[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-206-gba12b47
Thu Jun 10 12:40:33 PDT 2021
the project "PostGIS".
       via  ba12b4756994120cd736c64054322e290e5668ca (commit)
      from  12bb49953908c100683ca15bf2c2964d3b865a11 (commit)
revisions in full, below.
commit ba12b4756994120cd736c64054322e290e5668ca
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 10 12:40:12 2021 -0700
    Normalize ST_RemoveRepeatedPoints() test to work around different platform qsort behaviour.
diff --git a/regress/core/remove_repeated_points.sql b/regress/core/remove_repeated_points.sql
index 0270598..9da8f9a 100644
--- a/regress/core/remove_repeated_points.sql
+++ b/regress/core/remove_repeated_points.sql
@@ -4,8 +4,8 @@ SELECT 2, ST_AsText(ST_RemoveRepeatedPoints('LINESTRING(0 0, 1 1, 1 1, 2 2, 2 2,
 SELECT 3, ST_AsText(ST_RemoveRepeatedPoints('MULTILINESTRING((0 0, 1 1, 1 1, 2 2, 2 2, 2 2, 2 2, 3 3, 3 3),(5 5, 5 5, 5 5, 4 4, 2 2))'));
 SELECT 4, ST_AsText(ST_RemoveRepeatedPoints('POLYGON((0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0),(5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5))'));
 SELECT 5, ST_AsText(ST_RemoveRepeatedPoints('MULTIPOLYGON(((0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0),(5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5)),((50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50),(55 55, 55 58, 58 58, 58 55, 58 55, 55 55)))'));
-SELECT 6, ST_AsText(ST_RemoveRepeatedPoints('MULTIPOINT(0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0,5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5,50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50,55 55, 55 58, 58 58, 58 55, 58 55, 55 55)'));
-SELECT 7, ST_AsText(ST_RemoveRepeatedPoints('GEOMETRYCOLLECTION(MULTIPOINT(0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0,5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5,50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50,55 55, 55 58, 58 58, 58 55, 58 55, 55 55),MULTIPOLYGON(((0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0),(5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5)),((50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50),(55 55, 55 58, 58 58, 58 55, 58 55, 55 55))))'));
+SELECT 6, ST_AsText(ST_Normalize(ST_RemoveRepeatedPoints('MULTIPOINT(0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0,5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5,50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50,55 55, 55 58, 58 58, 58 55, 58 55, 55 55)')));
+SELECT 7, ST_AsText(ST_Normalize(ST_RemoveRepeatedPoints('GEOMETRYCOLLECTION(MULTIPOINT(0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0,5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5,50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50,55 55, 55 58, 58 58, 58 55, 58 55, 55 55),MULTIPOLYGON(((0 0, 10 0, 10 10, 10 10, 0 10, 0 10, 0 10, 0 0, 0 0, 0 0),(5 5, 5 5, 5 8, 8 8, 8 8, 8 8, 8 5,8 5, 5 5, 5 5, 5 5, 5 5, 5 5)),((50 50, 50 50, 50 50, 50 60, 50 60, 50 60, 60 60, 60 50, 60 50, 50 50),(55 55, 55 58, 58 58, 58 55, 58 55, 55 55))))')));
 SELECT 8, ST_AsText(ST_RemoveRepeatedPoints('POINT(0 0)'));
 SELECT 9, ST_AsText(ST_RemoveRepeatedPoints('CURVEPOLYGON(CIRCULARSTRING(
                 -2 0 0 0,
diff --git a/regress/core/remove_repeated_points_expected b/regress/core/remove_repeated_points_expected
index 607dca0..444759c 100644
--- a/regress/core/remove_repeated_points_expected
+++ b/regress/core/remove_repeated_points_expected
@@ -4,8 +4,8 @@
 3|MULTILINESTRING((0 0,1 1,2 2,3 3),(5 5,4 4,2 2))
 4|POLYGON((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5))
 5|MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55)))
-6|MULTIPOINT(0 0,0 10,5 5,5 8,8 5,8 8,10 0,10 10,50 50,50 60,55 55,55 58,58 55,58 58,60 50,60 60)
-7|GEOMETRYCOLLECTION(MULTIPOINT(0 0,0 10,5 5,5 8,8 5,8 8,10 0,10 10,50 50,50 60,55 55,55 58,58 55,58 58,60 50,60 60),MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(5 5,5 8,8 8,8 5,5 5)),((50 50,50 60,60 60,60 50,50 50),(55 55,55 58,58 58,58 55,55 55))))
+6|MULTIPOINT(60 60,60 50,58 58,58 55,55 58,55 55,50 60,50 50,10 10,10 0,8 8,8 5,5 8,5 5,0 10,0 0)
+7|GEOMETRYCOLLECTION(MULTIPOLYGON(((50 50,50 60,60 60,60 50,50 50),(55 55,58 55,58 58,55 58,55 55)),((0 0,0 10,10 10,10 0,0 0),(5 5,8 5,8 8,5 8,5 5))),MULTIPOINT(60 60,60 50,58 58,58 55,55 58,55 55,50 60,50 50,10 10,10 0,8 8,8 5,5 8,5 5,0 10,0 0))
 8|POINT(0 0)
 9|CURVEPOLYGON ZM (CIRCULARSTRING ZM (-2 0 0 0,-1 -1 1 2,0 0 2 4,1 -1 3 6,2 0 4 8,0 2 2 4,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2))
 10|LINESTRING(0 0,0 0)
Summary of changes:
 regress/core/remove_repeated_points.sql      | 4 ++--
 regress/core/remove_repeated_points_expected | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
