[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-15-g85553d7ea
Mon Nov 1 06:36:10 PDT 2021
the project "PostGIS".
       via  85553d7ea16f3ada83d00e21c25c14b4f6c9612e (commit)
       via  53e3ede012c0c1a9b5c995febd71b43384eac335 (commit)
       via  7d668c157115f355dd3553117ddb162f49327da4 (commit)
       via  ba0c250f8d4e690f5cfa42b345f9309cd274c87d (commit)
      from  5b765a615dd11505e341248b87d7117a85195e68 (commit)
revisions in full, below.
commit 85553d7ea16f3ada83d00e21c25c14b4f6c9612e
Merge: 5b765a615 53e3ede01
Author: leoregina <lr at pcorp.us>
Date:   Mon Nov 1 09:31:04 2021 -0400
    Merge remote-tracking branch 'Kajan/shiftlongitude-doc'
    References #5010
commit 53e3ede012c0c1a9b5c995febd71b43384eac335
Author: Lauri Kajan <lauri.kajan at gispo.fi>
Date:   Mon Nov 1 08:05:53 2021 +0200
    Change to more representational examples
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index c4e31d914..9a0710157 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1769,20 +1769,28 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
         <title>Examples</title>
-        <programlisting>--forward transform
-SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(179.2 12.2, 180.3 12.8)'::geometry))
+        <programlisting>--single point forward transformation
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;POINT(270 0)'::geometry))
 st_astext
-LINESTRING(179.2 12.2,-179.7 12.8)
+POINT(-90 0)
---reverse transform
-SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(179.2 12.2,-179.7 12.8)'::geometry))
+--single point reverse transformation
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;POINT(-90 0)'::geometry))
 st_astext
-LINESTRING(179.2 12.2, 180.3 12.8)
+POINT(270 0)
+--for linestrings the functions affects only to the sufficient coordinates
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(174 12, 182 13)'::geometry))
+st_astext
+LINESTRING(174 12,-178 13)
         </programlisting>
       </refsection>
commit 7d668c157115f355dd3553117ddb162f49327da4
Date:   Mon Nov 1 08:04:37 2021 +0200
    Reword the description to be specific with terms
index f81250475..c4e31d914 100644
@@ -1733,7 +1733,7 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refnamediv>
         <refname>ST_ShiftLongitude</refname>
-        <refpurpose>Swaps longitude coordinates of a geometry between -180..180 and 0..360.</refpurpose>
+        <refpurpose>Shifts the longitude coordinates of a geometry between -180..180 and 0..360.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -1748,8 +1748,8 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
         <title>Description</title>
-        <para>Reads every point/vertex in a geometry, and swaps its longitude coordinate from -180..0 to 180..360 and vice versa if between these ranges.
-            This function is symmetrical so the result is a 0..360 version of a -180..180 data and -180..180 version of a 0..360 data.
+        <para>Reads every point/vertex in a geometry, and shifts its longitude coordinate from -180..0 to 180..360 and vice versa if between these ranges.
+            This function is symmetrical so the result is a 0..360 representation of a -180..180 data and a -180..180 representation of a 0..360 data.
             </para>
         <note><para>This is only useful for data with coordinates in
         longitude/latitude; e.g. SRID 4326 (WGS 84 geographic)</para></note>
commit ba0c250f8d4e690f5cfa42b345f9309cd274c87d
Date:   Thu Oct 21 09:41:26 2021 +0300
    Clarify ST_ShiftLongitude docs
    The ST_ShiftLongitude function behave symmetrical with inverse
    and reverse transformations. Clarify this in the docs.
index 90c7f6dd1..f81250475 100644
@@ -1733,14 +1733,14 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refnamediv>
-        <refpurpose>Shifts a geometry with geographic coordinates between -180..180 and 0..360.</refpurpose>
+        <refpurpose>Swaps longitude coordinates of a geometry between -180..180 and 0..360.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
         <funcsynopsis>
           <funcprototype>
             <funcdef>geometry <function>ST_ShiftLongitude</function></funcdef>
-            <paramdef><type>geometry </type> <parameter>geomA</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -1748,9 +1748,9 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
-        <para>Reads every point/vertex in a geometry, and if the longitude coordinate is <0, adds 360
-            to it. The result is a 0-360 version of the data to be
-            plotted in a 180 centric map</para>
+        <para>Reads every point/vertex in a geometry, and swaps its longitude coordinate from -180..0 to 180..360 and vice versa if between these ranges.
+            This function is symmetrical so the result is a 0..360 version of a -180..180 data and -180..180 version of a 0..360 data.
+            </para>
@@ -1769,19 +1769,20 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
-        <programlisting>--3d points
-SELECT ST_AsEWKT(ST_ShiftLongitude(ST_GeomFromEWKT('SRID=4326;POINT(-118.58 38.38 10)'))) As geomA,
-    ST_AsEWKT(ST_ShiftLongitude(ST_GeomFromEWKT('SRID=4326;POINT(241.42 38.38 10)'))) As geomb
-geomA                             geomB
-SRID=4326;POINT(241.42 38.38 10) SRID=4326;POINT(-118.58 38.38 10)
+        <programlisting>--forward transform
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(179.2 12.2, 180.3 12.8)'::geometry))
+st_astext
+LINESTRING(179.2 12.2,-179.7 12.8)
---regular line string
-SELECT ST_AsText(ST_ShiftLongitude(ST_GeomFromText('LINESTRING(-118.58 38.38, -118.20 38.45)')))
+--reverse transform
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(179.2 12.2,-179.7 12.8)'::geometry))
 st_astext
-LINESTRING(241.42 38.38,241.8 38.45)
+LINESTRING(179.2 12.2, 180.3 12.8)
         </programlisting>
       </refsection>
Summary of changes:
 doc/reference_editor.xml | 37 +++++++++++++++++++++++--------------
 1 file changed, 23 insertions(+), 14 deletions(-)
hooks/post-receive
