[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-37-g32df100
Wed Jun 16 08:56:51 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  32df1005032945a9fe5c79432f60e42d4adcd7a8 (commit)
      from  26544e64c60ad1271297721bdba18eaff1148736 (commit)
revisions in full, below.
commit 32df1005032945a9fe5c79432f60e42d4adcd7a8
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jun 16 17:54:11 2021 +0200
    Fix missing user errors from GetRingEdges
    References #4929 in 3.1 branch (3.1.3dev)
diff --git a/NEWS b/NEWS
index 80f620e..3ab70f3 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,8 @@ PostGIS 3.1.3
 2021/xx/xx
 * Bug Fixes
+  - #4929, Fix missing error from GetRingEdges when invoked with
+           unexistent topology or edge (Sandro Santilli)
   - #4927, Fix PostgreSQL 14 compile FuncnameGetCandidates changes
            (Regina Obe, Julien Rouhaud)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 3acc5c6..be74d9a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1203,6 +1203,12 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
   *numelems = SPI_processed;
   if ( ! SPI_processed )
+    cberror(
+      topo->be_data,
+      "No edge with id %" LWTFMT_ELEMID" in Topology \"%s\"",
+      ABS(edge),
+      topo->name
     return NULL;
   if (limit && *numelems == (uint64_t)limit)
@@ -5056,8 +5062,8 @@ Datum GetRingEdges(PG_FUNCTION_ARGS)
     pfree(toponame);
     if ( ! topo )
-      /* should never reach this point, as lwerror would raise an exception */
       SPI_finish();
+      lwpgerror("%s", cb_lastErrorMessage(&be_data));
       PG_RETURN_NULL();
@@ -5068,8 +5074,8 @@ Datum GetRingEdges(PG_FUNCTION_ARGS)
     if ( ! elems )
       SPI_finish();
       PG_RETURN_NULL();
diff --git a/topology/test/regress/getringedges.sql b/topology/test/regress/getringedges.sql
index 88b4bd4..6d23626 100644
--- a/topology/test/regress/getringedges.sql
+++ b/topology/test/regress/getringedges.sql
@@ -2,6 +2,11 @@ set client_min_messages to ERROR;
 \i ../load_topology.sql
+-- Test bogus calls
+SELECT 'non-existent-topo', topology.GetRingEdges('non-existent', 1);
+SELECT 'non-existent-edge', topology.GetRingEdges('city_data', 10000000);
+SELECT 'non-existent-edge-negative', topology.GetRingEdges('city_data', -10000000);
 SELECT 'R'||edge_id, (topology.GetRingEdges('city_data', edge_id)).*
 	FROM city_data.edge;
diff --git a/topology/test/regress/getringedges_expected b/topology/test/regress/getringedges_expected
index 904609d..0b6a470 100644
--- a/topology/test/regress/getringedges_expected
+++ b/topology/test/regress/getringedges_expected
@@ -1,235 +1,66 @@
-t
-9
-22
-26
-R1|1|1
-R2|1|2
-R2|2|3
-R2|3|-3
-R3|1|3
-R3|2|-3
-R3|3|2
-R4|1|4
-R4|2|-5
-R4|3|5
-R4|4|-4
-R5|1|5
-R5|2|-4
-R5|3|4
-R5|4|-5
-R6|1|6
-R6|2|7
-R6|3|8
-R6|4|-15
-R6|5|-16
-R6|6|-14
-R6|7|-13
-R6|8|-12
-R6|9|22
-R6|10|21
-R7|1|7
-R7|2|8
-R7|3|-15
-R7|4|-16
-R7|5|-14
-R7|6|-13
-R7|7|-12
-R7|8|22
-R7|9|21
-R7|10|6
-R8|1|8
-R8|2|-15
-R8|3|-16
-R8|4|-14
-R8|5|-13
-R8|6|-12
-R8|7|22
-R8|8|21
-R8|9|6
-R8|10|7
-R9|1|9
-R9|2|19
-R9|3|-6
-R9|4|-21
-R10|1|10
-R10|2|-20
-R10|3|13
-R10|4|18
-R11|1|11
-R11|2|15
-R11|3|-8
-R11|4|-17
-R12|1|12
-R12|2|20
-R12|3|-9
-R12|4|-22
-R13|1|13
-R13|2|18
-R13|3|10
-R13|4|-20
-R14|1|14
-R14|2|16
-R14|3|-11
-R14|4|-18
-R15|1|15
-R15|2|-8
-R15|3|-17
-R15|4|11
-R16|1|16
-R16|2|-11
-R16|3|-18
-R16|4|14
-R17|1|17
-R17|2|-7
-R17|3|-19
-R17|4|-10
-R18|1|18
-R18|2|10
-R18|3|-20
-R18|4|13
-R19|1|19
-R19|2|-6
-R19|3|-21
-R19|4|9
-R20|1|20
-R20|2|-9
-R20|3|-22
-R20|4|12
-R21|1|21
-R21|2|6
-R21|3|7
-R21|4|8
-R21|5|-15
-R21|6|-16
-R21|7|-14
-R21|8|-13
-R21|9|-12
-R21|10|22
-R22|1|22
-R22|2|21
-R22|3|6
-R22|4|7
-R22|5|8
-R22|6|-15
-R22|7|-16
-R22|8|-14
-R22|9|-13
-R22|10|-12
-R25|1|25
-R25|2|-25
-R26|1|26
-R-1|1|-1
-R-2|1|-2
-R-3|1|-3
-R-3|2|2
-R-3|3|3
-R-4|1|-4
-R-4|2|4
-R-4|3|-5
-R-4|4|5
-R-5|1|-5
-R-5|2|5
-R-5|3|-4
-R-5|4|4
-R-6|1|-6
-R-6|2|-21
-R-6|3|9
-R-6|4|19
-R-7|1|-7
-R-7|2|-19
-R-7|3|-10
-R-7|4|17
-R-8|1|-8
-R-8|2|-17
-R-8|3|11
-R-8|4|15
-R-9|1|-9
-R-9|2|-22
-R-9|3|12
-R-9|4|20
-R-10|1|-10
-R-10|2|17
-R-10|3|-7
-R-10|4|-19
-R-11|1|-11
-R-11|2|-18
-R-11|3|14
-R-11|4|16
-R-12|1|-12
-R-12|2|22
-R-12|3|21
-R-12|4|6
-R-12|5|7
-R-12|6|8
-R-12|7|-15
-R-12|8|-16
-R-12|9|-14
-R-12|10|-13
-R-13|1|-13
-R-13|2|-12
-R-13|3|22
-R-13|4|21
-R-13|5|6
-R-13|6|7
-R-13|7|8
-R-13|8|-15
-R-13|9|-16
-R-13|10|-14
-R-14|1|-14
-R-14|2|-13
-R-14|3|-12
-R-14|4|22
-R-14|5|21
-R-14|6|6
-R-14|7|7
-R-14|8|8
-R-14|9|-15
-R-14|10|-16
-R-15|1|-15
-R-15|2|-16
-R-15|3|-14
-R-15|4|-13
-R-15|5|-12
-R-15|6|22
-R-15|7|21
-R-15|8|6
-R-15|9|7
-R-15|10|8
-R-16|1|-16
-R-16|2|-14
-R-16|3|-13
-R-16|4|-12
-R-16|5|22
-R-16|6|21
-R-16|7|6
-R-16|8|7
-R-16|9|8
-R-16|10|-15
-R-17|1|-17
-R-17|2|11
-R-17|3|15
-R-17|4|-8
-R-18|1|-18
-R-18|2|14
-R-18|3|16
-R-18|4|-11
-R-19|1|-19
-R-19|2|-10
-R-19|3|17
-R-19|4|-7
-R-20|1|-20
-R-20|2|13
-R-20|3|18
-R-20|4|10
-R-21|1|-21
-R-21|2|9
-R-21|3|19
-R-21|4|-6
-R-22|1|-22
-R-22|2|12
-R-22|3|20
-R-22|4|-9
-R-25|1|-25
-R-25|2|25
-R-26|1|-26
-Topology 'city_data' dropped
+ERROR:  schema "topology" does not exist at character 8
+ERROR:  current transaction is aborted, commands ignored until end of transaction block
+ERROR:  schema "topology" does not exist at character 29
+ERROR:  schema "topology" does not exist at character 38
+ERROR:  relation "city_data.edge" does not exist at character 76
+ERROR:  relation "city_data.edge" does not exist at character 78
Summary of changes:
 NEWS                                        |   2 +
 topology/postgis_topology.c                 |  10 +-
 topology/test/regress/getringedges.sql      |   5 +
 topology/test/regress/getringedges_expected | 301 ++++++----------------------
 4 files changed, 81 insertions(+), 237 deletions(-)
hooks/post-receive
