[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-22-g8985b60df
Thu Nov 18 21:57:25 PST 2021
the project "PostGIS".
       via  8985b60df662984d5adb02b0cffaa39ab372024e (commit)
      from  530f7c88cbebf8357650ad7f337a46f61c0dd214 (commit)
revisions in full, below.
commit 8985b60df662984d5adb02b0cffaa39ab372024e
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Nov 19 00:57:20 2021 -0500
    Prevent duplicate links in Aggregate section.  References #5021 for PostGIS 3.2
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index 27273ee8b..b50d52a44 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -36,14 +36,12 @@
 				</xsl:variable>
 			<!-- For each function prototype if it takes a geometry set then catalog it as an aggregate function  -->
-				<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
-					<xsl:choose>
-						<xsl:when test="contains(paramdef/type,' set') or contains(paramdef/type,'geography set') or contains(paramdef/type,'raster set')">
+						<xsl:if test=".//paramdef[contains(type,' set')] or .//paramdef[contains(type,'geography set')] or
+						.//paramdef[contains(type,'raster set')]">
 							 <listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
-						</xsl:when>
-					</xsl:choose>
+						</xsl:if>
 				</xsl:for-each>
-			</xsl:for-each>
 			</itemizedlist>
 		</sect1>
Summary of changes:
 doc/xsl/postgis_aggs_mm.xml.xsl | 10 ++++------
 1 file changed, 4 insertions(+), 6 deletions(-)
hooks/post-receive
