[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.4-8-gf42489b4a
Mon Nov 1 07:01:52 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  f42489b4ad4131097b71a4e8a67b8a21df228513 (commit)
       via  4686579f6c442898a26ed988ade18d4784318411 (commit)
       via  97565e7a82ebbe3ae0f8b61c32ce8045bedd9247 (commit)
      from  ec7f996bc9537919ea900f2517ab6ceae78c2b70 (commit)
revisions in full, below.
commit f42489b4ad4131097b71a4e8a67b8a21df228513
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 1 10:00:47 2021 -0400
    Doc clarifications for ST_ShiftLongitude
    from Lauri Kajan
    Closes #5010
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 671235bac..65ad55f51 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1682,14 +1682,14 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refnamediv>
         <refname>ST_ShiftLongitude</refname>
-        <refpurpose>Shifts a geometry with geographic coordinates between -180..180 and 0..360.</refpurpose>
+        <refpurpose>Shifts the longitude coordinates of a geometry between -180..180 and 0..360.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
         <funcsynopsis>
           <funcprototype>
             <funcdef>geometry <function>ST_ShiftLongitude</function></funcdef>
-            <paramdef><type>geometry </type> <parameter>geomA</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -1697,9 +1697,9 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
         <title>Description</title>
-        <para>Reads every point/vertex in a geometry, and if the longitude coordinate is <0, adds 360
-            to it. The result is a 0-360 version of the data to be
-            plotted in a 180 centric map</para>
+        <para>Reads every point/vertex in a geometry, and shifts its longitude coordinate from -180..0 to 180..360 and vice versa if between these ranges.
+            This function is symmetrical so the result is a 0..360 representation of a -180..180 data and a -180..180 representation of a 0..360 data.
+            </para>
         <note><para>This is only useful for data with coordinates in
         longitude/latitude; e.g. SRID 4326 (WGS 84 geographic)</para></note>
@@ -1718,19 +1718,28 @@ LINESTRING(0 0,1 1,0 0,3 3,4 4)
       <refsection>
         <title>Examples</title>
-        <programlisting>--3d points
-SELECT ST_AsEWKT(ST_ShiftLongitude(ST_GeomFromEWKT('SRID=4326;POINT(-118.58 38.38 10)'))) As geomA,
-    ST_AsEWKT(ST_ShiftLongitude(ST_GeomFromEWKT('SRID=4326;POINT(241.42 38.38 10)'))) As geomb
-geomA                             geomB
-SRID=4326;POINT(241.42 38.38 10) SRID=4326;POINT(-118.58 38.38 10)
+        <programlisting>--single point forward transformation
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;POINT(270 0)'::geometry))
+st_astext
+POINT(-90 0)
+--single point reverse transformation
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;POINT(-90 0)'::geometry))
+st_astext
+POINT(270 0)
---regular line string
-SELECT ST_AsText(ST_ShiftLongitude(ST_GeomFromText('LINESTRING(-118.58 38.38, -118.20 38.45)')))
+--for linestrings the functions affects only to the sufficient coordinates
+SELECT ST_AsText(ST_ShiftLongitude('SRID=4326;LINESTRING(174 12, 182 13)'::geometry))
 st_astext
-LINESTRING(241.42 38.38,241.8 38.45)
+LINESTRING(174 12,-178 13)
         </programlisting>
       </refsection>
commit 4686579f6c442898a26ed988ade18d4784318411
Merge: 97565e7a8 ec7f996bc
Date:   Mon Nov 1 10:00:19 2021 -0400
    Merge branch 'stable-3.1' of https://git.osgeo.org/gitea/postgis/postgis into stable-3.1
commit 97565e7a82ebbe3ae0f8b61c32ce8045bedd9247
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Oct 14 11:53:30 2021 -0700
    Round off some regression results to avoid spurious regression test failures under the latest GEOS release.
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index 2e05a7f08..21a7e76c9 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -5,7 +5,7 @@
 -- Ouput is snapped to grid to account for small floating numbers
 -- differences between architectures
-SELECT 'point quadsegs=2', ST_AsText(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 4);
+SELECT 'point quadsegs=2', ST_AsText(ST_SnapToGrid(st_buffer('POINT(0 0)', 1, 'quad_segs=2'),0.0001), 4);
 SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
 SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
 SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index 6bd9d4f0e..28847444e 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,4 +1,4 @@
-point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,1.6155e-15 -1,-0.7071 -0.7071,-1 -3.2311e-15,-0.7071 0.7071,-4.6246e-15 1,0.7071 0.7071,1 0))
+point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,0 -1,-0.7071 -0.7071,-1 0,-0.7071 0.7071,0 1,0.7071 0.7071,1 0))
 line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
 line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index dd4d36511..e07b50c7e 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -311,7 +311,7 @@ SELECT '#650', ST_AsText(ST_Collect(ARRAY[ST_MakePoint(0,0), ST_MakePoint(1,1),
 --SELECT '#662', ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326))) As the_geom FROM generate_series(-10,50,20) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m ORDER BY i, j, m, i*j*m LIMIT 1;
 -- #667 --
-SELECT '#667', ST_AsEWKT(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
+SELECT '#667', ST_AsText(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)),4) As geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
 -- #677 --
 SELECT '#677.deprecated',round(ST_DistanceSpheroid(ST_GeomFromEWKT('MULTIPOLYGON(((-10 40,-10 55,-10 70,5 40,-10 40)))'), ST_GeomFromEWKT('MULTIPOINT(20 40,20 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)'), 'SPHEROID["GRS_1980",6378137,298.257222101]')) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index f8dfdd934..91b8e7cc6 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -93,7 +93,7 @@ NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing found
 #835.11|MULTILINESTRING EMPTY
 #835.12|MULTIPOLYGON EMPTY
 #650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.99999999999987,30 40))
+#667|CURVEPOLYGON(CIRCULARSTRING(30 40,-50 40,30 40))
 #677.deprecated|1121395
 #677|1121395
 #680|01d107000000000000000024c000000000000049400000000000000040
Summary of changes:
 doc/reference_editor.xml | 37 +++++++++++++++++++++++--------------
 1 file changed, 23 insertions(+), 14 deletions(-)
hooks/post-receive
