				getPoint2d_p(mpt->geoms[j]->point, 0, &ptj);
-				if (distance2d_sqr_pt_pt(&ptj, &pti) > tolsq)
+				qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), dim == 0 ? cmp_point_x : cmp_point_y);
-					mpt->geoms[++i] = mpt->geoms[j];
+					if (mpt->geoms[i] == NULL)
+						continue;
+						if (mpt->geoms[j] == NULL)
+							continue;
+						if ((dim == 0 ? ptj->x - pti->x : ptj->y - pti->y) > tolerance)
+							break;
-				else
+				uint32_t i = 0;
+					if (mpt->geoms[j] != NULL)
-			geometry_modified = mpt->ngeoms != i + 1;
-			mpt->ngeoms = i + 1;
+				geometry_modified |= mpt->ngeoms != i;
+				mpt->ngeoms = i;
 			break;
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index bcbcc1c..b53be37 100644
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@ -81,7 +81,7 @@ TG6|GjIKBHRlc3QSHRICAAAYAyIVCVqmPxoTRjETCicPCSgKEh0KFBQPGgJjMSICKAEogCB4Ag==
 TG7|Gj0KBHRlc3QSKBICAAAYAyIgCSi6PyIyHh0eJwkAJw8JFAoSABQUCQ8JEzESKAoKFA8aAmMxIgIo
 ASiAIHgC
 TG8|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
-TG9|GiMKBHRlc3QSDhICAAAYASIGETLeP2VGGgJjMSICKAEogCB4Ag==
+TG9|GiMKBHRlc3QSDhICAAAYASIGETOkQGZFGgJjMSICKAEogCB4Ag==
 TA1|Gi8KBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgYKBGFiY2QogCB4Ag==
 TA2|GigKBHRlc3QSDBICAAAYASIECTLePxoCYzEiCRmamZmZmZnxPyiAIHgC
 TA3|GhkKBHRlc3QSCBgBIgQJMt4/GgJjMSiAIHgC
index faa1a9c..2e747d0 100644
@@ -4,8 +4,8 @@
-6|MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0)
-7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
+6|MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60)
+7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,10 0,5 5,8 5,5 8,8 8,0 10,10 10,50 50,60 50,55 55,58 55,55 58,58 58,50 60,60 60),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
 8|POINT(0 0)
commit 76f9c693b37139f3dd04f6ab5ecbee6ec9e16c70
Date:   Mon Apr 19 04:55:10 2021 +0300
index f58b001..4400ca2 100644
-	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,10 0,10 10,0 10,5 5)");
+	ASSERT_STRING_EQUAL(ewkt, "MULTIPOINT(0 0,0 10,5 5,10 10,10 0)");
 	lwgeom_free(g);
 	lwfree(ewkt);
-	    ewkt, "MULTIPOINT(0 0,10 0,10 10,0 10,5 5,5 8,8 8,8 5,50 50,50 60,60 60,60 50,55 55,55 58,58 58,58 55)");
+	    ewkt, "MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0)");
 	lwgeom_free(g);
 	lwfree(ewkt);
index 49579b4..66dc1be 100644
@@ -1549,6 +1549,21 @@ void lwgeom_set_srid(LWGEOM *geom, int32_t srid)
+static int
+point_cmp(const void *pn1, const void *pn2)
+	LWPOINT *p1 = *((LWPOINT **)pn1);
+	LWPOINT *p2 = *((LWPOINT **)pn2);
+	GBOX b1, b2;
+	lwgeom_calculate_gbox((LWGEOM *)p1, &b1);
+	lwgeom_calculate_gbox((LWGEOM *)p2, &b2);
+	uint64_t h1, h2;
+	h1 = gbox_get_sortable_hash(&b1, 0);
+	h2 = gbox_get_sortable_hash(&b2, 0);
+	return h1 < h2 ? -1 : (h1 > h2 ? 1 : 0);
 int
@@ -1606,55 +1621,29 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
-			double tolsq = tolerance*tolerance;
-			uint32_t i, j, n = 0;
-			LWMPOINT *mpt = (LWMPOINT *)(geom);
-			LWPOINT **out;
-			LWPOINT *out_stack[out_stack_size];
-			int use_heap = (mpt->ngeoms > out_stack_size);
-			/* No-op on empty */
-			if (mpt->ngeoms < 2)
-			/* We cannot write directly back to the multipoint */
-			/* geoms array because we're reading out of it still */
-			/* so we use a side array */
-			if (use_heap)
-				out = lwalloc(sizeof(LWMPOINT *) * mpt->ngeoms);
-			else
-				out = out_stack;
+			qsort(mpt->geoms, mpt->ngeoms, sizeof(LWPOINT *), point_cmp);
-			/* Inefficient O(n^2) implementation */
-			for (i = 0; i < mpt->ngeoms; i++)
+			uint32_t i = 0;
+			for (uint32_t j = 1; j < mpt->ngeoms; j++)
-				int seen = 0;
-				LWPOINT *p1 = mpt->geoms[i];
-				const POINT2D *pt1 = getPoint2d_cp(p1->point, 0);
-				for (j = 0; j < n; j++)
+				POINT2D ptj, pti;
+				getPoint2d_p(mpt->geoms[i]->point, 0, &pti);
+				getPoint2d_p(mpt->geoms[j]->point, 0, &ptj);
+				if (distance2d_sqr_pt_pt(&ptj, &pti) > tolsq)
-					LWPOINT *p2 = out[j];
-					const POINT2D *pt2 = getPoint2d_cp(p2->point, 0);
-					if (distance2d_sqr_pt_pt(pt1, pt2) <= tolsq)
-						seen = 1;
-						break;
+					mpt->geoms[++i] = mpt->geoms[j];
-				if (seen)
+				else
-					lwpoint_free(p1);
-					continue;
-				out[n++] = p1;
-			/* Copy remaining points back into the input */
-			/* array */
-			memcpy(mpt->geoms, out, sizeof(LWPOINT *) * n);
-			geometry_modified = mpt->ngeoms != n;
-			mpt->ngeoms = n;
-			if (use_heap) lwfree(out);
+			geometry_modified = mpt->ngeoms != i + 1;
+			mpt->ngeoms = i + 1;
 			break;
index b793a6d..faa1a9c 100644
@@ -4,8 +4,8 @@
-6|MULTIPOINT(0 0,10 0,10 10,0 10,5 5,5 8,8 8,8 5,50 50,50 60,60 60,60 50,55 55,55 58,58 58,58 55)
-7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,10 0,10 10,0 10,5 5,5 8,8 8,8 5,50 50,50 60,60 60,60 50,55 55,55 58,58 58,58 55),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
+6|MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0)
+7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,0 10,5 5,8 5,8 8,10 10,5 8,50 50,55 55,50 60,55 58,58 58,60 60,58 55,60 50,10 0),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
 8|POINT(0 0)
Summary of changes:
 NEWS                                         |   2 +
 liblwgeom/cunit/cu_algorithm.c               |   4 +-
 liblwgeom/lwgeom.c                           | 250 ++++++++++++++-------------
 regress/core/mvt_expected                    |   2 +-
 regress/core/remove_repeated_points_expected |   4 +-
 5 files changed, 135 insertions(+), 127 deletions(-)
hooks/post-receive
