[postgis-tickets] [PostGIS] #4680: Implement ST_GetFaceGeometry by following rings, not face labels
PostGIS trac at osgeo.org
Tue Jun 15 15:47:15 PDT 2021
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Fund Me
 Component:  topology     |    Version:  master
Resolution:               |   Keywords:
Comment (by strk):
 Important info: this would NOT be easy to make faster than GEOS with only
 using SQL, as the already complex recusrive CTE used to find a ring of
 edges would need to be iterated to find *all* rings, and for faces with a
 lot of holes this would be very very expensive, unless it can be done with
 a single SQL statement
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4680#comment:2>
