[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-211-gfc5947f
Wed Jun 16 01:18:29 PDT 2021
the project "PostGIS".
       via  fc5947f46d2ba1756d7ae2a1c79a2b2b02c433c9 (commit)
      from  1cfb456ac11a20aa361cf6816f2dd88d30651112 (commit)
revisions in full, below.
commit fc5947f46d2ba1756d7ae2a1c79a2b2b02c433c9
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jun 16 10:18:16 2021 +0200
    I don't think we're using travis anymore, right ?
diff --git a/.travis.yml b/.travis.yml
deleted file mode 100644
index 73df152..0000000
--- a/.travis.yml
+++ /dev/null
@@ -1,58 +0,0 @@
-services:
-  - docker
-language: c
-env:
-  # Use the last stable release to run more tests
-  #- tag=pg13-geos39-gdal31-proj71 mode=garden
-  - tag=pg13-geos39-gdal31-proj71 mode=tests
-  - tag=pg13-geos39-gdal31-proj71 mode=debug
-  - tag=pg13-geos39-gdal31-proj71 mode=coverage
-  - tag=pg13-geos39-gdal31-proj71 mode=usan_gcc
-  - tag=pg13-clang-geos39-gdal31-proj71 mode=usan_clang
-  # Run tests with different dependency combinations
-  - tag=latest mode=tests
-  - tag=pg13-geos38-gdal31-proj71 mode=tests
-  - tag=pg12-geos37-gdal30-proj611 mode=tests
-  - tag=pg11-geos37-gdal24-proj52 mode=tests
-  - tag=pg10-geos36-gdal23-proj49 mode=tests
-  - tag=pg96-geos36-gdal22-proj49 mode=tests
-matrix:
-  allow_failures:
-    - env: tag=latest mode=tests
-  include:
-    - name: "Lint: python3 -m flake8 . --select=E9,F63,F72,F82"
-      language: python
-      script:
-        - pip install flake8  # lint Python code for syntax errors
-        - flake8 . --count --select=E9,F63,F72,F82 --show-source --statistics
-before_install:
-  - curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
-  - sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
-  - sudo apt-get update
-  - sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
-script:
-  - echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
-  - echo "FROM postgis/postgis-build-env:${tag}" > Dockerfile
-  - echo "ADD --chown=postgres:postgres . /src/postgis" >> Dockerfile
-  - echo "CMD bash ci/travis/run_${mode}.sh" >> Dockerfile
-  - docker build -t pgtest .
-  - ci_env=`bash .github/codecov_env.bash`
-  - docker run $ci_env --name pgtest-${TRAVIS_BUILD_NUMBER} pgtest
-after_success:
-  - docker rm pgtest-${TRAVIS_BUILD_NUMBER}
-notifications:
-  email: false
-  irc:
-    channels:
-      - "irc.freenode.org#postgis-activity"
-    on_success: change
-    on_failure: always
-    use_notice: false
Summary of changes:
 .travis.yml | 58 ----------------------------------------------------------
 1 file changed, 58 deletions(-)
 delete mode 100644 .travis.yml
hooks/post-receive
