[postgis-tickets] [PostGIS] #5005: ST_AsFlatGeoBuf crashes on tables when geometry column is not the first column (was: ST_FlatGeoBuf crashes on tables when geometry column is not the first column)
PostGIS trac at osgeo.org
Thu Nov 25 18:20:10 PST 2021
column
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.2.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5005#comment:10>
