[postgis-tickets] [PostGIS] #4933: Slow topology population due to cost of finding face containing point.
PostGIS trac at osgeo.org
Mon Jun 28 08:07:15 PDT 2021
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.2.0
 Component:  topology     |    Version:
Resolution:               |   Keywords:
Comment (by strk):
 Unfortunately the current GetFaceByPoint function is *tested* to work
 against the broken topology built by topology.AddEdge and
 topology.AddFace, which is a combination of calls leaving the topology in
 a state with no correct edge linking. The new improved code relies instead
 on a valid topology in input.
 Note that ValidateTopology currently does not even report this kind of
 invalidity (see #3042)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4933#comment:7>
