[postgis-tickets] [PostGIS] #5026: DropTopology fires UPDATE triggers on topology layers
PostGIS trac at osgeo.org
Thu Nov 25 14:35:34 PST 2021
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.2.0
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Description changed by strk:
Old description:
> When a DELETE trigger is set on a TopoGeometry layer, the DropTopology
> fires it, possibly failing. It should instead disable or drop triggers, I
> think.
New description:
 When an UPDATE trigger is set on a TopoGeometry layer, the DropTopology
 think.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5026#comment:2>
