[postgis-tickets] [PostGIS] #2175: Adding the same closed line to topology twice creates two nodes: ST_Scroll (or ST_Rebase) function
PostGIS trac at osgeo.org
Thu Jun 24 02:15:31 PDT 2021
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.2.0
 Component:  topology  |    Version:  main
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"f4a1ce593d866d04ebc6814bff3b8993d17567fd/git" f4a1ce5/git]:
 #!CommitTicketReference repository="git"
 revision="f4a1ce593d866d04ebc6814bff3b8993d17567fd"
 Avoid creating two nodes when adding same closed line to topology
 Closes #2175
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2175#comment:13>
